Hi i try to upload a simple code on my arduino nano and the Create show me the error from bellow image.
Pic from above
This is the example I mean.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
delay(1); // delay in between reads for stability
Notice how it reads the port into variable first.
