How to use the DS1302 RTC module?
I looked up numerous tutorials and all of the referenced libraries do not work.
My wiring is:
VCC - 5v
GND - gnd
CLK - 12
DAT - 13
RST - 11
This is my current code, which always returns Current Date / Time: 45/25/2165 45:85:85 which never changes:
#include <virtuabotixRTC.h>
// Creation of the Real Time Clock Object
virtuabotixRTC myRTC(12, 13, 11);
void setup()  {
  // Set the current date, and time in the following format:
  // seconds, minutes, hours, day of the week, day of the month, month, year
  myRTC.setDS1302Time(18, 10, 10, 7, 18, 9, 2020);
void loop()  {
  // This allows for the update of variables for time or accessing the individual elements.
  myRTC.updateTime();
  // Start printing elements as individuals
  Serial.print("Current Date / Time: ");
  Serial.print(myRTC.dayofmonth);
  Serial.print("/");
  Serial.print(myRTC.month);
  Serial.print("/");
  Serial.print(myRTC.year);
  Serial.print("  ");
  Serial.print(myRTC.hours);
  Serial.print(":");
  Serial.print(myRTC.minutes);
  Serial.print(":");
  Serial.println(myRTC.seconds);
  // Delay so the program doesn't print non-stop
How do I correctly do this?
The .cpp shows this function might be what you seek to update the current time:
myRTC.updateTime();
That is already in my code.
I found an example sketch that worked!:
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <RtcDS1302.h>
ThreeWire myWire(4,5,2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
void setup ()
    Serial.begin(57600);
    Serial.print("compiled: ");
    Serial.print(__DATE__);
    Serial.println(__TIME__);
    Rtc.Begin();
    RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
    printDateTime(compiled);
    if (!Rtc.IsDateTimeValid())
        // Common Causes:
        //    1) first time you ran and the device wasn't running yet
        //    2) the battery on the device is low or even missing
        Serial.println("RTC lost confidence in the DateTime!");
        Rtc.SetDateTime(compiled);
    if (Rtc.GetIsWriteProtected())
        Serial.println("RTC was write protected, enabling writing now");
        Rtc.SetIsWriteProtected(false);
    if (!Rtc.GetIsRunning())
        Serial.println("RTC was not actively running, starting now");
        Rtc.SetIsRunning(true);
    RtcDateTime now = Rtc.GetDateTime();
    if (now < compiled)
        Serial.println("RTC is older than compile time!  (Updating DateTime)");
    else if (now > compiled)
        Serial.println("RTC is newer than compile time. (this is expected)");
    else if (now == compiled)
        Serial.println("RTC is the same as compile time! (not expected but all is fine)");
void loop ()
    printDateTime(now);
    if (!now.IsValid())
        // Common Causes:
        //    1) the battery on the device is low or even missing and the power line was disconnected
    delay(10000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
    char datestring[26];
    snprintf_P(datestring,
            countof(datestring),
            PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
    Serial.print(datestring);
Now how do I just regularly get the hour, minute, and second as int for further processing?
I would suspect your wiring.
Try this example from the library:
With this I still get a value of "0" for seconds, minutes, hours, etc.
Also there is nothing wrong with my wiring in post #4 because it is the only sketch that works.
Hi @busybird15,
if you analyze the sketch from your post #4 the data you look for should be available in loop() like this (not tested!!):
  • now.Hour()
  • now.Minute()
  • now.Second()
Feel free to try this changed loop() in this sketch:
// CONNECTIONS:
void setup ()
    Rtc.Begin();
        // Common Causes:
    if (now < compiled)
void loop ()
    if (!now.IsValid())
        // Common Causes:
      Serial.print(now.Hour());
      Serial.print(":");
      Serial.print(now.Minute());
      Serial.print(":");
      Serial.print(now.Second());
      Serial.println;
    delay(1000); // 1 second
After modifying it slightly (compiler errors due to not testing :slight_smile: ) it worked!
Thank you so much!
Great, (just saw it: Missing brackets after println() I guess... :wink: )
