'i' not declared in this scope
I don't understand I am getting the error message "'i' is not declared in this scope" even though it should be.
It is originating from the line if ((i)==1){
Here is my code:
#include <AFMotor.h>
//setting pin numbers
AF_DCMotor motor1(1);
AF_DCMotor motor2(2);
AF_DCMotor motor3(3);
AF_DCMotor motor4(4);
const int trigpin = 53;
const int echopin = 51;
//setting up other variables
int range;
long duration;
int distance;
int start_turn=-15001;
//defining threshold distance in cm
const int t_d=20;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  //set up sensor input, output
  pinMode(trigpin, OUTPUT);
  pinMode(echopin, INPUT);
  Serial.println("Start");
  // turn on motors and set the speed of motors
  motor1.setSpeed(255);
  motor2.setSpeed(255);
  motor3.setSpeed(255);
  motor4.setSpeed(255);
  motor1.run(RELEASE);
  motor2.run(RELEASE);
  motor3.run(RELEASE);
  motor4.run(RELEASE);
//defining the function for getting the range to nearest obstacle in cm
int get_range() {
  digitalWrite(trigpin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigpin, HIGH);
  delayMicroseconds(5);
  duration = pulseIn(echopin, HIGH);
  distance = duration*0.034/2;
  return distance;
  range=get_range();
  while ((range)>=(t_d)){
    //Serial.print("forward");
    motor1.run(FORWARD);
    motor2.run(FORWARD);
    motor3.run(FORWARD);
    motor4.run(FORWARD);
    range=get_range();
  Serial.println(range);
  while ((range)<(t_d)){
    if (abs((millis()-(start_turn)))>10000){
      randomSeed(analogRead(9));
      const int i = (random(1, 256))%2;
    if ((i)==1){
      Serial.print("right");
      motor1.run(BACKWARD);
      motor2.run(BACKWARD);
      range=get_range();
      start_turn=millis();
    else{
      motor3.run(BACKWARD);
      motor4.run(BACKWARD);
      range=get_range();
    if (range>t_d){
      delay(3000);
Do some research on variable scope:
https://www.arduino.cc/reference/en/language/variables/variable-scope--qualifiers/scope/
You've declared i within this scope:
so you can only use it within that scope.
add
byte i;
before setup()
so it's a global variable.
CrossRoads:
add
byte i;
before setup()
and don't put const int in front of it when you assign the random number to it otherwise you will have 2 different variables with the same name but different scopes
Thanks guys, I'm not very experienced with coding for Arduino or in C++ in general so I didn't understand the scope thing totally because it is different from other languages I've learned so far.
I'm going to use what you guys suggested.
jonman5:
General rule is everything declared inside {} will only live in that {}.
If you want to pursue further, I suggest to learn more about scoping and not giving up by using global variables when it's not necessary because it's a potentially hazard.
