ICMP Ping Error
My hardware are UNO R3 and Ethernet Shield W5100. I use it with basic sketch
Ping Example
This example sends an ICMP pings every 500 milliseconds, sends the human-readable
result over the serial port.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 30 Sep 2010
by Blake Foster
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // max address for ethernet shield
byte ip[] = {192,168,2,177}; // ip address for ethernet shield
IPAddress pingAddr(74,125,26,147); // ip address to ping
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
  // start Ethernet
  Ethernet.begin(mac, ip);
  ICMPEchoReply echoReply = ping(pingAddr, 4);
  if (echoReply.status == SUCCESS)
    sprintf(buffer,
            "Reply[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d",
            echoReply.data.seq,
            echoReply.addr[0],
            echoReply.addr[1],
            echoReply.addr[2],
            echoReply.addr[3],
            REQ_DATASIZE,
            millis() - echoReply.data.time,
            echoReply.ttl);
    sprintf(buffer, "Echo request failed; %d", echoReply.status);
  Serial.println(buffer);
and ICMP library from
https://github.com/BlakeFoster/Arduino-Ping/archive/version2.0.zip
when I apply all thing on my PC. There are error
C:\Program Files (x86)\Arduino\libraries\icmp_ping\ICMPPing.cpp: In member function 'void ICMPPing::receiveEchoReply(const ICMPEcho&, const IPAddress&, ICMPEchoReply&)':
C:\Program Files (x86)\Arduino\libraries\icmp_ping\ICMPPing.cpp:177: error: invalid conversion from 'uint16_t' to 'volatile uint8_t*'
C:\Program Files (x86)\Arduino\libraries\icmp_ping\ICMPPing.cpp:177: error:   initializing argument 2 of 'void W5100Class::read_data(SOCKET, volatile uint8_t*, volatile uint8_t*, uint16_t)'
C:\Program Files (x86)\Arduino\libraries\icmp_ping\ICMPPing.cpp:185: error: invalid conversion from 'uint16_t' to 'volatile uint8_t*'
C:\Program Files (x86)\Arduino\libraries\icmp_ping\ICMPPing.cpp:185: error:   initializing argument 2 of 'void W5100Class::read_data(SOCKET, volatile uint8_t*, volatile uint8_t*, uint16_t)'
How can I fix those thing? or Are there any workable sketch example? please advise me.
Try this. If this works, you won't have to dig through the library to fix the code.
// change this
// to this
byte pingAddr[] = {74,125,26,147}; // ip address to ping
edit: I tried it and it didn't work. You must download the most recent version. It has the fix to the library so you won't have to do it.
