i have problem with the code for the second ultrasonic sensor
Hi i make this code to show the level at the display from two water tanks
the first one work great, but the second not show anything
this is my code
  lcd.begin(16,2);
  lcd.print("   AQUA LEVEL ");
  lcd.createChar(0, symbol);
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  delay(3000);       // Show application name for 3 seconds.
It might
be useful
to set the
pin mode
for the other
set of
pins.
And stop with all the stupid blank lines in your code.
i make it like this and still not have anything blank guy :cold_sweat:
  lcd.begin(16,2);
  pinMode(ECHO_PIN2, INPUT);
  pinMode(TRIG_PIN2, OUTPUT);
you had a few errors ion there...
#include <LiquidCrystal.h>
#define ECHOPIN 3                            // Pin to receive echo pulse
#define TRIGPIN 4                            // Pin to send trigger pulse
#define ECHO_PIN2 2                            // Pin to receive echo pulse2
#define TRIG_PIN2 5                            // Pin to send trigger pulse2
#define STATUSPIN 13                        // Use for troubleshooting
int highWater = 24;        // These values allow to calculate % of full
int lowWater = 100;        // SRF04 hangs above water (lower distance = more water)
byte symbol[8] = {         // Custom character for LCD display
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);    // Assign pins
void flashLed(int pin, int times, int wait)
  for (int i = 0; i < times; i++) {
    digitalWrite(pin, HIGH);
    delay(wait);
    digitalWrite(pin, LOW);
    if (i + 1 < times) {
      delay(wait);
  lcd.begin(16,2);
  pinMode(ECHO_PIN2, INPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  pinMode(TRIG_PIN2, OUTPUT);//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  digitalWrite(TRIGPIN, LOW);                   // Set the trigger pin to low for 2uS
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);                  // Send a 10uS high to trigger ranging
  delayMicroseconds(10);
  digitalWrite(TRIGPIN, LOW);                   // Send pin low again
  int distance = pulseIn(ECHOPIN, HIGH);        // Read in times pulse
  distance= distance/65;                        // divide by 58 gives cm.
  digitalWrite(TRIG_PIN2, LOW);                   // Set the trigger pin to low for 2uS
  digitalWrite(TRIG_PIN2, HIGH);                  // Send a 10uS high to trigger ranging
  digitalWrite(TRIG_PIN2, LOW);                   // Send pin low again
  int distance2 = pulseIn(ECHO_PIN2, HIGH);        // Read in times pulse
  distance2= distance2/58;                        // divide by 58 gives cm.
  int scaledValue = map(constrain(distance, highWater, lowWater), lowWater, highWater, 0, 11);
  lcd.clear();
  lcd.print("E    |    F    1");
  lcd.setCursor(0,1);
  while (scaledValue > 0)
    lcd.print((char)0);
    scaledValue--;
  //delay(3000);  // Wait 2 seconds before printing the 2nd value.//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  int scaledValue2 = map(constrain(distance2, highWater, lowWater), lowWater, highWater, 0, 11); //<<<<<<<<note distance2
  lcd.clear();
  lcd.print("E    |    F    2");
  lcd.setCursor(0,1);
  while (scaledValue2 > 0) //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    lcd.print((char)0);
    scaledValue2--;//<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
  delay(3000);  // Wait 2 seconds before measuring again. We're in no hurry!
sure there is something wrong but where ?!
for the first part, i think there is nothing wrong
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
the second one i don't know where exactly
i corrected it tin the code I posted...
i test it, it shows the tank 2 only and not read anything !!
post your latest code, buddy
i change it to this and now the tank 2 shows full !! i not use it in the tank right now, so the sensor not detect anything
#define ECHO_PIN2 5                            // Pin to receive echo pulse2
#define TRIG_PIN2 6                            // Pin to send trigger pulse2
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
// Utility function for flashing STATUSPIN
void flashLed(int pin, int times, int wait) {
    delay(wait);
      delay(wait);
  lcd.begin(16,2);
 // Measure distance
// Measure distance 2
 // Convert measured value1 to value between 0-11, to display on LCD
  // Use Arduino built-in map and constrain functions
  lcd.clear();
  lcd.setCursor(0,1);
  while (scaledValue > 0) {
     lcd.print((char)0);
     scaledValue--;
  // Convert measured value2 to value between 0-11, to display on LCD
  lcd.clear();
  lcd.setCursor(0,1);
  while (scaledValue2 > 0) {
     lcd.print((char)0);
     scaledValue2--;
Which?
Code or comment?
Maybe put in some serial prints and lose some blank lines.
lol nic one :slight_smile: i am not that good in coding so i make blank lines to be more easy for me =(
there is alot of errors in my code, i solve it all
but i have problem now i have two water tank, so i must see first level from the first ultrasonic sensor, then delay 3000 and shows the second level
the first sensor work fine, the second one not show anything,
i change the code and now the first sensor gives the level for the two tanks !!
what about the other one !!
i am trying this from 4 days, and i try everything i know,
look at me :astonished: i am the captain now :smiley:
#define ECHO_PIN2 6                            // Pin to receive echo pulse2
  B00000,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B00000,
    delay(wait);
      delay(wait);
  lcd.begin(16,2);
 // Measure distance
  lcd.clear();
  lcd.setCursor(0,1);
     lcd.print((char)0);
     scaledValue--;
  int scaledValue2 = map(constrain(distance, highWater, lowWater), lowWater, highWater, 0, 11);
  lcd.clear();
  lcd.setCursor(0,1);
     lcd.print((char)0);
     scaledValue2--;
Should that be distance2?
~~ ~~int scaledValue2 = map(constrain(distance2, highWater, lowWater), lowWater, highWater, 0, 11);~~ ~~
i try that two, and not show anything ! from the second ultrasonic sensor
oh wow :astonished: i was try that and not work !!! why it works now i dont know :astonished:
thanks alooooooooooooot <3 :stuck_out_tongue:
