if( irrecv.decode(&results)){
while ( value==3772793023){
value=results.value;
Serial.println(value);
irrecv.resume();
irrecv.resume();
Help us help you.
Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
Please post a schematic.
Please post an image of your project.
Please describe the problem better then you just did.
code snippets suck.
Are you using a Uno or Mega with the number 3772793023? The Uno, Mega, and a few others cast that number as a 16 bit integer
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project.
In the while-loop you never check if there is anything decoded.
unsigned long value = 0;
do {
if (irrecv.decode(&results)) {
value = results.value;
irrecv.resume();
} while (value != 3772793023);
// Done waiting
<#include <IRremote.h>
IRrecv irrecv(9);
unsigned long val=0;
decode_results results;
Serial.begin(9600);// initialize serial monitor
irrecv.enableIRIn();
while (val = 3772793023){
if (irrecv.decode(&results)){
val=(results.value,DEC);
Serial.println(results.value,DEC);
irrecv.resume();
Serial.print("OK");
i used this code ,but it doesn't print "OK" even the 'val' match with the code
= assignment
== comparison
Even if you fix it to "while (val == 3772793023) {" it will not work because 'val' is set to 0 and will never be equal to 3772793023 because you never enter the 'while' body. You want:
while (val != 3772793023) {
That will repeat the decode until the desired input is found.
< while (val == 3772793023){
Serial.println(val);
irrecv.resume();
Serial.print("OK");
when its apply above code its print "OK" contineously
Yes. See post #8. You never look for input because "(val == 3772793023)" is always false.
