First of all, all credit goes to Boris Landoni for coming up with this project. It can be found Here: Water Tank level display with Arduino - Open Electronics - Open Electronics.
Ok, the ultrasonic sensor "measures" the water level, and if it does not meet a certain threshold, a buzzer goes off. If it does not meet another threshold, the buzzing gets louder. Also, it will display the level on a 16X2 LCD screen. However, this error that I am getting may be unrelated to this, but I would still like an anwser.
Here's the code:
/* -*- mode: c -*- */
* pozzo.pde
* version: 1.2
#include <LiquidCrystal.h>
#define PING_PIN 13
#define BUZZER_PIN 8
#define SWITCH_INT 0 /* 0 => pin 2 */
#define PI 3.1415926535898
#define SUPERFICE_BASE (R_POZZO * R_POZZO * PI)
#define SIZE_BAR (16 * 5)
#define ALARM_ICON 0 /* code */
#define SOUND_ICON 6 /* code */
#define SOUND_ICON_ON 7 /* code */
#define R_POZZO 0.5 /* raggio pozzo (m) */
#define H_POZZO 146.0 /* cm */
#define SOGLIA_ALLARME_1 100 /* cm */
#define SOGLIA_ALLARME_2 120 /* cm */
#define DELAY_0 60000 /* ms; 1000 * 60 * 1 = 1 min */
#define DELAY_1 600 /* ms */
#define DELAY_2 200 /* ms */
/* initialize the library with the numbers of the interface pins */
LiquidCrystal lcd(12, 11, 5, 4, 3, 6);
int mute = 0;
byte *getChar(int n, byte newChar[]) {
int i;
byte code[5] = {
B10000,
B11000,
B11100,
B11110,
B11111};
for (i = 0; i < 8; i++)
newChar[i] = code[n - 1];
return newChar;
int i;
float h;
byte newChar[8];
/* set up the LCD's number of rows and columns: */
lcd.begin(16, 2);
for (i = 1; i < 6; i++)
lcd.createChar(i, getChar(i, newChar));
newChar = {
B00000,
B00100,
B01010,
B01010,
B11111,
B00100,
B00000,
lcd.createChar(ALARM_ICON, newChar);
newChar = {
B00011,
B00101,
B11001,
B11001,
B11001,
B00101,
B00011,
lcd.createChar(SOUND_ICON, newChar);
newChar = {
B00100,
B10010,
B01001,
B01001,
B01001,
B10010,
B00100,
lcd.createChar(SOUND_ICON_ON, newChar);
pinMode(BUZZER_PIN, OUTPUT);
* LOW to trigger the interrupt whenever the pin is low,
* CHANGE to trigger the interrupt whenever the pin changes value
* RISING to trigger when the pin goes from low to high,
* FALLING for when the pin goes from high to low.
attachInterrupt(SWITCH_INT, button, RISING);
/* initialize serial communication */
long hWatherCm;
int litres;
hWatherCm = read_height();
if (check_alarm(hWatherCm) != 0) /* read again wather height */
lcd.clear();
print_histogram(hWatherCm);
lcd.setCursor(0, 1);
lcd.print(hWatherCm);
lcd.print(" cm - ");
// litres = SUPERFICE_BASE * (hWather / 100.0) * 1000
litres = floor(SUPERFICE_BASE * hWatherCm * 10);
lcd.print(litres);
lcd.print(" l ");
lcd.setCursor(14, 1);
lcd.write(SOUND_ICON);
lcd.setCursor(15, 1);
if (!mute)
lcd.write(SOUND_ICON_ON);
lcd.write('X');
Serial.print("cm = ");
Serial.println(hWatherCm);
switch (check_alarm(hWatherCm)) {
case 1:
lcd.setCursor(0, 0);
lcd.write(ALARM_ICON);
buzz(200);
delay(DELAY_1);
case 2:
buzz(200);
delay(200);
buzz(200);
delay(DELAY_2);
case 0: // no alarm
delay(DELAY_0);
void print_histogram(int hWatherCm) {
int i;
int bloks;
float histogram;
// hWatherCm : HPOZZO = histogram : SIZE_BAR
histogram = (SIZE_BAR * hWatherCm) / H_POZZO;
histogram = histogram + 0.5;
bloks = (int)histogram / 5;
for (i = 0; i < bloks; i++)
lcd.write(5);
if ((int)(histogram) % 5 > 0)
lcd.write((int)(histogram) % 5);
long read_height() {
* establish variables for duration of the ping,
* and the distance result in centimeters:
long duration, hWatherCm;
* The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
* Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(PING_PIN, OUTPUT);
digitalWrite(PING_PIN, LOW);
delayMicroseconds(2);
digitalWrite(PING_PIN, HIGH);
delayMicroseconds(5);
* The same pin is used to read the signal from the PING))): a HIGH
* pulse whose duration is the time (in microseconds) from the sending
* of the ping to the reception of its echo off of an object.
pinMode(PING_PIN, INPUT);
duration = pulseIn(PING_PIN, HIGH);
/* convert the time into a distance */
hWatherCm = H_POZZO - microseconds_to_centimeters(duration);
if (hWatherCm < 0)
return 0;
if (hWatherCm > H_POZZO)
return H_POZZO;
return hWatherCm;
void buzz(int msec) {
if (!mute)
digitalWrite(BUZZER_PIN, HIGH);
delay(msec);
digitalWrite(BUZZER_PIN, LOW);
int check_alarm(int hWatherCm) {
if (hWatherCm > SOGLIA_ALLARME_1) {
if (hWatherCm < SOGLIA_ALLARME_2)
return 1;
return 2;
return 0;
long microseconds_to_centimeters(long microseconds) {
* The speed of sound is 340.29 m/s or 29.4 microseconds per centimeter.
* The ping travels out and back, so to find the distance of the
* object we take half of the distance travelled.
return microseconds / 29.387 / 2;
void button() {
// Serial.println("Pulsante premuto");
mute = !mute;
if (!mute)
lcd.write('X');
Here is the error message:
sketch_mar13a.ino: In function 'void setup()':
sketch_mar13a:58: error: expected primary-expression before '{' token
sketch_mar13a:58: error: expected `;' before '{' token
sketch_mar13a:70: error: expected primary-expression before '{' token
sketch_mar13a:70: error: expected `;' before '{' token
sketch_mar13a:82: error: expected primary-expression before '{' token
sketch_mar13a:82: error: expected `;' before '{' token
sketch_mar13a.ino: In function 'void loop()':
sketch_mar13a:146: error: call of overloaded 'write(int)' is ambiguous
C:\arduino-1.0.3-windows\arduino-1.0.3\libraries\LiquidCrystal/LiquidCrystal.h:82: note: candidates are: virtual size_t LiquidCrystal::write(uint8_t)
C:\arduino-1.0.3-windows\arduino-1.0.3\hardware\arduino\cores\arduino/Print.h:49: note: size_t Print::write(const char*)
sketch_mar13a:154: error: call of overloaded 'write(int)' is ambiguous
I want to find out what these errors are requiring me to do in order to make this work. I have tried the following:
- Change newChar to byte
- Change newChar to createChar
- Adding "tokens" where the error report reports an error (such as ; or () or {})
Any help would be very appreciated, and thanks in advance.
LinktheInventor
