I wanna combine sketches but i don't know how to
hi
i don't know how to combine this sktches
i have 4 sketches and combine them into 2 code
(one in the sender arduino and other in the receiver arduino both wired to canbus mcp2515 )
ther first sketches is for controlling the leds by push buttons and their brightness by the potentiometer
and the seconds are for displaying the temperture and humidity on oled from a dht11
sender code
sketch1
#include <SPI.h>
#include <mcp2515.h>
#define potPin1 A0
#define potPin2 A1
#define CS 10
int ReceivedMessage;
int push1 = 2;
int push2 = 3;
int flag = 0;
int s;
   int potValue1;
   int potValue2;
struct can_frame MyMsg;
MCP2515 mcp2515(CS);
  while (!Serial);
 SPI.begin();
 mcp2515.reset();
 mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ);
 mcp2515.setNormalMode();
 pinMode(push1, INPUT_PULLUP);
 pinMode(push2, INPUT_PULLUP);
 MyMsg.can_id = 0x30;
 MyMsg.can_dlc = 3;
 if(digitalRead(push1) == 0)
 while(digitalRead(push1) == 0);
 s = 1;
  potValue1 = analogRead(potPin1);
        Serial.println(potValue1);
  potValue1 = map(potValue1,0,1023,0,255);
 flag = 1;
 if(digitalRead(push2) == 0)
 while(digitalRead(push2) == 0);
 s = 2;
   potValue2 = analogRead(potPin2);
        Serial.println(potValue2);
  potValue2 = map(potValue2,0,1023,0,255);
 flag = 1;
 if(flag == 1)
 flag = 0;
 MyMsg.data[0] = s;
 MyMsg.data[1] = potValue1;
 MyMsg.data[2] = potValue2;
 mcp2515.sendMessage(&MyMsg);
 delay(20);
sketch2
#include <SPI.h>
#include "DHT.h"
DHT dht;
#define CS 10
MCP2515 mcp2515(CS); // SPI CS
int DHTPIN = 4; // DHT11 on pin 2
float temperature, humidity;
 SPI.begin();
 mcp2515.reset();
 mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ); // CAN bus config
 mcp2515.setNormalMode(); // Normal mode
 dht.setup(DHTPIN); // Setup DHT11
 humidity = dht.getHumidity(); // GEt humidity
 temperature = dht.getTemperature(); // Get temperature
 MyMsg.can_id = 0x30; // CAN ID
 MyMsg.can_dlc = 2; // 2 byte
 MyMsg.data[0] = (int)temperature; // Temp in data[0]
 MyMsg.data[1] = (int)humidity; // Humidity
 mcp2515.sendMessage(&MyMsg); // Send message
 delay(5000); // Wait 5 seconds
receiver code
sketch 1
#include <SPI.h>
#define CS 10
int LED;
int led1 = 5;
int led2 = 3;
 SPI.begin();
 mcp2515.reset();
 pinMode(led1, OUTPUT);
 pinMode(led2, OUTPUT);
 digitalWrite(led1, 0);
 digitalWrite(led2, 0);
 if(mcp2515.readMessage(&MyMsg) == MCP2515::ERROR_OK)
 LED = MyMsg.data[0];
 if(LED == 1)
        int x1 = MyMsg.data[1];
       Serial.println(x1);
         analogWrite(led1,x1);
 if(LED == 2)
               int x2 = MyMsg.data[2];
       Serial.println(x2);
         analogWrite(led2,x2);
sketch2
#include <SPI.h>
#include <Wire.h>
 #include <Adafruit_GFX.h>
 #include <Adafruit_SSD1306.h>
 #define screen_width 128 // OLED display width, in pixels
 #define screen_height 64 // OLED display height, in pixels
 #define OLED_RESET 4
 Adafruit_SSD1306 display(screen_width, screen_height);
#define CS 10
int temperature, humidity;
 SPI.begin();
 mcp2515.reset();
 mcp2515.setBitrate(CAN_500KBPS, MCP_8MHZ); // Config CAN bus
   Serial.println("TEMPERATURE AND HUMIDITY");
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
 temperature = MyMsg.data[0]; // Temperature
 humidity = MyMsg.data[1]; // Humidity
   display.setTextSize(1);
   display.setTextColor(SSD1306_WHITE);
   display.setCursor(0, 0);
   display.print("  TEMP. & HUMIDITY");
   display.setCursor(0, 25);
   display.print(" TEMPERATURE : ");
   display.setCursor(90, 25);
   display.print((int)temperature);
   display.setCursor(0, 50);
   display.print(" HUMIDITY  : ");
   display.setCursor(90, 50);
   display.print((int)humidity);
   display.display();
thank you in advance
You need to write a new program that does what you want. It is OK to copy parts of other programs into the new code as long as
  1. those parts do exactly what you want, in the correct order
  2. don't conflict with any other parts of the code, especially variable names and types, and program functionality
Be sure there is no pin conflict between codes.
Look at any program. they are all similar. at the top, you include the libraries. then you declare the variables. after that you write the functions. at the bottom, you have void(setup)
divide the code being added as noted above. include the libraries you need to add, insert the new variables you need, changing any that conflict with the existing code. paste in the new functions. add the necessary steps to void(setup)
it is a case of sorting apples from oranges, and sending the components of the incoming sketches to where they belong.
