I have an Arduino Uno with an Ethernet shield. I have installed the ICMPPing library and trying to use the included example. Changed my IP address, etc.
Ping Example
This example sends an ICMP pings every 500 milliseconds, sends the human-readable
result over the serial port.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 30 Sep 2010
by Blake Foster
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED}; // max address for ethernet shield
byte ip[] = {10,1,1,177}; // ip address for ethernet shield
IPAddress pingAddr(10,1,1,101); // ip address to ping
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
// start Ethernet
Ethernet.begin(mac, ip);
ICMPEchoReply echoReply = ping(pingAddr, 4);
if (echoReply.status == SUCCESS)
sprintf(buffer,
"Reply[%d] from: %d.%d.%d.%d: bytes=%d time=%ldms TTL=%d",
echoReply.data.seq,
echoReply.addr[0],
echoReply.addr[1],
echoReply.addr[2],
echoReply.addr[3],
REQ_DATASIZE,
millis() - echoReply.data.time,
echoReply.ttl);
sprintf(buffer, "Echo request failed; %d", echoReply.status);
Serial.println(buffer);
When I try to load the sketch I get the following error message.
Arduino: 1.5.6-r2 (Windows 7), Board: "Arduino Uno"
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp: In member function 'void ICMPEcho::serialize(uint8_t*) const':
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp:71: error: 'htons' was not declared in this scope
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp:74: error: 'htonl' was not declared in this scope
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp: In member function 'void ICMPEcho::deserialize(const uint8_t*)':
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp:84: error: 'ntohs' was not declared in this scope
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp:90: error: 'ntohl' was not declared in this scope
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp: In member function 'void ICMPPing::receiveEchoReply(const ICMPEcho&, const IPAddress&, ICMPEchoReply&)':
E:\Program Files (x86)\Arduino\libraries\ICMPPing\ICMPPing.cpp:219: error: 'ntohs' was not declared in this scopeThis report would have more information with
enabled in File > Preferences.
Fairly new at this. Any suggestions?
thanks
