HX711 config to 80Hz sampling
Hey All,
I am using a HX711 to read data from a load cell on an Arduino Nano. Specifically I am using the XFW-HX711 unit.
This unit has a zero ohm resistor that you apparently replace on board to take you from 10Hz to 80Hz (as per this topic conversation - How to get 80hz with HX711? - #8 by chapellane)
I have done that, and now when I read from the Arduino I seem to be getting a much higher sampling rate. But once I connect my HX711 to 5V power it goes back to ~10Hz.
I am so confused, not sure what is going wrong, the code seems to work and output at a higher sampling frequency when nothing is connected but when I power the load cell with 5V through VCC everything goes back to slow sampling frequency.
I am using this library GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales.
Please help!!
Best,
F
Are you sure the resistor is properly soldered and there are no shorts.
If you have a DMM/voltmeter you should see +5V on both sides of the resistor.
Also, please post your code using Copy For Forum in the IDE
I tried the DMM, I can't read 5V on the resistors, (even with a new unmodified HX711). It does buzz on the continuity test though, but it doesn't buzz for the 80HZ modified one.
This is the code.
#include <Arduino.h>
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 2;
const int LOADCELL_SCK_PIN = 3;
//const int LOADCELL2_DOUT_PIN = 26;
//const int LOADCELL2_SCK_PIN = 27;
//const int LOADCELL3_DOUT_PIN = 26;
//const int LOADCELL3_SCK_PIN = 27;
HX711 scale;
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());      // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight (not set yet)
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(5), 1);  // print the average of 5 readings from the ADC minus tare weight (not set) divided
            // by the SCALE parameter (not set yet)
  //scale.set_scale(1941.446); //for Z force
  scale.set_scale(1952.604);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
  Serial.print("one reading:\t");
  Serial.print(scale.get_units(1), 1);
  Serial.print("\t| average:\t");
  Serial.println(millis());
  //Serial.println(scale.get_units(10), 5);
  //delay(100);
With 5V connected to Vcc, the unmodified one should read 0 volts. With the resistor moved to the 80Hz position, it should read +5V on both sides of the resistor, if not, then it is not soldered correctly.
It won't buzz in the 80Hz position but that doesn't tell you if it is connected to 5V or not.
Do you read 5V on the Vcc connection?
