Yes, you can connect it to your Mega2560 if you want. Just buy 21 level shifters for the TFT. And a few more for the SD if you want to use that.
It is a lot of hard work wiring up all those level shifters.
You could buy a 40-pin Adapter shield which will be easier. Just lots of plain wires from your display to the appropriate pins on the 20x2 socket.
It is much simpler to just buy a STM32 board with a matching socket. No need for level shifters.
The Chinese are very naughty. (I suppose that the Brits did give them Opium Wars, but we have been pretty nasty to most countries)
Normally Ebay Shops just add the word "Arduino" to an item. No one expects Ebay vendors to be honest.
It looks like the Manufacturer deliberately printed "Arduino" and the official logo. The display is not Arduino compatible in any way. The pins are all 3.3V and on a 32-pin header. No Arduinos have 32-pin headers.
You can buy an adapter like this
which has pinout like
It is your job to compare the pins on your display. Make sure that the LCD_VCC pin#1 on CN2 is 3.3V. The Shield probably has a 3.3V LDO regulator but it is your job to make sure it goes to the right pin.
But first I will try to cable it directly to the mega even if it will take me another month.
I want to learn, and as the French proverb says by force of forging will I become blacksmith? We'll see ! may be.
There are several 40-pin adapter shields. They have onboard level-shifters. You can buy them locally in Europe. Delivered in 24-48 hours.
You can use jumper wires from 32-pin to 40-pin.
This particular Adapter has 40-pin and 32-pin socket. If the 32 pins match your display, it will plug and go. It is made by CTE or Sainsmart. If you receive a Sainsmart pcb, check it carefully for bad soldering etc. Check pin#1 for 3.3V
If you connect 5V to your 3.3V display you will damage it. The Blacksmith does not put his hand into the Forge. He uses tongs.
Life is so much easier if you add your country to your Profile.
You keep all your privacy but readers will give you more appropriate replies.
In Europe or U.S. / Canada there are online hobbyist shops. They stock the most popular boards and accessories. They cost more than online Chinese shops but delivery is 24-72 hours.
I would never think of going to a regular shop. Even if I travelled to London, I doubt if I could buy items that are available from an Internet shop.
Sometimes packets take 9 days from China to the UK. Average 15 days. Sometimes 40 days.
How long does it take a packet from UK to Morocco?
I sent a packet from the UK to Teheran. 6 days !!!
I have no way to access your Google account. Nor would I want to. I guess you would not want me either.
You are a member of this Forum. You can enter your country in the Profile. Other members would see that you live in Morocco.
I guess that your postal service might be slower than European post. I guess that English is not your first language.
We can show you how to connect a 3.3V display to a 5V Mega2560. i.e. use level shifters.
A ready-made Adapter shield contains level shifters.
You could do this manually. e.g. by soldering level shifter chips, potential dividers or series resistors.
It is a lot of work.
