I have installed IDE 2.0.0 and have launched it as a test. A blank space has appeared with line numbers. I have searched Preferences to find the option for hiding the line numbers; but, I don't see any option there like IDE 1.8.19. Please, help.
Hi @GolamMostafa. This can be done via the the IDE's advanced settings:
- Press the Ctrl+Shift+P keyboard shortcut (Command+Shift+P for macOS users) to open the "Command Palette".
- Select the "Preferences: Open Settings (UI)" command from the menu.
- A "Preferences" tab will now open in the Arduino IDE. In the "Search Settings" field of that tab, type
editor.lineNumbers - In the search results of the "Preferences" tab, you will now see an "Editor: Line Numbers" setting. Select "off" from the dropdown menu.
- Click the X icon on the "Preferences" tab.
Does not work on 2.3
It works for me in Windows 10
