I do, but I don't think I can program it without removing the chip. Or can I? Atmel warn against attempting that with chips on boards, but maybe it would be OK. I suppose it couldn't get any worse.
Nick,
I can replace that chip for you. I have a hot air station, and even a couple of chips I think.
The TQFP chips, not the leadless chips - board looks like it has pads for both?
If you've got nothing to lose, I would try replacing the chip.
Put it in a toaster oven on high. It takes 5 minutes in the oven I use.
Once the solder is loose, carefully take the board out. It helps if it's on a tray in the oven. You don't want to bump it against anything, everything will be loose. Using tweezers, pick off the '328. Allow the board to cool.
Using a fine point soldering iron, solder on a new chip. Lots of tutorials on youtube on doing smd soldering by hand.
I havn't done this technique on a Uno yet, but I have done it on a breakout board when I got the chip on backwards. Standard disclaimers apply.
CrossRoads:
Nick,
However that is not the photo of it. (That has the extra pads). The broken one has a chip the size of the lower one (SMD edition) but that particular rev board did not have the larger pads. I don't have my camera handy right now.
cjdelphi:
I'm curious how on earth he killed one, i've tried (by accident) several times lol
I think I must have zapped it with static. I usually touch my aluminum keyboard before reaching for parts like that, but might have forgotten once. Sometimes I get quite a zap from the keyboard when I touch it.
