I Spent 6 Hours on the problem of burning the bootloader in my Leonardo and I didn't fix
recently my Leonardo ATmega32u4 Board had a problem is detected
Board ---->Detected
port ---->Not Show
"I also checked the device manager no COMport is listed
so I want to burn the bootloader in Leonardo
working Arduino UNO Connected to Computer as master & Leonardo as a Target like this connection diagram 523b53bb757b7f01268b456a.jpg (1001Ɨ419) (sparkfun.com)
but I got this error
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Failed chip erase: uploading error: exit status 1
please help to solve this :sob:
Did you load the "Arduino as ISP" sketch?
The Arduino that you will use as programmer needs a specific sketch. You find it >under Examples > 11. ArduinoISP > ArduinoISP .
Source: https://docs.arduino.cc/built-in-examples/arduino-isp/ArduinoISP
Recap: burn the Bootloader in 8 steps
  • Open the ArduinoISP firmware (in Examples) to your Arduino board.
  • Note for Arduino 1.0: you need to make one small change to the ArduinoISP code. Find the line in the heartbeat() function that says "delay(40);" and change it to "delay(20);".
  • Select the items in the Tools > Board and Serial Port menus that correspond to the board you are using as the programmer (not the board being programmed).
  • Upload the ArduinoISP sketch.
  • Wire your Arduino boards..
  • Select the item in the Tools > Board menu that corresponds to the board on which you want to burn the bootloader (not the board that you're using as the programmer). See the board descriptions on the environment page for details.
  • Select the Arduino as ISP in the Tools>Programmer menu.
  • Use the Burn Bootloader command.
The board that you selected was the Uno, not the Leonardo. You need to select the Leonardo as the board and the Uno port.
Before you continue
When you double-tap the reset of the Leonardo (not connected to the programmer), does the L-LED fade-in and fade-out for approximately 8 seconds? If so, there is probaly no need to burn the bootloader.
If yes, which IDE are you using?
My Man :pray:
That Works Thank you a lot
if I ask this you in the morning I won't waste this day
