I have bought a few components from Jaycar. (The Australian equivalent to Radio Shack) I have already had success constructing a breadboard with a blinking LED. So far so good. The next component I'd like to attach is a piezoelectric buzzer. The component description is here:
A fellow on the #arduino channel said this might draw too much current and damage the board (the board is actually a Freetronics Eleven, if that matters). So I would like some help setting up the circuit. Also, I was informed that you don't need to use the tone() function with a buzzer - is that right?
Have you tried to google this? I am sure there is a lot out there about this. It is very basic and most beginners go through this phase?
You need to use the tone() function because to get a sound you need to vibrate the piezo at high frequency. Tone() will do that, or you can do it in your own code.
Indeed I have googled this, and I did look at the tone() example. However, I do not know whether a piezoelectric buzzer works in the same way as a speaker. One fellow on IRC suggested that you don't need to use tone() at all. What would happen if I just connected one lead to 5V and the other to GND? Also, I got some advice on #arduino indicating I might need to use a transistor. There is no transistor specified in the tone() tutorial. Perhaps he meant "resistor", but I don't really know.
marco_c:
jhanarato:
Probably not much. The buzzer is designed for 12V operation, you'll need an external power supply to use it (or a voltage booster module).
jhanarato:
You need a transistor if the current needed for the device is more than 20-30 milliamps or the voltage is higher then 5V and you want to use an external power supply.
I think I understand now. Basically the buzzer needs a voltage switched on and off very quickly. Looking at the Jaycar page for the buzzer it is rated at 6-14VDC. So, it needs more voltage than the arduino can supply, right? Actually I wanted to get this component:
