just bought the above display and seem to have an issue with using tft.fillScreen(TFT_BLACK)see pic, all other colours work fine with this function. Is this a duff display or have I overlooked something?
Its white at one end and then goes to striped grey at the other, yes all the other colours work fine everywhere and I have download the correct library and installed it.
TFT_BLACK, TFT_WHITE, TFT_GRAY, TFT_RED, ... are all regular colours.
If there are any problems with Scan settings, Power, VCOM, Gamma, ... they would be visible with all colours.
If you can post a readable photo of your screen, a reader might identify a problem.
On a day like today that's as good as I can get it. Doesn't seem to want to display anything using UTFT. The second pic is of it running the meter demo from the example library which looks pretty much perfect
So, no ideas anyone? I've found a work-around, if I redefine the value of TFT_BLACK to 0x0001 rather than 0x000 it works perfectly! which is good enough for me.
I suspect your board has a fault which means that at least one (probably all) of the 8 bit buffers on the back of the board is/are not getting any power from the power supply pin. When you send black, all data lines are at logic zero and the buffer eventually runs out of power as the decoupling capacitor gets depleted. The strobe line will be toggling with a 50% duty cycle so does not provide enough power.
When you set one of the colour bits high, this poor data pin has to provide enough current to keep the buffer circuit alive and the decoupling sufficienty charged.
Check you do not have a bent pin going into the Arduino board, check the solder joints on the board, it is probably a bad joint somewhere in the power feed connections to the buffers.
Arduino boards are quite tolerant of overloads on the data pins but the situation is stressing the processor chip.
Thank you gentlemen, as far as I can I'll check the board over, strangely enough it's behaving itself today, so it's an intermittent fault. Bearing in mind the cost of these displays (£6 this was on ebay from china) it's irritating but hardly worth the effort in a trying to repair it or claim a replacement. You have confirmed what I was beginning to think that it was indeed faulty and not a software issue. I have also noticed that this screen is not as bright as my previous screen.
