I have recently started playing around with an arduino uno and tried to connect a 16x2 LCD via a I2C to the board. My issue is, that although the backround LED gets turned on, no text I have programmed is visible on the display, only the squares. I have played around with the contrast and tried a lot of different things, even another I2C+display and another uno.
#include <LiquidCrystal.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
lcd.init();
lcd.begin(16,2);
lcd.backlight();
lcd.print("Hello World!");
lcd.setCursor(0,1);
lcd.print("servus");
delay(10000);
lcd.noBacklight();
lcd.clear();
void loop() {}
SDA is connected to analog input 4 and SCL to analog input 5.
Thanks in advance!
GOOGLE : Arduino I2C Scanner
Download and run the sketch, it will see if your screen is recognised as an I2C device.
For an I2C LCD display to work, the I2C address and the I2C backpack to LCD pin mapping must be correct. If the library default settings for either or both are not correct the LCD will not work. You can try to figure out the right pin mapping and use an I2C scanner to find the address, but if you install and use the hd44780 library that is done automatically by the library.
To install the hd44780 library. The hd44780 library is the best available for I2C LCDs. The library is available in the Library Manager. Go to Library Manager (in the IDE menus, Sketch, Include Libraries, Manage Libraries) and in the Topics dropdown choose Display and in the Filter your search box enter hd44780. Select and install the hd44780 library by Bill Perry.
The class that you want to use is the hd44780_I2Cexp class. There are examples to show how to use the library. The nice thing about the hd44780 library is that it will autodetect the I2C address and the I2C backpack to LCD pin mapping.
In the examples, there is a diagnostic sketch that will help us to help you if you still have trouble with the display. Run the diagnostic sketch and post the results.
