i am encountering a problem with the below code. its that the mp3 isnt making a sound. so the order should be that i set an alarm for each motor as seen in the code. once alarm is reached the mp3 makes a sound and plays the track (2,25). then the huskylens checks face. if serial monitor output is ID=1 then the step motor moves.
#include <AccelStepper.h> // Include the AccelStepper Library
#include <DS3232RTC.h> // RTC library
#include <Streaming.h> // For easier Serial prints
#include "mp3tf16p.h" // Custom MP3 player library
#include <TimeLib.h> // Time functions
#include "HUSKYLENS.h" // HuskyLens Library
#include "SoftwareSerial.h" // Software Serial for HuskyLens Communication
// Pin definitions
#define LED_PIN 43 // Changed LED pin
#define MP3_RX 12
#define MP3_TX 8
// MP3 Player RX and TX pins
MP3Player mp3(MP3_RX, MP3_TX); //Changed MP3 pins.
// RTC instance
DS3232RTC myRTC;
// Define step constants
#define FULLSTEP 4
#define HALFSTEP 8
// Stepper motor instances (4 motors)
AccelStepper stepper1(HALFSTEP, 44, 40, 42, 38); // Motor 1
AccelStepper stepper2(HALFSTEP, 27, 31, 33, 29); // Motor 2
AccelStepper stepper3(HALFSTEP, 51, 47, 49, 45); // Motor 3
AccelStepper stepper4(HALFSTEP, 7, 5, 6, 4); // Motor 4
// Alarm times for each motor
tmElements_t alarmTime1, alarmTime2, alarmTime3, alarmTime4;
bool alarmSet1 = false, alarmSet2 = false, alarmSet3 = false, alarmSet4 = false; // Flags for each alarm
bool motor1Triggered = false, motor2Triggered = false, motor3Triggered = false, motor4Triggered = false; // Alarm-triggered flags for motors
// HuskyLens communication
HUSKYLENS huskylens;
SoftwareSerial mySerial(10, 11); // RX, TX for HuskyLens
// Flag to track if face has been recognized and motor should move
bool faceRecognized = false;
pinMode(LED_PIN, OUTPUT);
// Initialize RTC
Serial << F("Initializing RTC...") << endl;
myRTC.begin();
setSyncProvider(myRTC.get);
delay(200);
Serial << "Checking RTC Sync..." << endl;
Serial << "Current Time: " << hour() << ":" << minute() << ":" << second() << endl;
second() << endl;
if (timeStatus() != timeSet) {
Serial << F("RTC Sync FAIL!") << endl;
Serial << F("RTC Sync OK!") << endl;
// Initialize MP3 player
Serial << F("Initializing MP3 player...") << endl;
mp3.initialize();
// Initialize stepper motors with settings for smooth movement
stepper1.setMaxSpeed(500.0);
stepper1.setAcceleration(100.0);
stepper1.setSpeed(100);
stepper1.moveTo(2038);
stepper2.setMaxSpeed(500.0);
stepper2.setAcceleration(100.0);
stepper2.setSpeed(100);
stepper2.moveTo(2038);
stepper3.setMaxSpeed(500.0);
stepper3.setAcceleration(100.0);
stepper3.setSpeed(100);
stepper3.moveTo(2038);
stepper4.setMaxSpeed(500.0);
stepper4.setAcceleration(100.0);
stepper4.setSpeed(100);
stepper4.moveTo(2038);
// Initialize HuskyLens
mySerial.begin(9600);
while (!huskylens.begin(mySerial)) {
Serial.println(F("Begin failed!"));
Serial.println(F("1. Please recheck the \"Protocol Type\" in HUSKYLENS (General Settings>>Protocol Type>>Serial 9600)"));
Serial.println(F("2. Please recheck the connection."));
delay(100);
Serial.println(F("HuskyLens initialized successfully"));
Serial << F("Set alarm times for each motor. Enter time in hh:mm:ss format.") << endl;
static time_t lastPrintTime;
time_t currentTime = now();
// Print the current time once per second
if (currentTime != lastPrintTime) {
lastPrintTime = currentTime;
printDateTime(currentTime);
Serial << endl;
// Check if alarm time matches current time for each motor
if (alarmSet1 && checkAlarm(currentTime, alarmTime1)) {
alarmSet1 = false; // Disable alarm after triggering
triggerAlarm(1);
if (alarmSet2 && checkAlarm(currentTime, alarmTime2)) {
alarmSet2 = false;
triggerAlarm(2);
if (alarmSet3 && checkAlarm(currentTime, alarmTime3)) {
alarmSet3 = false;
triggerAlarm(3);
if (alarmSet4 && checkAlarm(currentTime, alarmTime4)) {
alarmSet4 = false;
triggerAlarm(4);
// Check for user input to set the alarm for each motor
if (Serial.available() >= 8) {
int hour = Serial.parseInt();
int minute = Serial.parseInt();
int second = Serial.parseInt();
int motorNumber = Serial.parseInt(); // Motor number input (1-4)
// Check if motor number is valid
if (motorNumber >= 1 && motorNumber <= 4) {
Serial << "Received Alarm Input: " << hour << ":" << minute << ":" << second << " for Motor " << motorNumber << endl;
if (hour >= 0 && hour < 24 && minute >= 0 && minute < 60 && second >= 0 && second < 60) {
if (motorNumber == 1) {
alarmTime1.Hour = hour;
alarmTime1.Minute = minute;
alarmTime1.Second = second;
alarmSet1 = true;
Serial << F("Alarm set for Motor 1: ");
printTime(makeTime(alarmTime1));
} else if (motorNumber == 2) {
alarmTime2.Hour = hour;
alarmTime2.Minute = minute;
alarmTime2.Second = second;
alarmSet2 = true;
Serial << F("Alarm set for Motor 2: ");
printTime(makeTime(alarmTime2));
} else if (motorNumber == 3) {
alarmTime3.Hour = hour;
alarmTime3.Minute = minute;
alarmTime3.Second = second;
alarmSet3 = true;
Serial << F("Alarm set for Motor 3: ");
printTime(makeTime(alarmTime3));
} else if (motorNumber == 4) {
alarmTime4.Hour = hour;
alarmTime4.Minute = minute;
alarmTime4.Second = second;
alarmSet4 = true;
Serial << F("Alarm set for Motor 4: ");
printTime(makeTime(alarmTime4));
Serial << endl;
Serial << F("Invalid time format! Use hh:mm:ss.") << endl;
Serial << F("Invalid motor number! Enter a number between 1 and 4.") << endl;
// Clear input buffer
while (Serial.available() > 0) Serial.read();
// Only move motors if the alarm has been triggered for that motor
if (motor1Triggered) stepper1.run();
if (motor2Triggered) stepper2.run();
if (motor3Triggered) stepper3.run();
if (motor4Triggered) stepper4.run();
// HuskyLens Detection:
if (!huskylens.request()) {
Serial.println(F("Fail to request data from HUSKYLENS, recheck the connection!"));
} else if (!huskylens.isLearned()) {
Serial.println(F("Nothing learned, press learn button on HUSKYLENS to learn one!"));
} else if (!huskylens.available()) {
//Serial.println(F("No block or arrow appears on the screen!"));
while (huskylens.available()) {
HUSKYLENSResult result = huskylens.read();
//printResult(result);
// Trigger stepper motor based on detected object ID (ID = 1)
if (result.command == COMMAND_RETURN_BLOCK) {
if (result.ID == 1) {
// Face with ID=1 detected, start motor
if (motor1Triggered) {stepper1.run();}
if (motor2Triggered) {stepper2.run();}
if (motor3Triggered) {stepper3.run();}
if (motor4Triggered) {stepper4.run();}
delay(50);
// Check if the current time matches the alarm time for each motor
bool checkAlarm(time_t currentTime, tmElements_t alarmTime) {
return (hour(currentTime) == alarmTime.Hour &&
minute(currentTime) == alarmTime.Minute &&
second(currentTime) == alarmTime.Second);
// Trigger the alarm for the respective motor
void triggerAlarm(int motorNumber) {
Serial << F("Alarm triggered for Motor ") << motorNumber << "!" << endl;
digitalWrite(LED_PIN, HIGH);
Serial << "Triggering MP3 alarm for Motor " << motorNumber << "..." << endl;
mp3.playTrackNumber(2, 25); // Play corresponding track for each motor (1-4)
delay(1000); // Increased Delay.
unsigned long startTime = millis();
while (!mp3.playCompleted() && millis() - startTime < 5000) {
digitalWrite(LED_PIN, !digitalRead(LED_PIN)); // Blink LED
Serial.println("MP3 is playing..."); // Debugging output
Serial.print("MP3 playback completed: ");
Serial.println(mp3.playCompleted());
digitalWrite(LED_PIN, LOW);
if (motorNumber == 1) motor1Triggered = true;
if (motorNumber == 2) motor2Triggered = true;
if (motorNumber == 3) motor3Triggered = true;
if (motorNumber == 4) motor4Triggered = true;
Serial << F("Motor ") << motorNumber << F(" is now moving.") << endl;
// Print date and time to Serial
void printDateTime(time_t t) {
printDate(t);
Serial << ' ';
printTime(t);
// Print time to Serial
void printTime(time_t t) {
Serial << hour(t) << ':' << minute(t) << ':' << second(t);
// Print date to Serial
void printDate(time_t t) {
Serial << day(t) << '/' << month(t) << '/' << year(t);
void printResult(HUSKYLENSResult result) {
Serial.print(F("Block Detected: "));
Serial.print(F("xCenter="));
Serial.print(result.xCenter);
Serial.print(F(", yCenter="));
Serial.print(result.yCenter);
Serial.print(F(", width="));
Serial.print(result.width);
Serial.print(F(", height="));
Serial.print(result.height);
Serial.print(F(", ID="));
Serial.println(result.ID);
} else if (result.command == COMMAND_RETURN_ARROW) {
Serial.print(F("Arrow Detected: "));
Serial.print(F("xOrigin="));
Serial.print(result.xOrigin);
Serial.print(F(", yOrigin="));
Serial.print(result.yOrigin);
Serial.print(F(", xTarget="));
Serial.print(result.xTarget);
Serial.print(F(", yTarget="));
Serial.print(result.yTarget);
Serial.println(F("Unknown object detected!"));
