I am having problems with my robot not seeing the white lines on the Mini-sumo arena
#include <xmotion.h>
int LeftSensor = 1; // Opponent Sensors D1, D2, D4, A4, A5
int LefttDiagonalSensor = 2;
int MiddleSensor = 4;
int RightDiagonalSensor = A4;
int RightSensor = A5;
int LeftLineSensor = 0; // Line Sensors D0 & A1
int RightLineSensor = A1;
int Remember=5; // Remember Variable (NOT PIN NUMBER!)
int led1 = 8; // User Led D8
//// //dipswitchler//
int switch1 = 5; // Dipswitches (D5, D6, D7)
int switch2 = 6;
int switch3 = 7;
int start = 10; // Microstart Input D10
xmotion.StopMotors(100);
xmotion.ToggleLeds(100);
pinMode(LeftSensor, INPUT);
pinMode(LefttDiagonalSensor, INPUT);
pinMode(MiddleSensor, INPUT);
pinMode(RightDiagonalSensor, INPUT);
pinMode(RightSensor, INPUT);
pinMode(RightLineSensor, INPUT);
pinMode(LeftLineSensor, INPUT);
pinMode(switch1, INPUT);
pinMode(switch2, INPUT);
pinMode(switch3, INPUT);
digitalWrite(switch1, HIGH);
digitalWrite(switch2, HIGH);
digitalWrite(switch3, HIGH);
digitalWrite(LefttDiagonalSensor, HIGH);
digitalWrite(MiddleSensor, HIGH);
digitalWrite(RightDiagonalSensor, HIGH);
Serial.begin(3600);
void NoSensorRead() {
while (digitalRead(start) == 1)
if (digitalRead(MiddleSensor) == 1)
xmotion.Forward(100, 1);
Remember = 0;
} else if (digitalRead(LeftSensor) == 1)     {
  xmotion.Left0(50, 1);
   Remember = 2;
} else if (digitalRead(RightSensor) == 1)
  xmotion.Right0(50, 1);
   Remember = 1;
else if (digitalRead(LefttDiagonalSensor) == 1)    {
   xmotion.ArcTurn(10, 70, 1);
   Remember = 2;
else if (digitalRead(RightDiagonalSensor) == 1)
   xmotion.ArcTurn(70, 10, 1);
   Remember = 1;
else if (digitalRead(LeftLineSensor) == 0 && digitalRead(RightLineSensor) == 1)
xmotion.Backward(80, 20);
xmotion.Right0(50, 30);
else if (digitalRead(RightLineSensor) == 0 && digitalRead(LeftLineSensor) == 1)
xmotion.Left0(50, 30);
else if (digitalRead(RightLineSensor) == 0 && digitalRead(LeftLineSensor) == 0) // Both Line Sensor See Line.
   xmotion.Backward(80, 50);
    xmotion.Left0(50, 80);
 *  OPEN This Section for Moving Robot Otherwise it will only work
 *  When opponent seen.
 *  else if (Remember == 0)
   xmotion.Forward(100,1);
else if (Remember == 1)
else if (Remember == 2)
else if (digitalRead(RightSensor) == 0 || digitalRead(RightDiagonalSensor) == 0 || digitalRead(MiddleSensor) == 0 || digitalRead(LefttDiagonalSensor) == 0 || digitalRead(LeftSensor) == 0)
  xmotion.StopMotors(1);
while (digitalRead(start) == 0)
/* DEBUG Section
Serial.print(digitalRead(LeftSensor));
Serial.print(digitalRead(LefttDiagonalSensor));
Serial.print(digitalRead(MiddleSensor));
Serial.print(digitalRead(RightDiagonalSensor));
Serial.println(digitalRead(RightSensor));
delay(100);
// TACTICS
if (digitalRead(switch1) == 0 && digitalRead(switch2) == 1 && digitalRead(switch3) == 1)  // Turn Left & Wait
 xmotion.Left0(80,60);
 else if (digitalRead(switch1) == 1 && digitalRead(switch2) == 0 && digitalRead(switch3) == 1)// Forward Attack
    xmotion.Forward(100,50);
     xmotion.StopMotors(10);
  else if (digitalRead(switch1) == 1 && digitalRead(switch2) == 1 && digitalRead(switch3) == 0)  //Turn Right
    xmotion.Right0(80,60);
   //xmotion.Forward(100,50);
 else if (digitalRead(switch1) == 0 && digitalRead(switch2) == 0 && digitalRead(switch3) == 1) // Left Zigzag
 xmotion.Left0(80,40);
  xmotion.Forward(80,50);
        xmotion.StopMotors(20);
 xmotion.Right0(80,70);
 xmotion.Forward(100,40);
 else if (digitalRead(switch1) == 0 && digitalRead(switch2) == 1 && digitalRead(switch3) == 0) // 180 degree U Turn
  xmotion.Right0(100,80);
 else if (digitalRead(switch1) == 1 && digitalRead(switch2) == 0 && digitalRead(switch3) == 0) // Right Zigzag
   xmotion.Right0(80,40);
  xmotion.Forward(100,60);
 xmotion.Left0(80,110);
  else if (digitalRead(switch1) == 0 && digitalRead(switch2) == 0 && digitalRead(switch3) == 0) // Right Arc Turn
{ xmotion.ArcTurn(40,90,120);
    xmotion.Backward(100,2);
   xmotion.Backward(100,1);
  else if (digitalRead(switch1) == 1 && digitalRead(switch2) == 1 && digitalRead(switch3) == 1) // Left Arc Turn
 xmotion.ArcTurn(90,40,120);
 NoSensorRead();
Edit post#1 and put code in code tags, please.
Post schematic. Post images of the project.
Describe what be the sensors? Are they line follower sensors attuned to a color? Are they some Infared led blasting light onto the roadbed? What be the sensors?
Don't delete your post again, please. I had 2 paragraphs of what the variable Remember is and that all went to poo! when you deleted the other post.
Try here
sorry I made an another post containing images.Also I didnt delete anything maybe mods did
Line sensors are allerted when they see sth other than black,sensors are ML1
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Cross posting is against the rules.
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
