I2C slave devices doenst boot on power up
hi all,
i made a project i call it modular midi pads.
it has a main pad (teensy4.0) with 16 buttons, screen + encoder and midi over usb to controll software on the pc.
i also created a fader pad and encoder pad with the ESP32 C3 and they communicate over I2C. and i use pin 8 and 9 (default I2C Pins) but i found out the hard way that both pins are also use for the boot priority.
now the issue i have is when i connect the main pad and/or fader/encoder pad and then apply power the fader/encoder pad does not boot.
but when i apply power to the main pad only and then connect the fader/encoder pad to the main pad it all works fine.
and with connect i mean that i have magnetic pogo pin connectors between them.
I’m sorry but You need to provide technical dokumentation according to this link: How to get the best out of this forum - Projects / General Guidance - Arduino Forum
Requested: Annotated schematics and code. Please use code tags.
no problem but it will be allot.
main pad:
.INO
#include "pads.h"
#include "oled.h"
pads *pad[127];
uint8_t i2cAddress[127];
uint8_t padsCount;
uint32_t prevMillisI2C;
  //Serial.begin(9600);
  pinMode(ENCBUTTON, INPUT_PULLUP);
  Wire.begin();
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;)
  display.setRotation(2);
  display.clearDisplay();
  display.setTextSize(2);
  display.display();
  createPadItem(MAIN, 0);
  //MEMINFO();
  oled();
  uint8_t midi_data1 = 255;
  uint8_t midi_data2 = 255;
  uint8_t midi_channel = 255;
  if (usbMIDI.read() == true) {
    midi_data1 = usbMIDI.getData1();
    midi_data2 = usbMIDI.getData2();
    midi_channel = usbMIDI.getChannel();
  uint8_t error;
  for (uint8_t x = 0; x < 127; x++) {
    if (pad[x] != NULL) {
      error = pad[x]->scanData();
      if (error == I2CDISCONNECTED) {  // disconected
        uint8_t i2cID = pad[x]->getI2cAdress();
        for (uint8_t y = 1; y < 127; y++) {
          delete pad[y];
          pad[y] = NULL;
          padsCount = 1;  //1 because mainpad stays
          menuItem[y].title = "";
          menuItem[y].function = NULL;
          menuItem[y].data1 = NULL;
          menuItem[y].data2 = NULL;
          menuItem[y].pStruct = NULL;
        //padsCount--;
        //i2cAddress[i2cID] = 0;
        padMenu.numItems = padsCount;
        currentMenu = &padMenu;
        //MEMINFO();
        pad[x]->sendData(midi_channel, midi_data1, midi_data2);
        pad[x]->saveData();
  if (millis() - prevMillisI2C >= 1000) {
    I2C();
    prevMillisI2C = millis();
void I2C() {
  uint8_t error;
  uint8_t type = 0;
  for (uint8_t address = 1; address < 127; address++) {
    //if (i2cAddress[address] == 0) {
    if (pad[address] == NULL) {
      Wire.beginTransmission(address);
      error = Wire.endTransmission();
      if (error == 0) {  // Connecton is good
        //i2cAddress[address] = 1;
        Wire.write(0);  // 0 = code to ask TYPE
        Wire.requestFrom(address, (size_t)1, true);
        while (Wire.available()) {
          type = Wire.read();
      switch (type) {
        case FADERPAD:  //1
          createPadItem(FADERPAD, address);
          //MEMINFO();
          type = false;
        case ENCODERPAD:  //2
          createPadItem(ENCODERPAD, address);
          //MEMINFO();
          type = false;
void createPadItem(uint8_t type, uint8_t i2cAddress) {
  switch (type) {
    case MAIN:
        pads *pMain = new main(i2cAddress);
        pad[i2cAddress] = pMain;
        String test;
        test = String(".MainPad");
        test = (i2cAddress) + test;
        menuItem[i2cAddress].title = test;
        menuItem[i2cAddress].function = NULL;
        menuItem[i2cAddress].data1 = NULL;
        menuItem[i2cAddress].data2 = NULL;
        menuItem[i2cAddress].pStruct = &pad[i2cAddress]->menu;
        //padsCount++;
        //padMenu.numItems = padsCount;
        padMenu.numItems = 127;
    case FADERPAD:
        pads *pMain = new fader(i2cAddress);
        String test;
        test = String(".Faderpad");
        //padsCount++;
    case ENCODERPAD:
        pads *pMain = new encoderpad(i2cAddress);
        String test;
        test = String(".Encpad");
        //padsCount++;
#define printf Serial.printf
#if ARDUINO_TEENSY41
extern "C" uint8_t external_psram_size;
#endif
void MEMINFO() {
  constexpr auto RAM_BASE = 0x2020'0000;
  constexpr auto RAM_SIZE = 512 << 10;
  constexpr auto FLASH_BASE = 0x6000'0000;
#if ARDUINO_TEENSY40
  constexpr auto FLASH_SIZE = 2 << 20;
#elif ARDUINO_TEENSY41
  constexpr auto FLASH_SIZE = 8 << 20;
#endif
  // note: these values are defined by the linker, they are not valid memory
  // locations in all cases - by defining them as arrays, the C++ compiler
  // will use the address of these definitions - it's a big hack, but there's
  // really no clean way to get at linker-defined symbols from the .ld file
  extern char _stext[], _etext[], _sbss[], _ebss[], _sdata[], _edata[],
    _estack[], _heap_start[], _heap_end[], _itcm_block_count[], *__brkval;
  auto sp = (char *)__builtin_frame_address(0);
  /*printf("_stext        %08x\n",      _stext);
    printf("_etext        %08x +%db\n", _etext, _etext - _stext);
    printf("_sdata        %08x\n",      _sdata);
    printf("_edata        %08x +%db\n", _edata, _edata - _sdata);
    printf("_sbss         %08x\n",      _sbss);
    printf("_ebss         %08x +%db\n", _ebss, _ebss - _sbss);
    printf("curr stack    %08x +%db\n", sp, sp - _ebss);
    printf("_estack       %08x +%db\n", _estack, _estack - sp);
    printf("_heap_start   %08x\n",      _heap_start);
    printf("__brkval      %08x +%db\n", __brkval, __brkval - _heap_start);
    printf("_heap_end     %08x +%db\n", _heap_end, _heap_end - __brkval);*/
  extern char _extram_start[], _extram_end[], *__brkval;
  printf("_extram_start %08x\n", _extram_start);
  printf("_extram_end   %08x +%db\n", _extram_end,
         _extram_end - _extram_start);
#endif
  /*printf("\n");
    printf("<ITCM>  %08x .. %08x\n",
         _stext, _stext + ((int) _itcm_block_count << 15) - 1);
    printf("<DTCM>  %08x .. %08x\n",
         _sdata, _estack - 1);
    printf("<RAM>   %08x .. %08x\n",
         RAM_BASE, RAM_BASE + RAM_SIZE - 1);
    printf("<FLASH> %08x .. %08x\n",
         FLASH_BASE, FLASH_BASE + FLASH_SIZE - 1);*/
  if (external_psram_size > 0)
    printf("<PSRAM> %08x .. %08x\n",
           _extram_start, _extram_start + (external_psram_size << 20) - 1);
#endif
  printf("\n");
  auto stack = sp - _ebss;
  printf("avail STACK %8d b %5d kb\n", stack, stack >> 10);
  auto heap = _heap_end - __brkval;
  printf("avail HEAP  %8d b %5d kb\n", heap, heap >> 10);
  auto psram = _extram_start + (external_psram_size << 20) - _extram_end;
  printf("avail PSRAM %8d b %5d kb\n", psram, psram >> 10);
#endif
fade.cpp
#include <Arduino.h>
#include <Wire.h>
#include "pads.h"
fader::fader(uint8_t adress)
  : _i2cAdress(adress) {
  for (uint8_t x = 0; x < 4; x++) {
    pMenuItemsFunc = new MENUITEMS[10];
    pMenuItemsFunc[0] = (MENUITEMS){
      "Mode", toggle, (void*)&_modeData, (void*)&modeNames, NULL
    pMenuItemsFunc[1] = (MENUITEMS){
      "Ch", variable, (void*)&_channelData[x], (void*)16, NULL
    pMenuItemsFunc[2] = (MENUITEMS){
      "Note", variable, (void*)&_noteData[x], (void*)127, NULL
    pMenuItemsFunc[3] = (MENUITEMS){
      "ColOn", toggle, (void*)&_colorOn[x], (void*)&colorNames, NULL
    pMenuItemsFunc[4] = (MENUITEMS){
      "ColOff", toggle, (void*)&_colorOff[x], (void*)&colorNames, NULL
    pMenuItemsFunc[5] = (MENUITEMS){
      "Min", NULL, NULL, NULL, NULL
    pMenuItemsFunc[6] = (MENUITEMS){
      "Max", NULL, NULL, NULL, NULL
    pMenuItemsFunc[7] = (MENUITEMS){
      "Mod", NULL, NULL, NULL, NULL
    pMenuItemsFunc[8] = (MENUITEMS){
      "Key", NULL, NULL, NULL, NULL
    pMenuItemsFunc[9] = (MENUITEMS){
      //"Back", NULL, NULL, NULL, &menu
      "Back", eeprom, (void*)&_id[x], (void*)&_eepromFlag, &menu
    menuItemsFunc[x] = pMenuItemsFunc;
    String test;
    test = String("-Fader ");
    test = test + (x + 1);
    test = test + String("-");
    menuFunc[x].title = test;
    menuFunc[x].numItems = 10;
    menuFunc[x].pStruct = menuItemsFunc[x];
  //Serial.println("a");
  pMenuItems = new MENUITEMS[5];
    String test;
    test = String("Fader ");
    pMenuItems[x].title = test;
    pMenuItems[x].function = NULL;
    pMenuItems[x].data1 = NULL;
    pMenuItems[x].data2 = NULL;
    pMenuItems[x].pStruct = &menuFunc[x];
  pMenuItems[4].title = "Back";
  pMenuItems[4].function = NULL;
  pMenuItems[4].data1 = NULL;
  pMenuItems[4].data2 = NULL;
  pMenuItems[4].pStruct = &padMenu;
  menuItems = pMenuItems;
  menu.title = "-FaderPad-";
  menu.numItems = 5;
  menu.pStruct = menuItems;
  Serial.println("Faderpad + menuStruct");
  Wire.beginTransmission(_i2cAdress);
  Wire.write(GETEEPROM);
  Wire.requestFrom(_i2cAdress, (size_t)28, true);
  uint8_t x = 0;
    //Serial.println(Wire.read());
    _modeData[x] = Wire.read();
    _channelData[x] = Wire.read();
    _noteData[x] = Wire.read();
    _colorOn[x] = Wire.read();
    _colorOff[x] = Wire.read();
    _min[x] = Wire.read();
    _max[x] = Wire.read();
    x++;
fader::~fader() {
  pMenuItemsFunc = menuItemsFunc[0];
  delete[] pMenuItemsFunc;
  pMenuItemsFunc = menuItemsFunc[1];
  pMenuItemsFunc = menuItemsFunc[2];
  pMenuItemsFunc = menuItemsFunc[3];
  delete[] pMenuItems;
  Serial.print("Faderpad + menu structs are ");
uint8_t fader::scanData() {
  uint8_t error;
  Wire.write(GET4FADERDATA);
    return I2CDISCONNECTED;
  Wire.requestFrom(_i2cAdress, (size_t)4, true);
  uint8_t num = 0;
    _faderState[num] = Wire.read();
    num++;
  return 0;
void fader::sendData(uint8_t channelData, uint8_t noteData, uint8_t velocityData) {
  //Send data to PC
  for (uint8_t num = 0; num < 4; num++) {
    if (_faderState[num] != _faderPrev[num]) {
      usbMIDI.sendControlChange(_noteData[num], _faderState[num], _channelData[num]);
      _faderPrev[num] = _faderState[num];
  //Send data to pad
  // effe kijken of dit anders kan, 1 fader per x ipv alle 4 altijd
    if (noteData == _noteData[num]) {
      _dataToSend[num] = velocityData;
      Wire.write(SEND4FADERDATA);
      uint8_t x = 0;
      while (x < 4) {
        Wire.write(_dataToSend[x]);
        x++;
void fader::saveData() {
  if (_eepromFlag != 255) {
    Wire.write(SEND2EEPROM);
      Wire.write(_modeData[num]);
      Wire.write(_channelData[num]);
      Wire.write(_noteData[num]);
      Wire.write(_colorOn[num]);
      Wire.write(_colorOff[num]);
      Wire.write(_min[num]);
      Wire.write(_max[num]);
    _eepromFlag = 255;
uint8_t fader::getI2cAdress() {
  return _i2cAdress;
encoderpad.cpp
#include <Wire.h>
#include "pads.h"
encoderpad::encoderpad(uint8_t adress)
  for (uint8_t x = 0; x < 12; x++) {
      //"Back", eeprom, (void*)&_id[x], (void*)&_eepromFlag, &menu
    String test;
    test = String("-test ");
  pMenuItems = new MENUITEMS[13];
    String test;
  pMenuItems[12].title = "Back";
  pMenuItems[12].function = NULL;
  pMenuItems[12].data1 = NULL;
  pMenuItems[12].data2 = NULL;
  pMenuItems[12].pStruct = &padMenu;
  menu.title = "-EncPad-";
  menu.numItems = 13;
  Serial.println("EncoderPad + menuStruct");
  /*Wire.beginTransmission(_i2cAdress);
  uint8_t x = 0;
    x++;
encoderpad::~encoderpad() {
  Serial.print("Encoderpad + menu structs are ");
uint8_t encoderpad::scanData() {
  uint8_t error;
  Wire.requestFrom(_i2cAdress, (size_t)12, true);
  uint8_t num = 0;
    _dataState[num] = Wire.read();
    num++;
  return 0;
void encoderpad::sendData(uint8_t channelData, uint8_t noteData, uint8_t velocityData) {
  //Send data to PC
  for (uint8_t num = 0; num < 12; num++) {
    if (_dataState[num] != _dataPrev[num]) {
      usbMIDI.sendControlChange(_noteData[num], _dataState[num], _channelData[num]);
      _dataPrev[num] = _dataState[num];
  //Send data to pad
      uint8_t x = 0;
      while (x < 12) {
        x++;
void encoderpad::saveData() {
  /*if (_eepromFlag != 255) {
    _eepromFlag = 255;
uint8_t encoderpad::getI2cAdress() {
  return _i2cAdress;
main.cpp
#include <EEPROM.h>
#include <FastLED.h>
#include "pads.h"
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
#define NUM_LEDS 17
#define DATA_PIN 20
uint8_t _colorValue[8][3] = {
  { 255, 0, 0 },
  { 0, 255, 0 },
  { 0, 0, 255 },
  { 0, 255, 255 },
  { 255, 0, 255 },
  { 255, 255, 0 },
  { 255, 128, 0 },
  { 255, 255, 255 }
CRGB _leds[NUM_LEDS];
main::main(uint8_t adress)
  for (uint8_t x = 0; x < 16; x++) {
    MENUITEMS *pMenuItemsFunc = new MENUITEMS[10];
    //Title, Function, Data1, Data2, pStruct
      "Mode", toggle, (void *)&_modeData, (void *)&modeNames, NULL
      "Ch", variable, (void *)&_channelData[x], (void *)16, NULL
      "Note", variable, (void *)&_noteData[x], (void *)127, NULL
      "ColOn", toggle, (void *)&_colorOn[x], (void *)&colorNames, NULL
      "ColOff", toggle, (void *)&_colorOff[x], (void *)&colorNames, NULL
      "Back", eeprom, (void *)&_id[x], (void *)&_eepromFlag, &menu
    String test;
    test = String("-Button ");
  MENUITEMS *pMenuItems = new MENUITEMS[17];
    String test;
    test = String("Button ");
  pMenuItems[16].title = "Back";
  pMenuItems[16].function = NULL;
  pMenuItems[16].data1 = NULL;
  pMenuItems[16].data2 = NULL;
  pMenuItems[16].pStruct = &padMenu;
  menu.title = "-MainPad-";
  menu.numItems = 17;
    pinMode(_colomPin[x], INPUT_PULLUP);
    pinMode(_rowPin[x], OUTPUT);
  FastLED.addLeds<SK6812, DATA_PIN, GRB>(_leds, NUM_LEDS);
  MIDI.begin();
    _modeData[x] = EEPROM.read((x * 9));
    _channelData[x] = EEPROM.read((x * 9) + 1);
    _noteData[x] = EEPROM.read((x * 9) + 2);
    _colorOn[x] = EEPROM.read((x * 9) + 3);
    _colorOff[x] = EEPROM.read((x * 9) + 4);
  for (uint8_t num = 0; num < 16; num++) {
    _leds[num + 1] = CRGB((float)_colorValue[_colorOff[num]][0] / 255 * 3,
                          (float)_colorValue[_colorOff[num]][1] / 255 * 3,
                          (float)_colorValue[_colorOff[num]][2] / 255 * 3);
  FastLED.show();
  Serial.println("Mainpad + menu structs");
main::~main() {
  Serial.print("Mainpad + menu structs are ");
uint8_t main::scanData() {
  uint8_t num = 0;
  for (uint8_t row = 0; row < 4; row++) {
    digitalWrite(_rowPin[row], LOW);
    delayMicroseconds(1);
    for (uint8_t colom = 0; colom < 4; colom++) {
      _buttonState[num] = digitalRead(_colomPin[colom]);
      num++;
    digitalWrite(_rowPin[row], HIGH);
  return 0;
void main::sendData(uint8_t channelData, uint8_t noteData, uint8_t velocityData) {
  //Send data to PC
    if (_buttonState[num] != _buttonPrev[num]) {
      if (_buttonState[num] == false) {
        usbMIDI.sendControlChange(_noteData[num], 127, _channelData[num]);
        usbMIDI.sendControlChange(_noteData[num], 0, _channelData[num]);
      _buttonPrev[num] = _buttonState[num];
  //Send data to pad
      if (velocityData >= 100) {
        _leds[num + 1] = CRGB(_colorValue[_colorOn[num]][0],
                              _colorValue[_colorOn[num]][1],
                              _colorValue[_colorOn[num]][2]);
  FastLED.show();
void main::saveData() {
    uint8_t a = _eepromFlag * 9;
    EEPROM.write(a + 0, _modeData[_eepromFlag]);
    EEPROM.write(a + 1, _channelData[_eepromFlag]);
    EEPROM.write(a + 2, _noteData[_eepromFlag]);
    EEPROM.write(a + 3, _colorOn[_eepromFlag]);
    EEPROM.write(a + 4, _colorOff[_eepromFlag]);
    EEPROM.write(a + 5, _min[_eepromFlag]);
    EEPROM.write(a + 6, _max[_eepromFlag]);
    EEPROM.write(a + 7, _mod[_eepromFlag]);
    EEPROM.write(a + 8, _key[_eepromFlag]);
    Serial.println("ALARM!!! EEPROM WRITE!");
  _eepromFlag = 255;
uint8_t main::getI2cAdress() {
  return _i2cAdress;
oled.h
#define APIN 22
#define BPIN 23
#include <Encoder.h>
Encoder enc(22, 23);
#define ENCBUTTON 21
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, OLED_RESET);
#define RELEASED 0
#define SHORTPRESS 1
#define LONGPRESS 2
bool (*currentAction)(void *ptr1, void *ptr2) = NULL;
void *currentParam1 = NULL;
void *currentParam2 = NULL;
bool value(void *ptr1, void *ptr2);
bool variable(void *ptr1, void *ptr2);
bool toggle(void *ptr1, void *ptr2);
bool Eeprom(void *ptr1, void *ptr2);
void subMenu();
uint8_t pressState = RELEASED;
uint8_t prevPress = HIGH;
uint32_t prevMillisPressed;
uint32_t currentMillisPressed;
uint8_t encVal;
uint8_t encMode;
uint32_t prevMillis;
void oled() {
  if (encMode == 0) {
    encVal = enc.read() / 4;
    encVal = encVal % currentMenu->numItems;
  display.setTextColor(SSD1306_WHITE, SSD1306_BLACK);
  display.setCursor(0, 0);
  display.print(currentMenu->title);
  display.setCursor(0, 16);
  display.print(currentMenu->pStruct[encVal].title);
  if (currentMenu->pStruct[encVal].function != NULL) {
    currentAction = currentMenu->pStruct[encVal].function;
    currentParam1 = currentMenu->pStruct[encVal].data1;
    currentParam2 = currentMenu->pStruct[encVal].data2;
    currentAction(currentParam1, currentParam2);
  if (currentMenu->pStruct[encVal].pStruct != NULL) {
    subMenu();
  if (millis() - prevMillis >= 33) {  // refresh 30 times a second
    display.display();                // slows down midi
    prevMillis = millis();
bool encButton() {
  uint8_t currentPress;
  currentPress = digitalRead(ENCBUTTON);
  if (prevPress == HIGH && currentPress == LOW) {
    currentMillisPressed = millis();
  } else if (prevPress == LOW && currentPress == HIGH) {
    prevMillisPressed = millis();
    uint32_t durationMillisPressed = prevMillisPressed - currentMillisPressed;
    if (durationMillisPressed < 1000) {
      pressState = SHORTPRESS;
    if (durationMillisPressed > 1000) {
      pressState = LONGPRESS;
  prevPress = currentPress;
  return pressState;
void subMenu() {
  if (encButton() == SHORTPRESS) {
    currentMenu = currentMenu->pStruct[encVal].pStruct;
    encVal = 0;
    enc.write(0);
bool value(void *ptr1, void *ptr2) {
  uint8_t *value = (uint8_t *)ptr1;
  display.setCursor(80, 16);
  display.print(*value);
  return true;
bool variable(void *ptr1, void *ptr2) {
  uint8_t data;
  uint8_t *val = (uint8_t *)ptr1;
  uint8_t maxVal = (uint8_t *)ptr2;  // <--- dit is trikky? ------------------------------------------------
  if (encMode == 0) {
    display.print(*val);
      encMode = 1;
      enc.write(*val * 4);
  if (encMode == 1) {
    data = enc.read() / 4;
    data = data % maxVal;
    if (maxVal == 16) {
      *val = data + 1;
      *val = data;
    display.setTextColor(SSD1306_BLACK, SSD1306_WHITE);
      encMode = 0;
  return true;
bool toggle(void *ptr1, void *ptr2) {
  uint8_t *num = (uint8_t *)ptr1;
  String *titles = (String *)ptr2;
  uint8_t i = 0;
  while (titles[i]) {
    i++;
  display.setCursor(75, 16);
  display.print(titles[*num]);
    ++*num;
    if (*num == i) {
      *num = 0;
  return true;
bool eeprom(void *ptr1, void *ptr2) {
  uint8_t *adress = (uint8_t *)ptr1;
  uint8_t *flag = (uint8_t *)ptr2;
    *flag = *adress;
  return true;
pads.cpp
#include "pads.h"
pads::pads() {
  //Serial.print("I created a ");
pads::~pads() {
  //Serial.println("Deleted");
pads.h
#ifndef pads_h
#define pads_h
#define MAIN 0
#define FADERPAD 1
#define ENCODERPAD 2
#define GETTYPE 0
#define GETEEPROM 253
#define SEND2EEPROM 254
//I2C registers faders
#define GET4FADERDATA 1
#define SEND4FADERDATA 2
//I2C registers encoders
#define GETDATA 1
#define SEDNDATA 2
#define I2CCONNECTED 0
#define I2CDISCONNECTED 2
inline String colorNames[9] = { "Red", "Green", "Blue", "Cyan", "Magenta", "Yellow", "Orange", "White" };  // add 1 to array size
inline String modeNames[4] = { "Midi", "Key", "M+K" };                                                     // add 1 to array size
bool eeprom(void *ptr1, void *ptr2);
struct MENUITEMS {
  String title;
  bool (*function)(void *ptr1, void *ptr2);
  void *data1;
  void *data2;
  struct MENU *pStruct;
  /* ~MENUITEMS() {
    Serial.print("create/delete struct items ");
    Serial.println(title);
struct MENU {
  String title;
  uint8_t numItems;
  uint8_t menuVal;
  MENUITEMS *pStruct;
  /*~MENU() {
    Serial.print("create/delete struct Menu");
inline MENUITEMS menuItem[127];
inline MENU padMenu = {
  "-Pads-", 0, 0, &menuItem[0]
inline MENU *currentMenu = &padMenu;
class pads {
public:
  MENUITEMS *menuItemsFunc[16];
  MENU menuFunc[16];
  MENUITEMS *menuItems;
  MENU menu;
  pads();
  virtual ~pads();
  virtual uint8_t scanData() = 0;
  virtual void sendData(uint8_t channelData, uint8_t noteData, uint8_t velocityData) = 0;
  virtual void saveData() = 0;
  virtual uint8_t getI2cAdress() = 0;
class main : public pads {
public:
  main(uint8_t adress);
  ~main();
  uint8_t scanData();
  void sendData(uint8_t channelData, uint8_t noteData, uint8_t velocityData);
  void saveData();
  uint8_t getI2cAdress();
private:
  //CRGB _leds[NUM_LEDS];
  uint8_t _rowPin[4] = { 6, 9, 8, 7 };
  uint8_t _colomPin[4] = { 15, 14, 5, 4 };
  uint8_t _i2cAdress;
  uint8_t _eepromFlag = 255;
  uint8_t _buttonState[16];
  uint8_t _buttonPrev[16];
  uint8_t _id[16] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15 };
  uint8_t _modeData[16];
  uint8_t _channelData[16];
  uint8_t _noteData[16];
  uint8_t _colorOn[16];
  uint8_t _colorOff[16];
  uint8_t _min[16];
  uint8_t _max[16];
  uint8_t _mod[16];
  uint8_t _key[16];
class fader : public pads {
public:
  MENUITEMS *pMenuItemsFunc;
  MENUITEMS *pMenuItems;
  fader(uint8_t adress);
  ~fader();
  uint8_t scanData();
  void saveData();
private:
  uint8_t _i2cAdress;
  uint8_t _dataToSend[4];
  uint8_t _faderState[4];
  uint8_t _faderPrev[4];
  uint8_t _id[4] = { 0, 1, 2, 3 };
  uint8_t _modeData[4];
  uint8_t _channelData[4];
  uint8_t _noteData[4];
  uint8_t _colorOn[4];
  uint8_t _colorOff[4];
  uint8_t _min[4];
  uint8_t _max[4];
class encoderpad : public pads {
public:
  encoderpad(uint8_t adress);
  ~encoderpad();
  uint8_t scanData();
  void saveData();
private:
  uint8_t _i2cAdress;
  uint8_t _dataToSend[12];
  uint8_t _dataState[12];
  uint8_t _dataPrev[12];
  uint8_t _id[12] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 };
  uint8_t _modeData[12];
  uint8_t _channelData[12] = { 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1 };
  uint8_t _noteData[12] = { 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32 };
  uint8_t _colorOn[12];
  uint8_t _colorOff[12];
  uint8_t _min[12];
  uint8_t _max[12];
#endif
// als je een nieuwe class toevoegd moet je alle functies in de nieuwe class(.cpp) stoppen anders krijg je irittante fout melding.
macropad_faders.ino
//nologo esp32c3 supermini
#include <Wire.h>
#include <EEPROM.h>
#define NUM_LEDS 12
#define DATA_PIN 10
CRGB leds[NUM_LEDS];
#define FADER1 A0
#define FADER2 A1
#define FADER3 A2
#define FADER4 A3
uint8_t faderPin[4] = { A0, A1, A2, A3 };
uint16_t analogState[4];
uint16_t prevanalog[4];
#define FADER 1 //3
uint8_t receiveVal = 0;
uint8_t fadervalRev[4];
  //delay(3000);
  //Serial.begin(115200);
  EEPROM.begin(28);
  Wire.begin(3);  // fader 1, encoder 2, fader 3
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  //while (!Serial);
  FastLED.addLeds<SK6812, DATA_PIN, GRB>(leds, NUM_LEDS);
  for (uint8_t z = 0; z < 12; z++) {
    leds[z] = CRGB(10, 10, 1);
  FastLED.show();
  /*for(uint8_t x = 0; x < 50; x++){
    EEPROM.write(x,0);
  EEPROM.commit();*/
  leds[0] = CRGB(fadervalRev[0], fadervalRev[0], fadervalRev[0]);
  leds[1] = CRGB(fadervalRev[0], fadervalRev[0], fadervalRev[0]);
  leds[2] = CRGB(fadervalRev[0], fadervalRev[0], fadervalRev[0]);
  leds[3] = CRGB(fadervalRev[1], fadervalRev[1], fadervalRev[1]);
  leds[4] = CRGB(fadervalRev[1], fadervalRev[1], fadervalRev[1]);
  leds[5] = CRGB(fadervalRev[1], fadervalRev[1], fadervalRev[1]);
  leds[6] = CRGB(fadervalRev[2], fadervalRev[2], fadervalRev[2]);
  leds[7] = CRGB(fadervalRev[2], fadervalRev[2], fadervalRev[2]);
  leds[8] = CRGB(fadervalRev[2], fadervalRev[2], fadervalRev[2]);
  leds[9] = CRGB(fadervalRev[3], fadervalRev[3], fadervalRev[3]);
  leds[10] = CRGB(fadervalRev[3], fadervalRev[3], fadervalRev[3]);
  leds[11] = CRGB(fadervalRev[3], fadervalRev[3], fadervalRev[3]);
  FastLED.show();
  for (uint8_t i = 0; i < 4; i++) {
    if (analogRead(faderPin[i]) < (prevanalog[i] - 30) || analogRead(faderPin[i]) > (prevanalog[i] + 30)) {
      prevanalog[i] = analogRead(faderPin[i]);
      analogState[i] = analogRead(faderPin[i]) / 32;
void receiveEvent(int howMany) {
  if (Wire.available()) {
    receiveVal = Wire.read();
    //Serial.println(receiveVal);
  switch (receiveVal) {
    case 2:
        fadervalRev[x] = Wire.read();
    case 254:
      for (uint8_t x = 0; x < 28; x++) {
        uint8_t t = Wire.read();
        EEPROM.write(x, t);
      EEPROM.commit();
      //Serial.println("ALARM!!! EEPROM WRITE!");
void requestEvent() {
    case 0:
      Wire.write(FADER);  // type = "1" FADERPAD
    case 1:
          Wire.write(analogState[x]);
    case 253:
          Wire.write(EEPROM.read(x));
macropad_encoder.ino
// miso 5
// mosi 6
// ss 7 MCP23C17
// SDA 8
// SCL 9
// SS2 10 LCD
// INT 20
// CLK 4
// encButtons 3,A3  -  r17 1k, r18 2k , r19 3k , r20 10k
// reset 2,A2 LCD
// DC 1,A1
// LED 0,A0
#define ENCODER 2
#include <Wire.h>
#define NUM_LEDS 12
#define DATA_PIN 0
#include "MCP23S17.h"
MCP23S17 MCP(7);
#include <U8g2lib.h>
#include <SPI.h>
U8G2_SH1122_256X64_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/10, /* dc=*/1, /* reset=*/2);
//U8G2_SH1122_256X64_F_4W_HW_SPI u8g2(U8G2_R0, /* clock=*/ 4, /* data=*/ 6, /* cs=*/ 10, /* dc=*/ 1, /* reset=*/ 2);
int16_t encoderVal[4];
uint8_t aLastState[4];
uint8_t buttonState[8];
uint8_t buttonPrev[8];
uint8_t receiveVal;
uint32_t prevtime;
  pinMode(20, INPUT);
  Wire.begin(2);
  FastLED.addLeds<SK6812, DATA_PIN, RGB>(leds, NUM_LEDS);
  FastLED.show();
  Serial.print("MCP23S17_LIB_VERSION: ");
  Serial.println(MCP23S17_LIB_VERSION);
  delay(100);
  SPI.begin();
  u8g2.begin();
  u8g2.clearBuffer();                   // clear the internal memory
  u8g2.setFont(u8g2_font_ncenB08_tr);   // choose a suitable font
  u8g2.drawStr(0, 50, "Hello World!");  // write something to the internal memory
  u8g2.sendBuffer();
  MCP.begin();
  MCP.pinMode8(0, 0xFF);
  MCP.pinMode8(1, 0xFF);
  encoder(&encoderVal[0], &aLastState[0], 7, 6);
  encoder(&encoderVal[1], &aLastState[1], 5, 4);
  encoder(&encoderVal[2], &aLastState[2], 3, 2);
  encoder(&encoderVal[3], &aLastState[3], 1, 0);
  for (uint8_t x = 0; x < 8; x++) {
    uint8_t currentState = MCP.read1(x + 8);
    if (currentState != buttonPrev[x]) {
      if (currentState == HIGH) {
        buttonState[x] = 0;
        buttonState[x] = 127;
    buttonPrev[x] = currentState;
    uint32_t time = millis();
  if (time - prevtime >= 33) {
    prevtime = time;
    u8g2.clearBuffer();
    u8g2.setCursor(0, 15);
    u8g2.print(u8g2_u8toa((uint8_t)(encoderVal[0]), 3));
    u8g2.sendBuffer();
void encoder(int16_t *val, uint8_t *last, uint8_t pin1, uint8_t pin2) {
  uint8_t aState = MCP.read1(pin1);
  if (aState != *last) {
    if (MCP.read1(pin2) != aState) {
      //++*val;
      *val = *val + 4;
      //--*val;
      *val = *val - 4;
    *last = aState;
    *val = constrain(*val, 0, 127);
    case 2:
        encoderVal[x] = Wire.read();
        buttonState[x] = Wire.read();
      /*case 254:
        EEPROM.write(x, t);
      EEPROM.commit();
      break;*/
    case 0:
      Wire.write(ENCODER);  // type = 2 ENCODERPAD
    case 1:
      Wire.write(encoderVal[0]);
      Wire.write(encoderVal[1]);
      Wire.write(encoderVal[2]);
      Wire.write(encoderVal[3]);
      Wire.write(buttonState[0]);
      Wire.write(buttonState[1]);
      Wire.write(buttonState[2]);
      Wire.write(buttonState[3]);
      Wire.write(buttonState[4]);
      Wire.write(buttonState[5]);
      Wire.write(buttonState[6]);
      Wire.write(buttonState[7]);
code seems to work fine the issue is the order of power up, with or without extra pad
You can isolate those pins with an analog switch such as the CD4066. Pull all the control pins down (all can be connected together) with maybe a 10K or whatever you have handy. Then connect that junction to an unused port pin. After boot you can set that pin high and the connection will be made. You only need two of the 4 switches.
maby this will make it more clear.
https://www.dropbox.com/scl/fi/p7two929radojcejxefom/WhatsApp-Video-2025-12-10-at-21.14.32.mp4?rlkey=dqs18mzxsy5qedh5soyhso9uv&st=5xsvmwks&dl=0
i have also been thinking about a switch but i think it easyer to add a mosfet to the power rail of the main pad(teensy4.0) so it will turn on the other pads with a delay.
but if i can get it working without will mean i dont need to make a new pcb :grin:
If you can isolate the I2C lines by cutting some traces or drilling some vias you can use the tried and true "blue wire mod" to wire to unused GPIO pins. You may have to do something about pull ups as well.
:thinking: the issue is the encoder pad only has one pin left "TX" so i can debug.
and sorry did not say that but i allready added pull ups and tried different values.
Ah, sorry, I missed that.
ok i bodged a mosfet on one of the gnd pins of the pogopins controlled by the teensy so the ESP32C3 gets power with a small delay and now it all works great!
I'm glad you found a usable workaround. It's a professional looking project. I didn't realize the magnetic pogo pins were so readily available and will keep them in mind for a future project.
thanks you! just a hobbyist that found out about arduino 15 years ago :sweat_smile:
and about the pogopins the magnets are pretty weak. so i added 2 more magnets hidden inside the 3dprint on each side to get a more secure connection.
