Hello! I want to upload a simple sketch into Attiny13a. I've read a lot of instructions available online. But still it doesn't work.
First I've burnt a boot loader using an Arduino Nano as ISP. After uploading a sketch into Arduino, I 've chosen Programmer Arduino as ISP and hardware library by Microcore. (check the attachments). It shows an error but it seems it burns fuses but maybe I'm wrong. Here is what I’ve got:
/Users/antonz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/antonz/Library/Arduino15/packages/MicroCore/hardware/avr/1.0.3/avrdude.conf -v -pattiny13 -carduino -B32 -P/dev/cu.usbserial-A9WVN9HP -b19200 -e -Ulock:w:0x3f:m -Uhfuse:w:0xf9:m -Ulfuse:w:0x38:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/antonz/Library/Arduino15/packages/MicroCore/hardware/avr/1.0.3/avrdude.conf"
User configuration file is "/Users/antonz/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-A9WVN9HP
Using Programmer : arduino
Overriding Baud Rate : 19200
Setting bit clk period : 32.0
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATtiny13
Chip Erase delay : 4000 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 64 4 0 4000 4000 0xff 0xff
flash 65 6 32 0 yes 1024 32 32 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
Programmer Type : Arduino
Description : Arduino
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 425479
Firmware Version: 16798724.-1443917992
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
Then I tried to upload a sketch using a programmer. And here is what I’ve got:
Users/antonz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/Users/antonz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -pattiny13 -carduino -P/dev/cu.usbserial-A9WVN9HP -b19200 -Uflash:w:/var/folders/9y/qqlxtc0501l1dxlm2y4wh9l80000gn/T/arduino_build_548641/Blink182.ino.hex:i
System wide configuration file is "/Users/antonz/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
AVR Part : ATtiny13
PAGEL : P00
BS2 : P00
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Firmware Version: 33559044.-1443917992
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
this check.
the selected serial port
does not exist or your board is not connected
And it doesn’t work.
I’ve tried also DIY Attiny, Attiny13 and Arduino Tiny libraries, but it doesn’t work.
I’ve also bought a programmer like this
But when I try to upload a sketch it asks to connect a board in 60 sec. I connect it and nothing happens. I use OSX.
Here is my simple sketch:
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(3,OUTPUT);
// the loop function runs over and over again forever
digitalWrite(3, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(3, LOW); // turn the LED off by making the voltage LOW
