[I2C] How to send and receive a singel comma (in char)
Hi Guys.
I need your help.
I use I2c protocols to communicate two Ardus.
For example, I want to send only : “,” , a comma from master Ardu to slave Ardu.
If I write Wire.write(“,”);
I received “44” on the Slave side. If you have a look on the Ascii table, you can see that (“44”) Is the Dec spelling from a single comma.
Can you tell me please, how I can send sign that the slave Ardus interpret as a Char spelling?
Best regards
Wire.write(',');
If you get something else on the receiving end, it is the receiver code that is wrong.
You program the slave to use the value of 44 as a char.
   char comma = 44;
  Serial.print(comma);
Thank you very much. My receiver code is wrong, i correct it.
Thank you PaulS and jremington.
