part 2
void set(byte position, int value)
// segment 0, red
if ( (0 <= position) && (position < LED_COUNT / SEG) ) // segment 0 (bottom to top), red
if ( value == 0 )
leds.setPixelColor( position, 0, 0, 0 );
// increase light output of a low number
// value += 10;
// value = constrain( value, 0, 255 ); // keep raised value within limits
if ( value <= 25 )
leds.setPixelColor( position, leds.Color( value , 0, 0) );
if ( (value * LED0_Multiplier) >= 255 )
leds.setPixelColor( position, leds.Color( 255 , 0, 0) );
leds.setPixelColor( position, leds.Color( (value * LED0_Multiplier) , 0, 0) );
else if ( (LED_COUNT / SEG <= position) && (position < LED_COUNT / SEG * 2) ) // segment 1 yellow
if ( value == 0 )
leds.setPixelColor(position, leds.Color(0, 0, 0));
leds.setPixelColor(position, leds.Color( value, value, 0)); // works better to make yellow
else if ( (LED_COUNT / SEG * 2 <= position) && (position < LED_COUNT / SEG * 3) ) // segment 2 pink
if ( value == 0 )
leds.setPixelColor(position, leds.Color( value, 0, value * .91) ); // pink
else if ( (LED_COUNT / SEG * 3 <= position) && (position < LED_COUNT / SEG * 4) ) // seg 3, green
if ( value == 0 )
leds.setPixelColor(position, leds.Color( 0, 0, 0));
else //
leds.setPixelColor( position, leds.Color( 0, value, 0) ); //
else if ( (LED_COUNT / SEG * 4 <= position) && (position < LED_COUNT / SEG * 5) ) // segment 4, leds.color( R, G, B ), blue
if ( value == 0 )
else //
leds.setPixelColor(position, leds.Color( 0, 0, value) ); // blue
else // segment 5
if ( value == 0 )
leds.setPixelColor(position, leds.Color( 0, 0, 0)); // only helps a little bit in turning the leds off
leds.setPixelColor( position, leds.Color( value, value * .3, 0) ); // orange
} // void set(byte position, int value)
void clearLEDs()
for (int i = 0; i < LED_COUNT; i++)
leds.setPixelColor(i, 0);
} // void clearLEDs()
Each I_XXX preprocessor define translates into a single 32-bit instruction. So you can count instructions to learn which memory address are used and where the free mem space starts.
To generate branch instructions, special M_ preprocessor defines are used. M_LABEL define can be used to define a branch target.
Implementation note: these M_ preprocessor defines will be translated into two ulp_insn_t values: one is a token value which contains label number, and the other is the actual instruction.
void ULP_BLINK_RUN(uint32_t us)
size_t load_addr = 0;
RTC_SLOW_MEM[12] = 0;
ulp_set_wakeup_period(0, us);
const ulp_insn_t ulp_blink[] =
I_MOVI(R3, 12), // #12 -> R3
I_LD(R0, R3, 0), // R0 = RTC_SLOW_MEM[R3(#12)]
M_BL(1, 1), // GOTO M_LABEL(1) IF R0 < 1
I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 1), // RTC_GPIO2 = 1
I_SUBI(R0, R0, 1), // R0 = R0 - 1, R0 = 1, R0 = 0
I_ST(R0, R3, 0), // RTC_SLOW_MEM[R3(#12)] = R0
M_BX(2), // GOTO M_LABEL(2)
M_LABEL(1), // M_LABEL(1)
I_WR_REG(RTC_GPIO_OUT_REG, 26, 27, 0),// RTC_GPIO2 = 0
I_ADDI(R0, R0, 1), // R0 = R0 + 1, R0 = 0, R0 = 1
M_LABEL(2), // M_LABEL(2)
I_HALT() // HALT COPROCESSOR
const gpio_num_t led_gpios[] =
GPIO_NUM_2,
// GPIO_NUM_0,
// GPIO_NUM_4
for (size_t i = 0; i < sizeof(led_gpios) / sizeof(led_gpios[0]); ++i) {
rtc_gpio_init(led_gpios[i]);
rtc_gpio_set_direction(led_gpios[i], RTC_GPIO_MODE_OUTPUT_ONLY);
rtc_gpio_set_level(led_gpios[i], 0);
size_t size = sizeof(ulp_blink) / sizeof(ulp_insn_t);
ulp_process_macros_and_load( load_addr, ulp_blink, &size);
ulp_run( load_addr );
} // void ULP_BLINK_RUN(uint32_t us)
