const int motorPin1 = 6;
const int motorPin2 = 5;
char input;
pinMode(motorPin1,OUTPUT);
pinMode(motorPin2,OUTPUT);
if(Serial.available() > 0) {
input = Serial.read();
if (input == '+') {
Serial.println("Clockwise");
digitalWrite(motorPin1,HIGH);
digitalWrite(motorPin2,LOW);
else if (input == '-') {
Serial.println("CounterClockwise");
digitalWrite(motorPin1,LOW);
digitalWrite(motorPin2,HIGH);
else if (input == 'S') {
Serial.println("Stop");
Where are you stuck ?
Is it with entering and interpreting the number or is it in using the map() function ?
well basically my prof asked me to edit the code to make the range of the speed on my pins for the motor start from 0-99 instead of 0-255 since my pins are PWM and i dont know how to do that honestly
Where does the 0-99 come from?
Your code at the moment just stops, fwd, reverse, there is no PWM, no speed control.
What are you using as a motor driver?
What model Arduino are you using?
Thanks.. Tom..
i totally get what are you saying but my prof asked me to edit the code using analogWrite instead of digitalWrite and change the speed range which is 0-255 to 0-99 , so i was thinking about some sort of mapping the range but i dont know how and im not sure if mapping would work
as i said before he wants the range starts from 0-99 instead 0-255 ( i have to use analogWrite to use that) for example analogWrite(0,50); which should equal to analogWrite(0,127); somehow and i dont know how to do that.
Yes, but where does the 0-99 value come from?
idk he just wants us to convert it ig somehow
he came up with this idea all of a sudden
its not the deal right here
my problem is how to convert that if you get what i mean
the number doesnt mean anything here, he couldve chosen different range but he wanted 0-99
Have you tried using the map function?
What went wrong?
I don't know how to apply it in this situation honestly that's what I have been trying the whole time
do you have a clue on how to apply the map function in this situation?
Then step away from the hardware, and write a simple sketch that generates (for loop) values in the range 0-255, and uses the map function to convert them to 0-99.
Print both values.
after converting them i have to send the values to my motor to run within a specific speed, how is that possible?
You'd have to have some sort of feedback.
This could be as simple as a once-per-revolution pulse to act as an rpm counter, or some sort of encoder.
