The code what I want to make is this situation.
"When the distance is in from 100cm to 50cm for 5 seconds. I want to make a 'LOW' sign at motors."
this is my code
#include <NewPing.h>
#define MAX_DISTANCE 150
int motor_1m1 = 7;
int motor_2m1 = 8;
int motor_3m1 = 9;
int motor_1m2 = 11;
int motor_2m2 = 12;
int motor_3m2 = 13;
NewPing sonar1(3,4, MAX_DISTANCE);
NewPing sonar2(5,6, MAX_DISTANCE);
pinMode(motor_1m1, OUTPUT);
pinMode(motor_2m1, OUTPUT);
pinMode(motor_3m1, OUTPUT);
pinMode(motor_1m2, OUTPUT);
pinMode(motor_2m2, OUTPUT);
pinMode(motor_3m2, OUTPUT);
unsigned int uS1 = sonar1.ping_median();
int value1 = uS1 / US_ROUNDTRIP_CM;
unsigned int uS2 = sonar2.ping_median(); .
int value2 = uS2 / US_ROUNDTRIP_CM;
if(value1 >= 100){
digitalWrite(motor_1m1, LOW);
digitalWrite(motor_2m1, LOW);
digitalWrite(motor_3m1, LOW);
else if(value1 >=50 && value1 < 100) {
digitalWrite(motor_3m1, HIGH);
else if(value1 >=30 && value1 < 50)
digitalWrite(motor_2m1, HIGH);
else if(value1 >=1 && value1 < 30)
digitalWrite(motor_1m1, HIGH);
if(value2 >= 100)
digitalWrite(motor_1m2, LOW);
digitalWrite(motor_2m2, LOW);
digitalWrite(motor_3m2, LOW);
else if(value2 >=50 && value2 <100)
digitalWrite(motor_3m2, HIGH);
else if(value2 >=30 && value2 < 50)
digitalWrite(motor_2m2, HIGH);
else if(value2 >=1 && value2 < 30)
digitalWrite(motor_1m2, HIGH);
Serial.print("value1: ");
Serial.print(uS1 / US_ROUNDTRIP_CM);
Serial.println("cm");
Serial.print("value2: ");
Serial.print(uS2 / US_ROUNDTRIP_CM);
