I want to control the AD5290 digital potentiometer,with arduino uno
i am trying to control AD5290 using arduino using below attached code, here iam getting the value of pot as 7k ohms. even though i am changing the values of resistance from 0-255. can any one help to fix this problem
#include <SPI.h>
const int CS_PIN = 9;
const int SDI_PIN = 10;
const int SDO_PIN = 11;
const int SCLK_PIN = 13;
// Set pin modes
pinMode(CS_PIN, OUTPUT);
pinMode(SDI_PIN, OUTPUT);
pinMode(SDO_PIN, INPUT);
pinMode(SCLK_PIN, OUTPUT);
// Initialize SPI
SPI.begin();
SPI.setDataMode(SPI_MODE2);
SPI.setBitOrder(MSBFIRST);
// Set initial resistance value (0-255, where 0 is minimum resistance and 255 is maximum)
setResistance(50); // Example: set the resistance to halfway
// Your main code logic goes here
// You can change the resistance value using the setResistance() function
void setResistance(byte resistanceValue) {
digitalWrite(CS_PIN, LOW); // Set CS low to enable communication with the AD5290
SPI.transfer(resistanceValue); // Send the command to set the resistance value
digitalWrite(CS_PIN, HIGH); // Set CS high to end communication
Welcome to the forum
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
You can cross-check your code and circuit with this video: Arduino Nano AD5252 I2C Digital Potentiometer Tutorial - YouTube
Your code only sets the resistance value to 50, it does nothing else
1. Check that you have connected your pot with UNO as per Fig-1.
digitalPotdownload
Figure-1:
2. Upload the following sketch (your one with slight modification).
#include <SPI.h>
const int CS_PIN = 10;//9;
const int SDI_PIN = 12;//10;
  // Set pin modes
 /* pinMode(CS_PIN, OUTPUT);
  pinMode(SCLK_PIN, OUTPUT);*/
  // Initialize SPI
  SPI.begin();
 // SPI.setDataMode(SPI_MODE2);
 // SPI.setBitOrder(MSBFIRST);
 // setResistance(50); // Example: set the resistance to halfway
3. Connect DVM between across W and GND. Check that DVM reads about 1V.
I had changed the resistance values from 0-255 in that code, but the value of the digipot is showing the same 7k ohm resistance between wiper and VA pins, I need different values of resistance ranging from 0 to 10k ohms. can you help me.
Have you tried @GolamMostafa suggestions?
I have did the same thing what you have said, and connections are made as per block diagram mentioned by you.
but I am getting 4.9v between W and Ground. what should I do now.
Yahh I have tried, but I didn't got the result as my requirement.
Connect the following
Arduino --> AD5290
MOSI (pin 11) --> SDI
SCK (pin 13) --> CLK
SS (pin 10) --> CS
Use this code:
#include <SPI.h>
// set pin 10 as the slave select for the digital pot:
const int slaveSelectPin = 10;
  // set the slaveSelectPin as an output:
  pinMode(slaveSelectPin, OUTPUT);
  // initialize SPI:
  SPI.begin();
  SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
  // change the resistance from min to max:
  for (int level = 0; level < 255; level++)
    digitalPotWrite(level);
    delay(100);
void digitalPotWrite(byte value) {
  // take the SS pin low to select the chip:
  digitalWrite(slaveSelectPin, LOW);
  delay(5);
  //  send value via SPI:
  SPI.transfer(value);
  delay(5);
  // take the SS pin high to de-select the chip:
  digitalWrite(slaveSelectPin, HIGH);
Where to look for output?
The sketch 0f post #5 is modified as follows:
#include <SPI.h>
//const int CS_PIN = 10;//9; if using UNO, then no need
//const int SDI_PIN = 12;//10;
//const int SDO_PIN = 11;
//const int SCLK_PIN = 13;
  // Set pin modes
  // Initialize SPI
  SPI.begin();
 digitalWrite(SS, HIGH);
  digitalWrite(SS, LOW); // Set CS low to enable communication with the AD5290
  delay(10);
  byte y = SPI.transfer(resistanceValue); // Send command to set resistance value
  delayMicroseconds (10);
  digitalWrite(SS, HIGH); // Set CS high to end communication and to latch data
Wouldn't "halfway" be 127 ~ 128? Which of the 3 AD5290s does the OP have?
thank you, I will try withs code for sure and I will update you
How are you measuring resistance?
I will try this code also,
can you predict the the out put for this code and tell me please!!!
I have tried this code, the values are chaining in serial monitor(1 to 255 numbers are generating) but the value of digipot is remaining constant!
By using digital multimeter. between the A & W (terminal A and Wiper) terminals of the AD5290.
now I got my digipot getting changed from 0k ohms to 10k ohms. thank you for the code.
Thank u for this code, can u help me with the code which can keep the resistance of digipot at a constant position, actually this is incrementing the digipot. I want to set it at 2k ohms can u help me with that.
