I'm taking Clock data(SCL) from A5 and SDA from A4 port in Arduino UNO board. The code below is used to transfer 8 bit signal and illustrating signal on oscilloscope. The problem is that the 8 bit data vis not transferring and only transferring address bits. Please help me.
#include <Wire.h>
Wire.begin();
// join i2c bus (address optional for master)
//byte x = 0;
void loop(){
Wire.beginTransmission(170);
Wire.write(1);
Wire.write(0x07); // sends five bytes
Wire.endTransmission(); // stop transmitting
/*x++; // increment value
if (x == 127) { // if reached 64th position (max)
x = 0; // start over from lowest value
delay(10);
The transmission is aborted because no slave responded.
For testing purpose a broadcast (address 0) may work?
1. Connect UNO and NANO/UNO as per following diagram using I2C Bus. Don't forget to install the pull-up resistors.
2. Upload the following sketch (your one) in UNO-Master.
#include <Wire.h>
Wire.begin();
Wire.write(1);
delay(1000); //test interval
3. Upload the following sketch in NANO/UNO-Slave.
#include <Wire.h>
volatile bool flag = false;
byte myData[2];
Wire.begin(170);
Wire.onReceive(receiveEvent);
if(flag == true)
Serial.println(myData[0]); //shows: 1 (01)
Serial.println(myData[1]); //shows: 7 (07)
flag = false;
void receiveEvent(int howMany)
for(int i = 0; i<howMany; i++)
myData[i] = Wire.read();
flag = true;
4. Check that Serial Monitor of Slave shows: 1 and 7.
