Hello,
I'm a beginner with the Arduino and I'm having trouble with my code.
I've essentially got 5 different functions that control the lights on LED strips, and then I've got code on Processing (another program) that plays one of two audio tracks when the keys 'h' or 'r' are pressed. The processing code also returns the numbers 1 and 2 respectively when either of these tracks are played.
I used the inbuilt library named Serial to connect both these pieces of code, and essentially all I'm trying to do is set the color of the LED strips in my Arduino code to red or green depending on whether I receive a '1' or '2' from Processing. I keep getting this error below: 'i' was not declared in this scope.
I'm not sure where I'm meant to define 'i' in the code below for this error to stop.
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
Adafruit_NeoPixel strip = Adafruit_NeoPixel(18, PIN, NEO_GRB + NEO_KHZ800);
int setting = 0;
char val; // Data received fromt the serial port
Serial.begin(9600); // Starts serial communication at 9600 bps
strip.begin();
strip.show(); // Initialize all pixels to 'off'
if (Serial.available()) // If data is available to read,
val = Serial.read(); // read it and store it in val
for (int i = 0; i <= strip.numPixels(); i++);{
if (val == '1') // If 1 was received
strip.setPixelColor(i, 255, 0, 0);
else if (val == '2') // If 2 was received
strip.setPixelColor(i, 15, 224, 67);
simpleTest(false, 100);
contraryChase(false,100);
littleChase(false,150);
basicFade(false,10,strip.numPixels(),0);
rollingFade(false, 10, strip.numPixels());
void simpleTest(boolean on, int spd){
while(on){
for (int i = 0; i <= strip.numPixels(); i++){
strip.setPixelColor(i,255,0, 0);
strip.setPixelColor(i-1, 0, 0, 0);
strip.show();
delay(spd);
}//end simpleTest
void contraryChase(boolean on, int spd){
while(on){
strip.setPixelColor(i, random(255),200+random(55),255);
strip.setPixelColor(strip.numPixels()-i, 255,255,255);
strip.setPixelColor(strip.numPixels()-i+1, 0, 0, 0);
strip.show();
delay(spd);
}//end contraryChase
void basicFade(boolean on, int spd, int numPix, int begPix){
int level = 0;
int dir = 0;
while(on){
switch(dir){
case 0:
for (int i = begPix; i <= numPix+begPix; i++){
strip.setPixelColor(i,level,level,level);
}//end for
strip.show();
delay(spd);
if (level < 255) level++;
else dir = 1;
case 1:
}//end for
strip.show();
delay(spd);
if (level > 0) level--;
else dir = 0;
}//end switch
}//end big while
}// end basic fade
void rollingFade(boolean on, int spd, int numPix){
int lvl1=0;
int lvl2=0;
int lvl3=0;
int state = 0;
while(on){
Serial.println(state);
switch(state){
case 0:
stripUtility(lvl1,lvl2,lvl3);
strip.show();
delay(spd);
if (lvl1 < 85) lvl1++;
else state = 1;
case 1:
strip.show();
delay(spd);
if (lvl1 < 170){
lvl1++;
lvl2++;
else state = 2;
case 2:
strip.show();
delay(spd);
if (lvl2 < 170 ){
lvl1--;
lvl2++;
lvl3++;
else state = 3;
case 3:
strip.show();
delay(spd);
if (lvl3 < 170 ){
lvl1--;
lvl2--;
lvl3++;
else state = 4;
case 4:
strip.show();
delay(spd);
if (lvl1 > 0 ){
lvl1--;
lvl2--;
lvl3--;
else state = 5;
case 5:
strip.show();
delay(spd);
if (lvl2 > 0 ){
lvl1++;
lvl2--;
lvl3--;
else state = 6;
case 6:
strip.show();
delay(spd);
if (lvl3 > 0 ){
lvl1++;
lvl2++;
lvl3--;
else state = 1;
}//end switch
}//end big while
}//end rollingFade
void stripUtility(int lvl1, int lvl2, int lvl3){
for (int i = 0; i <= 5; i++){
strip.setPixelColor(i,lvl1,lvl1,lvl1);
strip.setPixelColor(i+6,lvl2,lvl2,lvl2);
strip.setPixelColor(i+12,lvl3,lvl3,lvl3);
}//end for
void littleChase(boolean on, int spd){
for (int i = 0; i<13; i++){
if(i<7){
strip.setPixelColor(i,255,255,255);
strip.setPixelColor(i+6,255,255,255);
strip.setPixelColor(i+12,255,255,255);
strip.show();
delay(spd);
strip.setPixelColor(i,0,0,0);
strip.setPixelColor(i+6,0,0,0);
strip.setPixelColor(i+12,0,0,0);
strip.show();
else{
strip.setPixelColor(13-i,255,255,255);
strip.setPixelColor(13-i+6,255,255,255);
strip.setPixelColor(13-i+12,255,255,255);
strip.show();
delay(spd);
strip.setPixelColor(13-i,0,0,0);
strip.setPixelColor(13-i+6,0,0,0);
strip.setPixelColor(13-i+12,0,0,0);
strip.show();
