How to throw an exception in my custom library?
I would like to stop the compilation process if the inputs are invalid. I tried exception classes in the standard C++ library but Arduino does not recognise them. i tried throw "message"; but I got an error exception handling disabled, use -fexceptions to enable. Any ideas?
Thanks.
What do you mean?
Stop the code from uploading to the board. (user side)
Did you mean #error "message" ?
Oh thanks.
#if 1 == 1
#error C++ compiler required.
#endif
But why doesn't this work?
bool test() {
    return false;
    #if !test()
    #error "message."
    #endif
Because the preprocessor can't call a function that hasn't been compiled yet.
You can use constexpr functions with static_assert:
constexpr bool test(int i) {
    return i < 42;
  static_assert(test(43), "The test failed!");
In C++11, you're quite limited in what you can do inside of constexpr functions (basically only return statements), so you'll either have to beg the Arduino developers to enable the newer C++ features by default, or jump through some horrible metaprogramming hoops to get it working in C++11.
