Please describe your question in more detail.
and review do while() syntax.
do {
// code block to be executed
while (condition);
Help us help you.
I want to run both pixels 1 and pixels 2 but before i added "do" and "while" it only run pixels 1 -> pixels 2 -> pixels 1 -> pixels 2....
What code can be to run both 2 pixels
Yep thats it. Thats how do while works.
The error is like this: You wrote
loop{
//do something
}//Here is the error about
do{
//somehting
while
Like it should look:
do{
//somehting
while(condition)
Can u fix for me?
I can post my code in here
I can at least try it.
int pin_1 = 2; int pin_2 = 3;
int numPixels_1 = 8; int numPixels_2 =16;
int pixelFormat = NEO_GRB + NEO_KHZ800;
Adafruit_NeoPixel *pixels_1; Adafruit_NeoPixel *pixels_2;
#define DELAYVAL 255
pixels_1 = new Adafruit_NeoPixel(numPixels_1, pin_1, pixelFormat);
pixels_1->begin();
pixels_2 = new Adafruit_NeoPixel(numPixels_2, pin_2, pixelFormat);
pixels_2->begin();
pixels_2->show();
pixels_2->setBrightness(50);
// PIXELS 1
do
pixels_1->clear();
for(int i=0; i<numPixels_1; i++) {
pixels_1->setPixelColor(i, pixels_1->Color(0, 150, 0));
pixels_1->show();
delay(DELAYVAL);
while
// PIXELS 2
colorWipe(pixels_2->Color(255, 0, 0), 50); // Red
colorWipe(pixels_2->Color( 0, 255, 0), 50); // Green
colorWipe(pixels_2->Color( 0, 0, 255), 50); // Blue
rainbow(10);
theaterChaseRainbow(50);
void colorWipe(uint32_t color, int wait) {
for(int j=0; j<pixels_2->numPixels(); j++) {
pixels_2->setPixelColor(j, color);
pixels_2->show();
delay(wait);
void rainbow(int wait) {
for(long firstPixelHue = 0; firstPixelHue < 5*65536; firstPixelHue += 256) {
pixels_2->rainbow(firstPixelHue);
pixels_2->show();
delay(wait);
void theaterChaseRainbow(int wait) {
int firstPixelHue = 0;
for(int a=0; a<30; a++) {
for(int b=0; b<3; b++) {
pixels_2->clear();
for(int c=b; c<pixels_2->numPixels(); c += 3) {
int hue = firstPixelHue + c * 65536L / pixels_2->numPixels();
uint32_t color = pixels_2->gamma32(pixels_2->ColorHSV(hue));
pixels_2->setPixelColor(c, color);
pixels_2->show();
delay(wait);
firstPixelHue += 65536 / 90;
What symbol always comes right after the do? Look at the examples
pixels_1->show();
delay(DELAYVAL);
i'm not familiar with AdaFruit_NeoPixles. shouldn't you execute the above for both "pixels"(?), pixels_1 and pixels_2?
maybe
pixels_1->show();
delay(DELAYVAL);
for(int i=0; i<numPixels_2; i++) {
pixels_2->setPixelColor(i, pixels_2->Color(0, 150, 0));
pixels_2->show();
delay(DELAYVAL);
pixels_1->begin();
pixels_2->begin();
pixels_2->show();
// PIXELS 1
do {
pixels_1->clear();
pixels_1->show();
delay(DELAYVAL);
// PIXELS 2
rainbow(10);
while(//!!!!!!!!!!!!!!!!Custom Condition)
pixels_2->show();
delay(wait);
pixels_2->show();
delay(wait);
pixels_2->clear();
pixels_2->show();
delay(wait);
I dont kow this is gonna work because im not familiar with NeoPixel. Just try it i think.
That didn't work, i maybe use fastled instead of neopixel
Changing to FastLED is unlikely to make any difference.
It is not exactly clear what you want to do, or what the do/while is needed for.
As it is, the code (if you remove the do/while), will do the following sequence:
clear pixel_1
progressively light all the LEDs in pixel_1
light pixel_2 all RED
light pixel_2 all GREEN
light pixel_2 all BLUE
run rainbow on pixel_2
run theaterChaseRainbow on pixel_2
do you understand "fastled" better than you understand "neo_pixel"?
If you don't know the condition of the while, then you likely don't need a do/while loop.
You are already in a looping function. Consider just eliminating the do/while loop and just coding directly what you want done.
It sounds like you want to have different patterns showing on the two strips at the same time. To do that you have to get rid of delay() in all of your patterns. For example:
This has to be re-written using a millis() timer;
static unsigned long lastChangeTime = 0;
int currentPixel = 0;
if (millis() - lastChangeTime >= DELAYVAL)
lastChangeTime = millis();
if (currentPixel == 0)
pixels_1->clear();
pixels_1->setPixelColor(currentPixel, pixels_1->Color(0, 150, 0));
pixels_1->show();
currentPixel++;
if (currentPixel >= numPixels_1)
currentPixel = 0;
