I wanted to build a wall climbing robot for our third challenge "The robot wall race" and it ended up with an awsemoe fast rc racing car that is so much fun to steer. I would like to share it with you.
This video will guide you through the design, assembly and function of Sonic: The wall racing robot:
This robot is unbelievably fun to steer and simple to build. All Stl. files, partlist...etc are available for free. You can build it yourself and try it out .
Nope... but the category is Robotics where you can discuss "Platforms, motors, algorithms and sensors to conform robotics projects"
so let's say it's a motor and RC showcase
(hence @Budvar10 or my comment about adding some intelligence to call that a robot - which could become an interesting project = add a distance detection sensor (ToF) sensor below the "robot" and use PID to constrain the propeller so that the "robot" sticks to ground and does not start flying around)
Well i really didn't want to disturbe anyone in this forum by posting this. i thought it might be interessting although it has no arduino anymore on board. it started with one though
i already had a version with an arduino, an mpu6050 to control the angle of the propeller and a couple of mini dc motors to be able to go from ground to wall without any external help. but unfortunatelly it was too heavy, so i had to drop a lot of stuff to keep it light. So it started actually as an arduino project and it might end up in one as well in the further development.
@jim-p DXF files are 2D. Im afraid they won't help you printing the parts. but i could provide you with stl or step files.
no not really to be honest. I had to print a lot of parts to reach a reasonable weight and stabilty. Once you have the stl. files all you need is to print and connect the brushless motor controller and servo to an rc reveiver and you are ready to go. If you have any specific problems, you can write here and i will help.
