I'm looking for an IC, which I could use to create a timer clock.
I need to do an endless cycle similar to on (4h), off (10 min), on (4h), off (10 min)...
Can anyone point me in a direction? I read that the timer 555 is not suitable for such long times.
Not sure what you are trying to do. Are you are just looking for a programmable timer something like these. https://www.amazon.com/s?k=programmable+timer
Or are you looking to build something as a project?
What about MCU, like some arduino? If local real time doesn't matter, that's easy alternative to 555. If you need to know certain time of the day, you want battery backed RTC module or MCU that can get the time from internet or from GPS.
Yes, of course I could use a MC, but I hoped there would be something cheaper which you don‘t need to program first. In my mind I have a few ideas for lighting projects, but I would need a easy solution (maybe a 20x20mm PCB).
@van_der_decken solution is around a buck for 1. The code is there so no code to write. If you want to do it with discrete chips you will need several.
I thought you could set the values with resistors. But ok, I see, it is probably easier to use a MC such as ATtiny85.
So far I have only used Arduino boards, but never a MC alone. How can I program it easily? What could I do for higher quantities? Does JLCPCB or PCBWAY offer some service for programming in higher quantities?
Ah, and it is ok if it starts right after powering up, without any delay!
It's not that difficult to design a PCB, but if you're going mass production, cost is obviously prio no 1. I'm not sure if the PCB manufacturers offer programming, but since they offer all sorts of services nowadays I wouldn't be surprised if they can do that as well. Otherwise you need a way to connect to the board in order to interface with the MCU.
With that requirement only an MCU is needed. Btw, how much drift is ok for those 4 h / 10 min?
Then you will be just fine with the internal clock at 1 or 8 MHz, it will keep cost down as well.
With an ATTiny, ceramic capacitor rated 0.1 u or similar, breadboard and some jumper wires you can start prototype, and you already got a suggestion for the code.
Uploading the code will be different than how you normally do, you need a programmer. A regular Arduino Uno / Nano for example can be used as such.
