I need help for RAM optimization
Hello everyone, I just finished the code I needed to do for a school project, everything works very well except for one thing, when i try to save the GPS values in the SD Card, it saves only a portion of it, not everything, I need help, I think it is a RAM problem because when I try to print in the file "lalalalalallalalallalalalallalalallalalalllallalalall..." it just doesn't print anything. Please help me I need the project to be done this week and it is only the last thing I am missing.
This is my code :
#include <SoftwareSerial.h>
#include <Wire.h>
#include <RTClib.h>
#include <forcedClimate.h>
#include <ChainableLED.h>
#include <SdFat.h>
#include <EEPROM.h>
#define MODE_STANDARD 1
#define MODE_MAINTENANCE 2
#define MODE_ECO 3
#define MODE_CONFIGURATION 4
#define PIN_BOUTON_VERT 2
#define PIN_BOUTON_ROUGE 3
#define PIN_LUMIN A3
#define PIN_SD 4
#define TAILLE_TABLEAU 15
SdFat SD;
RTC_DS1307 rtc;
ForcedClimate climateSensor = ForcedClimate();
ChainableLED leds(8, 9, 1);
SoftwareSerial SoftSerial(6, 7);
int mode_actu = 0;
int mode_prec;
bool EtatBoutonVert = false;
unsigned long TempsBoutonVert;
bool EtatBoutonRouge = false;
unsigned long TempsBoutonRouge;
unsigned long TempsInactif;
int adresse = 0;
bool etatGPS = true;
unsigned long start_maintenance = 0;
String NomDossier;
int JourActuel;
const int ParametresDefault[TAILLE_TABLEAU] =
        10,   // LOG_INTERVAL,
        2048, // FILE_MAX_SIZE,
        30,   // TIMEOUT,
        1,    // LUMIN,
        255,  // LUMIN_LOW,
        768,  // LUMIN_HIGH,
        1,    // TEMP_AIR,
        -10,  // MIN_TEMP_AIR,
        60,   // MAX_TEMP_AIR,
        1,    // HYGR,
        0,    // HYGR_MINT,
        50,   // HYGR_MAXT,
        1,    // PRESSURE
        850,  // PRESSURE_MIN
        1080  // PRESSURE_MAX
int ParametresConfig[TAILLE_TABLEAU] =
        30,   // TIMEOUT,
        1,    // LUMIN,
        255,  // LUMIN_LOW,
        768,  // LUMIN_HIGH,
        1,    // TEMP_AIR,
        1,    // HYGR,
        0,    // HYGR_MINT,
        50,   // HYGR_MAXT,
        1,    // PRESSURE
#define LOG_INTERVAL_INDEX 0
#define FILE_MAX_SIZE_INDEX 1
#define TIMEOUT_INDEX 2
#define LUMIN_INDEX 3
#define LUMIN_LOW_INDEX 4
#define LUMIN_HIGH_INDEX 5
#define TEMP_AIR_INDEX 6
#define MIN_TEMP_AIR_INDEX 7
#define MAX_TEMP_AIR_INDEX 8
#define HYGR_INDEX 9
#define HYGR_MINT_INDEX 10
#define HYGR_MAXT_INDEX 11
#define PRESSURE_INDEX 12
#define PRESSURE_MIN_INDEX 13
#define PRESSURE_MAX_INDEX 14
File32 Fichier;
unsigned long TempsDerniereMesure = 0;
int RevisionFichier = 1;
bool VerificationEEPROM = false;
long LOG_INTERVAL = ParametresConfig[LOG_INTERVAL_INDEX];
void BoutonRougeInterruption(void);
void BoutonVertInterruption(void);
void Mode_standard();
void Mode_Maintenance();
void Mode_economique();
void Mode_config();
void LEDMode();
void Enregistrement_SD();
void ChangerHorloge(int annee, int mois, int jour, int heure, int minute, int seconde);
void GenerationDonnees();
void DonneesGPS();
void connexionSD();
void erreur_acces_horloge();
void erreur_acces_GPS();
void erreur_acces_donnees_capteurs();
void erreur_donnees_incoherentes();
void erreur_carte_SD_pleine();
void erreur_acces_ecriture();
void ModificationConfig(int index);
void Affichage(String Donnees, bool ligne);
void PointVirgule();
void SeparateurHorloge();
void Creation();
void ClearMoniteurSerie();
void LireEEPROM(int ParametresConfig[TAILLE_TABLEAU]);
  SoftSerial.begin(9600);
  pinMode(PIN_BOUTON_VERT, INPUT);
  pinMode(PIN_BOUTON_ROUGE, INPUT);
  Wire.begin();
  leds.init();
  climateSensor.begin();
  connexionSD();
  Serial.println(F("Connexion à la carte SD réussie."));
  leds.setColorRGB(0, 255, 255, 255);
  while (!rtc.begin())
    Serial.println(F("Module RTC pas trouvé"));
  // rtc.adjust(DateTime((__DATE__), (__TIME__)));
  attachInterrupt(digitalPinToInterrupt(PIN_BOUTON_VERT), BoutonVertInterruption, CHANGE);
  attachInterrupt(digitalPinToInterrupt(PIN_BOUTON_ROUGE), BoutonRougeInterruption, CHANGE);
  LireEEPROM(ParametresConfig);
  for (int i = 0; i < TAILLE_TABLEAU; i++)
    if (ParametresConfig[i] != ParametresDefault[i])
      VerificationEEPROM = true;
  if (!VerificationEEPROM)
      EEPROM.put(i * sizeof(long), ParametresDefault[i]);
  if (digitalRead(PIN_BOUTON_ROUGE) == LOW)
    mode_actu = MODE_CONFIGURATION;
    mode_actu = MODE_STANDARD;
  DateTime Maintenant = rtc.now();
  JourActuel = Maintenant.day();
  TempsDerniereMesure = millis();
  switch (mode_actu)
  case MODE_STANDARD:
    Mode_standard();
  case MODE_MAINTENANCE:
    Mode_Maintenance();
  case MODE_ECO:
    Mode_economique();
  case MODE_CONFIGURATION:
    Mode_config();
  if ((digitalRead(PIN_BOUTON_VERT) == LOW) && (!EtatBoutonVert))
    EtatBoutonVert = true;
    TempsBoutonVert = millis();
  else if ((digitalRead(PIN_BOUTON_VERT) == HIGH) && (EtatBoutonVert))
    if ((millis() - TempsBoutonVert) >= (5000))
      if (mode_actu == MODE_STANDARD)
        mode_actu = MODE_ECO;
        LEDMode();
      else if (mode_actu == MODE_ECO)
        LEDMode();
  if ((digitalRead(PIN_BOUTON_ROUGE) == LOW) && (!EtatBoutonRouge))
    EtatBoutonRouge = true;
    TempsBoutonRouge = millis();
  else if (digitalRead(PIN_BOUTON_ROUGE) == HIGH && (EtatBoutonRouge))
    if ((millis() - TempsBoutonRouge) >= 5000)
      switch (mode_actu)
        LEDMode();
      case MODE_STANDARD:
      case MODE_ECO:
        mode_prec = mode_actu;
        mode_actu = MODE_MAINTENANCE;
        LEDMode();
        mode_actu = mode_prec;
        mode_prec = 0;
        switch (mode_actu)
        case MODE_STANDARD:
          LEDMode();
        case MODE_ECO:
          LEDMode();
  LEDMode();
  connexionSD();
  if ((millis() - TempsDerniereMesure) >= (1000)) //* 10000))// * 60000))
    LEDMode();
  LEDMode();
  if(millis() - start_maintenance < 10000)
    return;
  start_maintenance = millis();
  Creation();
  LEDMode();
  LEDMode();
  connexionSD();
  if ((millis() - TempsDerniereMesure) >= (LOG_INTERVAL)) //* 1200000))
    LEDMode();
void Mode_config()
  LEDMode();
  if ((millis() - TempsInactif) > (30 * 1000)) // A changer pour test soutenance (30 * 60000)
  Serial.println(F("Fin de la configuration. Retour au mode standard."));
  return;
    if (Serial.available() > 0)
      TempsInactif = millis();
      String commande = Serial.readStringUntil('\n');
      int IndexEgal = commande.indexOf('=');
      if(IndexEgal < 0)
        if (commande == F("RESET"))
          ParametresConfig[i] = ParametresDefault[i];
          EEPROM.put(i * sizeof(long), ParametresConfig[i]);
        Serial.println(F("Reset des paramètres effectué."));
      else if (commande == F("VERSION"))
        Serial.println(F("Version du programme : 1.0"));
        Serial.println(F("Numéro de lot : 1"));
      else if (commande == F("CLOCK_AUTO")){
        Serial.println(F("Clock ajustée en fonction de l'horloge du PC."));
      else{
        Serial.println(F("Commande inexistante."));
      return;
      String nomCommande = commande.substring(0, IndexEgal);
      long Valeur = commande.substring(IndexEgal + 1).toInt();
      if (nomCommande == F("LOG_INTERVAL"))
        ParametresConfig[LOG_INTERVAL_INDEX] = Valeur;
        ModificationConfig(LOG_INTERVAL_INDEX);
      else if (nomCommande == F("FILE_MAX_SIZE"))
        ParametresConfig[FILE_MAX_SIZE_INDEX] = Valeur;
        ModificationConfig(FILE_MAX_SIZE_INDEX);
      else if (nomCommande == F("TIMEOUT"))
        ParametresConfig[TIMEOUT_INDEX] = Valeur;
        ModificationConfig(TIMEOUT_INDEX);
      else if (nomCommande == F("LUMIN"))
        ParametresConfig[LUMIN_INDEX] = Valeur;
        ModificationConfig(LUMIN_INDEX);
      else if (nomCommande == F("LUMIN_LOW"))
        ParametresConfig[LUMIN_LOW_INDEX] = Valeur;
        ModificationConfig(LUMIN_LOW_INDEX);
      else if (nomCommande == F("LUMIN_HIGH"))
        ParametresConfig[LUMIN_HIGH_INDEX] = Valeur;
        ModificationConfig(LUMIN_HIGH_INDEX);
      else if (nomCommande == F("TEMP_AIR"))
        ParametresConfig[TEMP_AIR_INDEX] = Valeur;
        ModificationConfig(TEMP_AIR_INDEX);
      else if (nomCommande == F("MIN_TEMP_AIR"))
        ParametresConfig[MIN_TEMP_AIR_INDEX] = Valeur;
        ModificationConfig(MIN_TEMP_AIR_INDEX);
      else if (nomCommande == F("MAX_TEMP_AIR"))
        ParametresConfig[MAX_TEMP_AIR_INDEX] = Valeur;
        ModificationConfig(MAX_TEMP_AIR_INDEX);
      else if (nomCommande == F("HYGR"))
        ParametresConfig[HYGR_INDEX] = Valeur;
        ModificationConfig(HYGR_INDEX);
      else if (nomCommande == F("HYGR_MINT"))
        ParametresConfig[HYGR_MINT_INDEX] = Valeur;
        ModificationConfig(HYGR_MINT_INDEX);
      else if (nomCommande == F("HYGR_MAXT"))
        ParametresConfig[HYGR_MAXT_INDEX] = Valeur;
        ModificationConfig(HYGR_MAXT_INDEX);
      else if (nomCommande == F("PRESSURE"))
        ParametresConfig[PRESSURE_INDEX] = Valeur;
        ModificationConfig(PRESSURE_INDEX);
      else if (nomCommande == F("PRESSURE_MIN"))
        ParametresConfig[PRESSURE_MIN_INDEX] = Valeur;
        ModificationConfig(PRESSURE_MIN_INDEX);
      else if (nomCommande == F("PRESSURE_MAX"))
        ParametresConfig[PRESSURE_MAX_INDEX] = Valeur;
        ModificationConfig(PRESSURE_MAX_INDEX);
      else if (nomCommande == F("CLOCK"))
        String Horloge = commande.substring(6);
        int annee = Horloge.substring(0, 4).toInt();
        int mois = Horloge.substring(5, 7).toInt();
        int jour = Horloge.substring(8, 10).toInt();
        int heure = Horloge.substring(11, 13).toInt();
        int minute = Horloge.substring(14, 16).toInt();
        int seconde = Horloge.substring(17, 19).toInt();
        ChangerHorloge(annee, mois, jour, heure, minute, seconde);
  DateTime NouvelleHorloge(annee, mois, jour, heure, minute, seconde); // Année, mois, jour, heure, minute, seconde
  rtc.adjust(NouvelleHorloge);
  Serial.println(F("Horloge changée avec succès."));
void LEDMode()
  switch (mode_actu)
  case MODE_STANDARD:
    leds.setColorRGB(0, 0, 255, 0);
    leds.setColorRGB(0, 255, 155, 0);
  case MODE_ECO:
    leds.setColorRGB(0, 0, 0, 255);
    leds.setColorRGB(0, 255, 0, 0);
  default:
{                                 // Si erreur d'accès à l'horloge
  leds.setColorRGB(0, 255, 0, 0); // Allume la LED en rouge
  delay(1000);                    // On attend 1 sec
  leds.setColorRGB(0, 0, 0, 255); // Allume la LED en bleu
{                                   // Si erreur d'accès au GPS
  leds.setColorRGB(0, 255, 255, 0); // Allume la LED en jaune
{                                 // Si erreur d'accès aux données d'un capteur
  leds.setColorRGB(0, 0, 255, 0); // Allume la LED en verte
{                                 // Si données incohérentes
  delay(2000);                    // On attend 2 sec
{                                     // Si erreur de carte SD pleine
  leds.setColorRGB(0, 255, 255, 255); // Allume la LED en blanc
{                                     // Si erreur d'accès et d'écriture sur la carte SD
  leds.setColorRGB(0, 255, 0, 0);     // On allume la LED en rouge
  leds.setColorRGB(0, 255, 255, 255); // On allume la LED en blanc
  climateSensor.takeForcedMeasurement();
  if (ParametresConfig[LUMIN_INDEX])
    int Luminosite = analogRead(PIN_LUMIN);
    Affichage(String(Luminosite), false);
    PointVirgule();
    Affichage(F("Capteur désactivé ; "), false);
  float Temperature_Air = climateSensor.getTemperatureCelcius();
  if (ParametresConfig[TEMP_AIR_INDEX])
    if (Temperature_Air >= ParametresConfig[MIN_TEMP_AIR_INDEX] && Temperature_Air <= ParametresConfig[MAX_TEMP_AIR_INDEX])
      Affichage(String(Temperature_Air), false);
      PointVirgule();
      Affichage(F("Hors intervalle ; "), false);
  if (ParametresConfig[HYGR_INDEX])
    float Hygrometrie = climateSensor.getRelativeHumidity();
      Affichage(String(Hygrometrie), false);
      PointVirgule();
  if (ParametresConfig[PRESSURE_INDEX])
    float Pression = climateSensor.getPressure();
    if (Pression >= ParametresConfig[PRESSURE_MIN_INDEX] && Pression <= ParametresConfig[PRESSURE_MAX_INDEX])
      Affichage(String(Pression), false);
      Affichage(F("Hors intervalle"), false);
    Affichage(F("Capteur désactivé"), false);
void connexionSD()
  while (!SD.begin(PIN_SD))
    Serial.println(F("Connexion Ă  la carte SD impossible, veuillez verifier la connexion."));
  Serial.println(F("Modification effectuée avec succès."));
  EEPROM.put(index * sizeof(long), ParametresConfig[index]);
  for (int i = 0; i < 30; i++)
    EEPROM.get(i * sizeof(long), ParametresConfig[i]);
void DonneesGPS()
  String GPS = "";
  if (mode_actu == MODE_ECO){
    etatGPS = !etatGPS;
    GPS = F("Aucune mesure effectuée");
  else{
    etatGPS = true;
  if ((SoftSerial.available() > 0) && (etatGPS))
    for (int i = 0; i < 15; i++){
      GPS = SoftSerial.readStringUntil('\n');
    GPS = "";
    unsigned long StartGPS = millis();
    do
      if ((millis() - StartGPS) > 10000)
        erreur_acces_GPS();
        Affichage(F("GPS Timeout"), true);
    } while (!GPS.startsWith(F("$GPGGA")));
    Affichage(GPS, true);
  if (mode_actu == MODE_MAINTENANCE)
    if (ligne)
      Serial.println(Donnees);
      Serial.print(Donnees);
    if (ligne)
      Fichier.println(Donnees);
      Fichier.flush();
    else{
      Fichier.print(Donnees);
      Fichier.flush();
void PointVirgule()
  Affichage(F(" ; "), false);
  Affichage(F(":"), false);
void Creation()
  Affichage("", true);
  Affichage(F("Horloge | Luminosité | Température (°C) | Hygrométrie (%) | Pression (HPa) | Données GPS"), true);
  Affichage(NomFichierDossier(Maintenant.hour()), false);
  Affichage(NomFichierDossier(Maintenant.minute()), false);
  Affichage(NomFichierDossier(Maintenant.second()), false);
  PointVirgule();
  PointVirgule();
  DonneesGPS();
void Dossier(){
    NomDossier = NomFichierDossier(Maintenant.year() % 100) + NomFichierDossier(Maintenant.month()) + NomFichierDossier(Maintenant.day());
    if (!SD.exists(NomDossier)){
      SD.mkdir(NomDossier);
void VerificationRevision(){
  if(JourActuel != Maintenant.day()){
    RevisionFichier = 0;
String NomFichierAvecRevision(int Revision){
    Revision = 0;
  Dossier();
  String NomFichier = NomDossier + '/' + NomDossier + '_' + String(Revision) + F(".LOG");
  return NomFichier;
    Fichier = SD.open(NomFichierAvecRevision(0), FILE_WRITE);
    if (Fichier)
        Creation();
        Fichier.close();
        if (Fichier.size() > ParametresConfig[FILE_MAX_SIZE_INDEX])
          SD.rename(NomFichierAvecRevision(0), NomFichierAvecRevision(RevisionFichier));
          RevisionFichier++;
        Serial.println(F("Enregistrement SD effectué."));
    else{
      Serial.println(F("Carte SD pleine."));
String NomFichierDossier(int Time){
    return (Time > 9 ? String(Time) : '0' + String(Time));
It's just I don't see why in maintenance mode it prints all the values and in the SD card it doesn't print everything
Which Arduino are you using?
How much RAM does the build process say has been used?
Using the SD card library takes 512+ bytes if RAM.
I'm using an Arduino Uno which is asked in the project, and this is what i use :
you already use tricks to get text into flash memory, you could win 30 bytes of RAM by having ParametresDefault in PROGMEM but that might not cut it and your flash memory is also pretty full..
how much memory is consumed by those libraries
Please don't post photos that contain only text. Copy & paste the text into your post (using code tags). It's much more efficient.
I don't know how much RAM it would save, but you could try not using String and use basic C string (char array) functions instead. Using String is convenient, but it probably uses more RAM and Flash.
note that you should be careful with maths operations
30 * 1000 is conducted using int and on your uno an int is 2 bytes, limited at 32767. so 30 * 1000 will work but 40 * 1000 would have failed.
write it like that
  if ((millis() - TempsInactif) > (1000ul * 30)) // A changer pour test soutenance (1000ul * 60 * 30)
so that the ul suffix forces the maths to be done using unsigned long instead of int (or write 30000 directly or 30000ul if you want to show you understand about setting the underlying data type for your numbers)
