I have ordered DTS6012M laser distance sensor but I don't know how to connect it to an arduino board. Are there similar laser distance sensor that I can refer to ? The pin outputs of DTS6012M is as follow:
When I looked at the datasheet, I found that if i want to use uart, i need to ground the int pin as follow.
And I don't know how to proceed from there to read distance from the sensor. The datasheet is in chinese and can be found at https://www.paioutech.com/uploadfile/202406/104fa6ddcebbe93.pdf
I think I need to trigger it with 3.3 V in order to received distance reading. Is there some function or library that is used in other laser distance meter that I can use for this? Thank you
