I have 12-24v sensors.
Hello,
I have 12-24v sensors, as I know i can't put them to digitals.
How can i use these sensors to arduino board?
Should i have to buy something like a to convert 24v to 5v?
Any ideas?
Thanks.
You can reduce 24v signals to 5v signals by using two resistors as a voltage divider. You want to divide the voltage by about 5 so you need two resistors of value x and about 4x. The input pin is connected to ground through the 'x' resistor and the sensor is connected to the input pin through the '4x' resistor. The standard 10% resistor values of 1.2k and 4.7k will work and give an output voltage around 4.9v.
Thanks for information.
From where i can get these resistors, maybe you can include any link to buy ?
Thanks for your reply :slight_smile:
control123:
Hello,
Any ideas?
Thanks.
Can you provide a link to your specific sensors? There is just too much room for misidentifying what you actually might have to give good feedback.
Lefty
control123:
You can order them from DigiKey.com if you don't have any electronics parts stores like Radio Shack near you:
1.2k
4.7k
