I'm using an HC-05 Bluetooth module connected to an Arduino Nano Every to send sensor data to my android phone using App Inventor. I have successfully written the code for the Nano Every and the Android phone and breadboarded the hardware. All was good until I created the actual prototype. Now it seems that data is not being sent out from the HC-05 and therefore the data is not displayed on the phone. I have done as much troubleshooting as I know how and am at a loss as to what is wrong. I am using a potentiometer to simulate the analog pressure sensor for one of three sensors and am using SoftwareSerial to activate pins 10 and 11 for Rx and Tx respectively. The Nano and HC-05 are the same units used in the breadboard. Here's my simple schematic:
When I use a terminal program rather than my phone, I can connect to the HC-05 but there is no data displayed on the terminal. I disconnected the Tx and Rx wires to the Nano and shorted them together. The HC-05 responded with whatever I typed in through the terminal so it seems the HC-05 is working properly.
Here's my Nano code with only the necessary lines included since my code is fairly bloated. This will make it easier to read.
#include <SoftwareSerial.h> //Allows use of pins 10/11 for Tx/Rx instead of 0,1
/* RX is digital pin 10 (connect to TX of HC-05)
* TX is digital pin 11 (connect to RX of HC-05)*/
SoftwareSerial mySerial(10, 11); // RX, TX
int Fpin = A0; //Connect Fresh Water transduer to pin A0
int Gpin = A1; //Connect Grey Water transduer to pin A1
int Bpin = A2; //Connect Black Water transduer to pin A2
mySerial.begin(9600); //initializes software serial
Serial.println(fileName);
pinMode(Fpin, INPUT);
pinMode(Gpin, INPUT);
pinMode(Bpin, INPUT);
FreshWaterDetail();
GreyWaterDetail();
BlackWaterDetail();
// Send data to HC-05
String vals = String(int(FPercentheightinTank)) + "#" + String(int(GPercentheightinTank))
+ "#" + String(int(BPercentheightinTank)); //needed to send all data to HC-05 at once
mySerial.println(vals); //prints to software serial
Serial.print("1st FreadIndex = ");
Serial.print(FreadIndex);
Serial.print(" FPercentheightinTank = ");
Serial.print(FPercentheightinTank);
Serial.print(" Freading = ");
Serial.print(analogRead(Fpin));
Serial.print(" String = ");
Serial.println(vals); //prints to serial monitor
//*********************Subroutines****************************************
void FreshWaterDetail() //Calculates percent full
void GreyWaterDetail() //Calculates percent full
void BlackWaterDetail() //Calculates percent full
Can you suggest how to troubleshoot? Can I disconnect the wires to Pins 10 and 11 and connect to pins 0,1 (through a voltage divider to the Rx on the HC-05) using the same code except using only Serial.println(vals)) to see if that works?
So a detailed photograph of that might be a good idea.
Good one !
How about loading an empty sketch onto the Nano and using it as a USB to TTL, connecting TX to TX & RX to Voltage divider to RX, and use the Serial monitor to send data to the HC-05
Just a thought. Could it be that the HC-05 is not set to 9600bps anymore ? That would explain why it still communicates with itself, but not with the Nano anymore.
Power through the USB port until all is working, then 12V into Vin but I haven't used the Vin route yet on the prototype.
OK, but as I said, I think it is bloated. It is to measure liquid amounts in RV tanks, fresh, grey and black water.
char fileName[ ] = "Camper 2.1";
* Rev 2.1 combines Camper 2.0.2 with Boat monitor part of
* freshwater tank code
* Sends percentage to full number (ie x10) to HC-05
// F = fresh water,G = grey water, B = black water :
float FsensorRange = 12.06; //pressure range for sensor converted from kPa to inches
float GsensorRange = 12.06; //pressure range for sensor converted from kPa to inches
float BsensorRange = 12.06; //pressure range for sensor converted from kPa to inches
float FsensorToTankTop = 10.375; //distance in inches from tank Top to snensor at zero pressure
float GsensorToTankTop = 10.375; //distance in inches from tank Top to snensor at zero pressure
float BsensorToTankTop = 10.375; //distance in inches from tank Top to snensor at zero pressure
float FpercentSensorInchRange; //% of 12.06 max range of sensor that the top of the tabk is from sensor
float GpercentSensorInchRange; //% of 12.06 max range of sensor that the top of the tabk is from sensor
float BpercentSensorInchRange; //% of 12.06 max range of sensor that the top of the tabk is from sensor
float FmaxPinAtTankTop; //Pin value at top of tank
float GmaxPinAtTankTop; //Pin value at top of tank
float BmaxPinAtTankTop; //Pin value at top of tank
float FmaxVoltageAtTankTop; //Voltage at top of tank
float GmaxVoltageAtTankTop; //Voltage at top of tank
float BmaxVoltageAtTankTop; //Voltage at top of tank
int FmaxPinValueRange = 921; //at 3kPa, 12.06inches and 4.5 volts, pin value is 920 (ie 4.5*1023/5)
int GmaxPinValueRange = 921; //at 3kPa, 12.06inches and 4.5 volts, pin value is 920 (ie 4.5*1023/5)
int BmaxPinValueRange = 921; //at 3kPa, 12.06inches and 4.5 volts, pin value is 920 (ie 4.5*1023/5)
int Fbase = 102; //0 pressure at sensor pin value, ie .5V*1023/5V
int Gbase = 102; //0 pressure at sensor pin value, ie .5V*1023/5V
int Bbase = 102; //0 pressure at sensor pin value, ie .5V*1023/5V
int FmaxPinValue; //Pin Value at top of tank
int GmaxPinValue; //Pin Value at top of tank
int BmaxPinValue; //Pin Value at top of tank
float FmaxPinVoltage; //Voltage when level is at top of tank
float GmaxPinVoltage; //Voltage when level is at top of tank
float BmaxPinVoltage; //Voltage when level is at top of tank
float FpercentValueIs; //% of range from sensor to tank top that value read is
float GpercentValueIs; //% of range from sensor to tank top that value read is
float BpercentValueIs; //% of range from sensor to tank top that value read is
float FtankHeight = 12.375; // Total height of tank
float GtankHeight = 12.375; // Total height of tank
float BtankHeight = 12.375; // Total height of tank
float FheightinTank; //Calculated level above sensor
float GheightinTank; //Calculated level above sensor
float BheightinTank; //Calculated level above sensor
float FPercentheightinTank; //Calculated level above bottom of tank
float GPercentheightinTank; //Calculated level above bottom of tank
float BPercentheightinTank; //Calculated level above bottom of tank
int FsensorValue; //Pin value of sensor output
int GsensorValue; //Pin value of sensor output
int BsensorValue; //Pin value of sensor output
float Fvoltage; //Calculated value of voltage of sensor output
float Gvoltage; //Calculated value of voltage of sensor output
float Bvoltage; //Calculated value of voltage of sensor output
float FabsHeight; //Absolute value in inches from bottom of tank
float GabsHeight; //Absolute value in inches from bottom of tank
float BabsHeight; //Absolute value in inches from bottom of tank
const int FnumReadings = 100; //number of readings to be averaged
const int GnumReadings = 100; //number of readings to be averaged
const int BnumReadings = 100; //number of readings to be averaged
int FreadingsArray[FnumReadings]; // the readings from the analog input
int GreadingsArray[GnumReadings]; // the readings from the analog input
int BreadingsArray[BnumReadings]; // the readings from the analog input
int FreadIndex = 0; // the index of the current reading
int GreadIndex = 0; // the index of the current reading
int BreadIndex = 0; // the index of the current reading
float Ftotal = 0; // the running total
float Gtotal = 0; // the running total
float Btotal = 0; // the running total
int FaveSensor = 0; // the average
int GaveSensor = 0; // the average
int BaveSensor = 0; // the average
int FgoodAveFlag = 0; //when first turned on, a final average is arrived at
int GgoodAveFlag = 0; //when first turned on, a final average is arrived at
int BgoodAveFlag = 0; //when first turned on, a final average is arrived at
//init pins
// initialize all the readings to 0 for average
for (int BthisReading = 0; BthisReading < BnumReadings; BthisReading++) {
BreadingsArray[BthisReading] = 0;
// delay (1000);
FreshWaterDetail();
GreyWaterDetail();
BlackWaterDetail();
//For testing with only one pot to simulate transducer:
/* if (FPercentheightinTank+25 >= 100)
GPercentheightinTank = 100;
GPercentheightinTank = FPercentheightinTank + 25;
if (FPercentheightinTank+50 >= 100)
BPercentheightinTank = 100;
BPercentheightinTank = FPercentheightinTank + 50;
/* if(FgoodAveFlag == 0)
{ // Do nothing
delay(500); // else add a delay
//*********************Average data******************************
// read the input on analog pin A0 and average:
// subtract the last reading:
Ftotal = Ftotal - FreadingsArray[FreadIndex];
// read from the sensor:
FreadingsArray[FreadIndex] = analogRead(Fpin);
// add the reading to the total:
Ftotal = Ftotal + FreadingsArray[FreadIndex];
// advance to the next position in the array:
FreadIndex = FreadIndex + 1;
// if we're at the end of the array...
if (FreadIndex >= FnumReadings)
FgoodAveFlag = 1;
// ...wrap around to the beginning:
FreadIndex = 0;
// calculate the average:
FaveSensor = Ftotal / (FnumReadings);
FsensorValue = FaveSensor;
Fvoltage = FsensorValue * (5.0 / 1023.0);
FpercentSensorInchRange = FsensorToTankTop / FsensorRange; //% of 12.06 max range of sensor that the top of the tank is from sensor
FmaxPinAtTankTop = (FpercentSensorInchRange * (FmaxPinValueRange - Fbase)) + Fbase; //Pin value at top of tank
FpercentValueIs = (FsensorValue - Fbase) / (FmaxPinAtTankTop-Fbase); //% of range from sensor to tank top that value read is
FheightinTank = FpercentValueIs * FsensorToTankTop; //Height above sensor
FabsHeight = FheightinTank +(12.375 - FsensorToTankTop); // Total height in tank
if(FabsHeight < 0) // don't show negative heights
FabsHeight = 0;
FPercentheightinTank = (FabsHeight / FtankHeight) * 100; //Convert to integer Percentage of tank is full
// read the input on analog pin A1 and average:
Gtotal = Gtotal - GreadingsArray[GreadIndex];
GreadingsArray[GreadIndex] = analogRead(Gpin);
Gtotal = Gtotal + GreadingsArray[GreadIndex];
GreadIndex = GreadIndex + 1;
if (GreadIndex >= GnumReadings)
GgoodAveFlag = 1;
GreadIndex = 0;
GaveSensor = Gtotal / (GnumReadings);
GsensorValue = GaveSensor;
Gvoltage = GsensorValue * (5.0 / 1023.0);
GpercentSensorInchRange = GsensorToTankTop / GsensorRange; //% of 12.06 max range of sensor that the top of the tank is from sensor
GmaxPinAtTankTop = (GpercentSensorInchRange * (GmaxPinValueRange - Gbase)) + Gbase; //Pin value at top of tank
GpercentValueIs = (GsensorValue - Gbase) / (GmaxPinAtTankTop-Gbase); //% of range from sensor to tank top that value read is
GheightinTank = GpercentValueIs * GsensorToTankTop; //Height above sensor
GabsHeight = GheightinTank +(12.375 - GsensorToTankTop); // Total height in tank
if(GabsHeight < 0) // don't show negative heights
GabsHeight = 0;
GPercentheightinTank = (GabsHeight / GtankHeight) * 100; //Percentage of tank is full
// read the input on analog pin A3 and average:
Btotal = Btotal - BreadingsArray[BreadIndex];
BreadingsArray[BreadIndex] = analogRead(Bpin);
Btotal = Btotal + BreadingsArray[BreadIndex];
BreadIndex = BreadIndex + 1;
if (BreadIndex >= BnumReadings)
BgoodAveFlag = 1;
BreadIndex = 0;
BaveSensor = Btotal / (BnumReadings);
BsensorValue = BaveSensor;
Bvoltage = BsensorValue * (5.0 / 1023.0);
BpercentSensorInchRange = BsensorToTankTop / BsensorRange; //% of 12.06 max range of sensor that the top of the tank is from sensor
BmaxPinAtTankTop = (BpercentSensorInchRange * (BmaxPinValueRange - Bbase)) + Bbase; //Pin value at top of tank
BpercentValueIs = (BsensorValue - Bbase) / (BmaxPinAtTankTop-Bbase); //% of range from sensor to tank top that value read is
BheightinTank = BpercentValueIs * BsensorToTankTop; //Height above sensor
BabsHeight = BheightinTank +(12.375 - BsensorToTankTop); // Total height in tank
if(BabsHeight < 0) // don't show negative heights
BabsHeight = 0;
BPercentheightinTank = (BabsHeight / BtankHeight) * 100; //Percentage of tank is full
Thanks, Looking very good ! A bit confusing that there is an extra solder point on 1 of the rows, which led me to believe you misconnected, but that is not true. The connection between the TX-pin (11) and the resistor is suspect though. I would re-melt that. Just to make sure that's not the issue.
Another unfortunate event is that the voltage divider is mounted in relation the Nano, but it actually belongs to the HC-05. Like this it is hard to test the HC-05 using the Nano as USB to TTL. You could try a simple Serial passthrough at different speeds.
Thanks but I had soldered it on the other side and that one is good.
So desoldered the HC-05 and redid the breadboard and all works good. The issue must be in my soldering of the porotype board. But for the life of me, I can't find the cause. So I am going to start over from scratch and check it all along the way.
So, I found the problem, but I don't understand it. What I haven't made clear here in this thread is that I intend to use 12V to power the board and sensors but up to this point on the prototype, I have powered the board through the USB connection. As I was rebuilding the board, I checked the function at each step. As soon as I add a wire from the Vin pin to a pin that happens to be next to the A0 pin, the transfer of data from the Nano Every to the HC-05 and therefore to the app on my phone fails (although the serial monitor is still showing data as it should be). Disconnect the wire from that pin and all is well. It seems there is some cross talk between the A0 pin and the Vin pin that effects the HC-05??? Note I do have a potentiometer attached to pin A0. Can I ground the Vin pin until I actually have 12V on it in order to stop the cross talk or will the Vin pin not go for that when powered by the USB?
If you are powering through USB, you should not use the Vin pin at all. If you want 5v, you should use the 5v pin.
The Vin pin should not really provide you with any power at all and should be considered a power input only. In fact i am confused you managed to get it to work using that pin at all.
If you intend to use 12v later, i would still recommend you scale that down to 5v first (using a regulator) and power the board through the 5v pin. Vin takes 7-12v but the onboard linear is not very powerful, and from 12v down to 5v a lot of heat will need to be dissipated.
Doesn't the HC-05 work on a 3.7- 4.2 range ? or is there a regulator included in the unit you are using.
I am using USB for power only to troubleshoot. I have never used 12V yet so there has never been 12V on that line - it is just where I will connect it eventually instead of using the USB. I am planning on using12V since this project will be connected to my RV which will be the source of power (12V).
So the issue is that the Vin pin is getting influenced by the A0 pin and effecting the HC-05. It sounds strange and unlikely, but that's the facts at the moment! Again, when the Vin pin is connected to the terminal strip next to pin A0, I get no output from the HC-05 even though the data is shown on the serial monitor. I guess I will have to reroute that wire and move the connector away from pin A0 and see if that helps ignore the issue. I notice that pins A1 and A2 show the same data as pin A0 even though nothing is connected to them. I'm not sure why that is.
