int s0 = 7;
int s1 = 8;
int s2 = 9;
int s3 = 16;
const int ledPin1 = 2;
const int ledPin2 = 3;
const int ledPin3 = 4;
const int ledPin4 = 5;
const int ledPin5 = 6;
int SIG_pin = 10;
void setup(){
pinMode(s0, OUTPUT);
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(s3, OUTPUT);
pinMode(SIG_pin,INPUT);
digitalWrite(s0, LOW);
digitalWrite(s1, LOW);
digitalWrite(s2, LOW);
digitalWrite(s3, LOW);
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
digitalWrite(ledPin5, LOW);
void loop(){
//Loop through and read all 16 values
//Reports back Value at channel 6 is: 346
for(int i = 0; i < 16; i ++){Serial.print("value ");
Serial.print(i);
Serial.print(" is : ");
Serial.println(readMux(i));
delay(500);}
int buton1 = readMux(0); //(Problem is here) I can't take the value of readMux(0)
if(buton1==HIGH) // I want to add digitalRead stg.
{digitalWrite(ledPin1,LOW);}else{digitalWrite(ledPin1,HIGH);}
int readMux(int channel){
int controlPin[] = {s0, s1, s2, s3};
int muxChannel[16][4]={ {0,0,0,0}, //channel 0
{1,0,0,0}, //channel 1
{0,1,0,0}, //channel 2
{1,1,0,0}, //channel 3
{0,0,1,0}, //channel 4
{1,0,1,0}, //channel 5
{0,1,1,0}, //channel 6
{1,1,1,0}, //channel 7
{0,0,0,1}, //channel 8
{1,0,0,1}, //channel 9
{0,1,0,1}, //channel 10
{1,1,0,1}, //channel 11
{0,0,1,1}, //channel 12
{1,0,1,1}, //channel 13
{0,1,1,1}, //channel 14
{1,1,1,1}};//channel 15
//loop through the 4 sig
for(int i = 0; i < 4; i ++){digitalWrite(controlPin[i], muxChannel[channel][i]);}
//read the value at the SIG pin
int val = analogRead(SIG_pin);
//return the value
return val;
I want to use hp4067 multiplexer (for 16 button input) button box using Joystick.
I read 16 button value as serial (0 and 1023).
How can I read digitalread (covert serial to digital read)
pls help this subject.
Thk u.
