HelloUse code tags to format code for the forum
I have an arduino nano that transmits data via ibus to a flysky i6 radio control. I use a gps neo 6m that sends data to the radio control, I can save several points in the eeprom and read again with a certain button. The problem is that I don't have the correct distance displayed from home point 0 to the selected point. Can someone help me? Thank you
#include <iBUSTelemetry.h>
#include <EEPROM.h>
#include <TinyGPS++.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
/* Assign a unique ID to this sensor at the same time */
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
const int ledPin = 2;
const int led2Pin = 8;
const int buzzerPin = 10; // Pinul pentru buzzer
const int swaPin = 3; // Pin pentru SWA
const int swbPin = 7; // Pin pentru SWB
const int swcPin = 5; // Pin pentru SWC
const int swdPin = 6; // Pin pentru SWD
#define TRIG 11 // Module pins
#define ECHO 12
TinyGPSPlus gps; // DHLWSH GPS
#define UPDATE_INTERVAL 100 //
iBUSTelemetry telemetry(9); //
uint32_t prevMillis = 0; //
volatile uint8_t countSatelite = 0;
const int maxSavedPoints = 10;
int currentPointIndex = 0; // Indexul punctului curent
struct GPSPoint {
double latitude;
double longitude;
GPSPoint savedPoints[maxSavedPoints];
// Adăugare pentru punctul Home
GPSPoint homePoint = {0.0, 0.0}; // Coordonate inițiale pentru punctul Home
double startpoint_lat = -4.409;
double startpoint_lon = +4.678;
double TXdistanceRX = 7, i = 6;
long heading = 0; // modificare: initializam heading cu 0 pentru a incepe de la 0
double offsetX = 0.0, offsetY = 0.0, offsetZ = 0.0;
pinMode(ledPin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(buzzerPin, OUTPUT); // Configurează pinul buzzerului ca ieșire
pinMode(TRIG, OUTPUT); // Initializing Trigger Output and Echo Input
pinMode(ECHO, INPUT_PULLUP);
pinMode(swcPin, INPUT_PULLUP);
pinMode(swdPin, INPUT_PULLUP);
Serial.println("HMC5883 Magnetometer Test");
Serial.println("");
/* Initialise the sensor */
if (!mag.begin()) {
/* There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while (1);
telemetry.begin();
// sensor definition
telemetry.addSensor(0x01); // temp
telemetry.addSensor(IBUS_MEAS_TYPE_GPS_ALT);
telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LAT);
telemetry.addSensor(IBUS_MEAS_TYPE_GPS_LON);
telemetry.addSensor(0x14); // distance
telemetry.addSensor(IBUS_MEAS_TYPE_GPS_STATUS); // satellite status
telemetry.addSensor(0x13); // speed m/s
telemetry.addSensor(0x7e); // Speed in km/hr
telemetry.addSensor(0x7e); // GPS Full
telemetry.addSensor(IBUS_MEAS_TYPE_CMP_HEAD); // Heading
telemetry.addSensor(IBUS_MEAS_TYPE_COG);// course over ground
telemetry.addSensor(IBUS_MEAS_TYPE_ACC_X); // Acc X
telemetry.addSensor(IBUS_MEAS_TYPE_ACC_Y); // Acc Y
telemetry.addSensor(IBUS_MEAS_TYPE_ACC_Z); // Acc Z
telemetry.addSensor(0x85); // Address 0x84 for displaying current point index
telemetry.addSensor(0x07); // Address 0x84 for displaying current point index
calibrateCompass();
updateValues();
telemetry.run();
bool inited = false;
int readNo = 0;
double latitude = 0, longitude = 0, destLat = 0, destLong = 0;
double X = 0, Y = 0, Z = 0;
bool isSatelliteFound = false;
void compassHeadingToDestination(double currentLat, double currentLon, double destLat, double destLon) {
double dLon = destLon - currentLon;
double y = sin(dLon) * cos(destLat);
double x = cos(currentLat) * sin(destLat) - sin(currentLat) * cos(destLat) * cos(dLon);
double brng = atan2(y, x);
brng = fmod((brng + 2 * M_PI), (2 * M_PI)); // Asigurați-vă că unghiul este întotdeauna pozitiv
brng = brng * 180 / M_PI;
double headingToDest = brng;
if (headingToDest < 0) {
headingToDest += 360;
telemetry.setSensorValue(9, headingToDest);
int readDistance() {
digitalWrite(TRIG, LOW);
delayMicroseconds(2);
digitalWrite(TRIG, HIGH);
delayMicroseconds(20);
float distance = pulseIn(ECHO, HIGH, 26000);
distance = distance / 58;
return distance;
// Funcție pentru salvarea locației GPS în EEPROM
void saveLocation(int index) {
if (index < 0 || index >= maxSavedPoints) {
Serial.println("Index invalid pentru salvare!");
return;
int addr = index * sizeof(GPSPoint);
EEPROM.put(addr, savedPoints[index]);
Serial.print("Locație salvată la indexul: ");
Serial.println(index);
// Funcție pentru salvarea punctului Home
void saveHomePoint() {
homePoint.latitude = gps.location.lat();
homePoint.longitude = gps.location.lng();
EEPROM.put(0, homePoint);
Serial.println("Punctul Home a fost salvat!");
// Funcție pentru recuperarea locației GPS din EEPROM
void updateValues() {
uint32_t currMillis = millis();
if (Serial.available()) {
gps.encode(Serial.read());
if (!inited) {
if (gps.location.isValid()) {
startpoint_lat = gps.location.lat();
startpoint_lon = gps.location.lng();
inited = true;
readNo = 0;
TXdistanceRX = 3;
if (currMillis - prevMillis >= UPDATE_INTERVAL) {
prevMillis = currMillis;
sensors_event_t event;
mag.getEvent(&event);
X = event.magnetic.x - offsetX;
Y = event.magnetic.y - offsetY;
Z = event.magnetic.z - offsetZ;
float heading = atan2(event.magnetic.y, event.magnetic.x);
float declinationAngle = 0.22;
heading += declinationAngle;
if (heading < 0)
heading += 2 * PI;
if (heading > 2 * PI)
heading -= 2 * PI;
float headingDegrees = heading * 180 / M_PI;
int headDir = (int)headingDegrees;
if (headingDegrees < 0)
headingDegrees += 360;
float sonicDistance = readDistance();
telemetry.setSensorValue(1, (i * 10));
telemetry.setSensorValue(2, sonicDistance);
telemetry.setSensorValue(3, ((latitude = gps.location.lat() ) * 10000000));
telemetry.setSensorValue(4, ((longitude = gps.location.lng() ) * 10000000));
if (gps.satellites.isValid()) {
telemetry.setSensorValue(6, min(gps.satellites.value(), 25));
telemetry.setSensorValue(6, 0);
telemetry.setSensorValue(7, (gps.speed.value()));
telemetry.setSensorValueFP(8, gps.speed.kmph());
telemetry.setSensorValue(9, headDir);
telemetry.setSensorValue(10, TinyGPSPlus::courseTo(latitude, longitude, destLat, destLong));
telemetry.setSensorValue(11, X);
telemetry.setSensorValue(12, Y);
telemetry.setSensorValue(13, Z);
telemetry.setSensorValue(0x85, currentPointIndex + 1);
telemetry.setSensorValue(0x0f, currentPointIndex + 1);
i += 0.1;
if (i > 50)
i = 0;
if (gps.satellites.value() >= 4 && !isSatelliteFound) {
isSatelliteFound = true;
tone(buzzerPin, 1000, 1500);
delay(1500);
noTone(buzzerPin);
int swaVal = pulseIn(swaPin, HIGH, 30000);
if (swaVal > 1500) {
digitalWrite(ledPin, HIGH);
saveLocation(currentPointIndex);
digitalWrite(ledPin, LOW);
int swbVal = pulseIn(swbPin, HIGH, 30000);
if (swbVal > 1500) {
digitalWrite(led2Pin, HIGH);
getSavedLocation(currentPointIndex);
compassHeadingToDestination(latitude, longitude, destLat, destLong);
TXdistanceRX = TinyGPSPlus::distanceBetween(gps.location.lat(), gps.location.lng(), destLat, destLong);
telemetry.setSensorValue(5, TXdistanceRX);
digitalWrite(led2Pin, LOW);
// Modificare pentru SWC și SWD pe pini digitali
static unsigned long lastDebounceTimeSWC = 0;
static unsigned long lastDebounceTimeSWD = 0;
const unsigned long debounceDelay = 200; // Întârziere pentru debounce
if (digitalRead(swcPin) == LOW && millis() - lastDebounceTimeSWC > debounceDelay) {
currentPointIndex = (currentPointIndex + 1) % maxSavedPoints;
lastDebounceTimeSWC = millis();
Serial.print("Punct curent: ");
Serial.println(currentPointIndex + 1);
if (digitalRead(swdPin) == LOW && millis() - lastDebounceTimeSWD > debounceDelay) {
currentPointIndex = (currentPointIndex - 1 + maxSavedPoints) % maxSavedPoints;
lastDebounceTimeSWD = millis();
void getSavedLocation(int index) {
Serial.println("Index invalid pentru recuperare!");
return;
EEPROM.get(addr, savedPoints[index]);
destLat = savedPoints[index].latitude;
destLong = savedPoints[index].longitude;
Serial.print("Locație încărcată de la indexul: ");
Serial.print("Latitudine: ");
Serial.println(destLat, 6);
Serial.print("Longitudine: ");
Serial.println(destLong, 6);
void calibrateCompass() {
Serial.println("Începeți calibrarea busolei. Vă rugăm să rotiți și să mișcați senzorul lent în toate direcțiile.");
float minX = 1000, minY = 1000, minZ = 1000;
float maxX = -1000, maxY = -1000, maxZ = -1000;
for (int i = 0; i < 1000; i++) {
minX = min(minX, event.magnetic.x);
minY = min(minY, event.magnetic.y);
minZ = min(minZ, event.magnetic.z);
maxX = max(maxX, event.magnetic.x);
maxY = max(maxY, event.magnetic.y);
maxZ = max(maxZ, event.magnetic.z);
offsetX = (maxX + minX) / 2;
offsetY = (maxY + minY) / 2;
offsetZ = (maxZ + minZ) / 2;
Serial.println("Calibrare completă.");
