Continuing the discussion from No ports discovered Arduino IDE 2.0.3:
Very frustrating when it says: topic solved.
I connect MKRzero, upload simple sketch and it runs once. Then after I safe file, uploading again fails (actually IDE hangs!).
Hi @rnieuwland. I'm sorry to hear you're having troubles with uploading.
I'm going to ask you to post the full verbose output from an upload.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
☑ compilation in the "Preferences" dialog.<CODE/> icon on the post composer toolbar.```) to your reply to make sure the error messages are correctly formatted.
Connect first time to USB. UPLOAD RESULT:
FQBN: arduino:samd:mkrzero
Using board 'mkrzero' from platform in folder: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Using core 'arduino' from platform in folder: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13
Detecting libraries used...
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Alternatives for Adafruit_BMP3XX.h: [Adafruit BMP3XX Library@2.1.2]
ResolveLibrary(Adafruit_BMP3XX.h)
-> candidates: [Adafruit BMP3XX Library@2.1.2]
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.14.3]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit BusIO@1.14.3]
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Alternatives for SD.h: [SD@1.2.4 SD@1.2.4]
ResolveLibrary(SD.h)
-> candidates: [SD@1.2.4 SD@1.2.4]
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire\Wire.cpp
Using cached library dependencies for file: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library\Adafruit_BMP3XX.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library\bmp3.c
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src\File.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src\utility\Sd2Card.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src\utility\SdFile.cpp
Using cached library dependencies for file: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src\utility\SdVolume.cpp
Generating function prototypes...
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\robbi\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Wire\Wire.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit BMP3XX Library"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-gcc" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library\bmp3.c" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BMP3XX_Library\bmp3.c.o"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library\Adafruit_BMP3XX.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BMP3XX_Library\Adafruit_BMP3XX.cpp.o"
Compiling library "Adafruit BusIO"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++11 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD -DF_CPU=48000000L -DARDUINO=10607 -DARDUINO_SAMD_MKRZERO -DARDUINO_ARCH_SAMD -DUSE_ARDUINO_MKR_PIN_LAYOUT -D__SAMD21G18A__ -DUSB_VID=0x2341 -DUSB_PID=0x804f -DUSBCON "-DUSB_MANUFACTURER="Arduino LLC"" "-DUSB_PRODUCT="Arduino MKRZero"" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Include/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS-Atmel\1.2.0/CMSIS/Device/ATMEL/" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino/api/deprecated-avr-comp" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire" "-IC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO" "-IC:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD\src" "C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp" -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o"
Compiling library "SD"
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\SD.cpp.o
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\SdFile.cpp.o
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\File.cpp.o
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\SdVolume.cpp.o
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\Sd2Card.cpp.o
Compiling core...
Using previously compiled file: C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\core\variant.cpp.o
Using precompiled core: C:\Users\robbi\AppData\Local\Temp\arduino\cores\arduino_samd_mkrzero_966c5e02bda2ba7032828b5187ef440b\core.a
Linking everything together...
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++" "-LC:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588" -Os -Wl,--gc-sections -save-temps "-TC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\variants\mkrzero/linker_scripts/gcc/flash_with_bootloader.ld" "-Wl,-Map,C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.map" --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -o "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.elf" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\sketch\ZERO_BMP388_SD.ino.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Wire\Wire.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SPI\SPI.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BMP3XX_Library\Adafruit_BMP3XX.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BMP3XX_Library\bmp3.c.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\File.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\SD.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\Sd2Card.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\SdFile.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\libraries\SD\utility\SdVolume.cpp.o" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588\core\variant.cpp.o" -Wl,--start-group "-LC:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\CMSIS\4.5.0/CMSIS/Lib/GCC/" -larm_cortexM0l_math -lm "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/..\..\cores\arduino_samd_mkrzero_966c5e02bda2ba7032828b5187ef440b\core.a" -Wl,--end-group
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O binary "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.elf" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.bin"
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.elf" "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.hex"
Multiple libraries were found for "SD.h"
Used: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD
Not used: C:\Users\robbi\AppData\Local\Arduino15\libraries\SD
Using library Wire at version 1.0 in folder: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\libraries\SPI
Using library Adafruit BMP3XX Library at version 2.1.2 in folder: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BMP3XX_Library
Using library Adafruit BusIO at version 1.14.3 in folder: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\Adafruit_BusIO
Using library SD at version 1.2.4 in folder: C:\Users\robbi\OneDrive\Documenten\Arduino\libraries\SD
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-size" -A "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.elf"
Sketch uses 46732 bytes (17%) of program storage space. Maximum is 262144 bytes.
Global variables use 4464 bytes (13%) of dynamic memory, leaving 28304 bytes for local variables. Maximum is 32768 bytes.
Performing 1200-bps touch reset on serial port COM3
Waiting for upload port...
Upload port found on COM4
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe" -i -d --port=COM4 -U true -i -e -w -v "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.bin" -R
Set binary mode
readWord(addr=0)=0x20007ffc
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10010305
version()=v2.0 [Arduino:XYZ] Dec 20 2016 15:36:46
chipId=0x10010005
Connected at 921600 baud
Atmel SMART device 0x10010005 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMD21G18A
Chip ID : 10010005
Version : v2.0 [Arduino:XYZ] Dec 20 2016 15:36:46
Address : 8192
Pages : 3968
Page Size : 64 bytes
Total Size : 248KB
Planes : 1
Lock Regions : 16
Locked : readWord(addr=0x41004020)=0xffff
none
readWord(addr=0x41004018)=0
Security : false
Boot Flash : true
readWord(addr=0x40000834)=0x7000a
BOD : true
BOR : true
Arduino : FAST_CHIP_ERASE
Arduino : FAST_MULTI_PAGE_WRITE
Arduino : CAN_CHECKSUM_MEMORY_BUFFER
Erase flash
chipErase(addr=0x2000)
done in 0.823 seconds
Write 46732 bytes to flash (731 pages)
write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x2000, size=0x1000)
[== ] 8% (64/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x3000, size=0x1000)
[===== ] 17% (128/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x4000, size=0x1000)
[======= ] 26% (192/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x5000, size=0x1000)
[========== ] 35% (256/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x6000, size=0x1000)
[============= ] 43% (320/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x7000, size=0x1000)
[=============== ] 52% (384/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x8000, size=0x1000)
[================== ] 61% (448/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0x9000, size=0x1000)
[===================== ] 70% (512/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xa000, size=0x1000)
[======================= ] 78% (576/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xb000, size=0x1000)
[========================== ] 87% (640/731 pages)write(addr=0x20005000,size=0x1000)
writeBuffer(scr_addr=0x20005000, dst_addr=0xc000, size=0x1000)
[============================ ] 96% (704/731 pages)write(addr=0x20005000,size=0x6c0)
writeBuffer(scr_addr=0x20005000, dst_addr=0xd000, size=0x6c0)
[==============================] 100% (731/731 pages)
done in 0.375 seconds
Verify 46732 bytes of flash with checksum.
checksumBuffer(start_addr=0x2000, size=0x1000) = 4948
checksumBuffer(start_addr=0x3000, size=0x1000) = 2ac4
checksumBuffer(start_addr=0x4000, size=0x1000) = 3563
checksumBuffer(start_addr=0x5000, size=0x1000) = 82fc
checksumBuffer(start_addr=0x6000, size=0x1000) = 6f57
checksumBuffer(start_addr=0x7000, size=0x1000) = b9c4
checksumBuffer(start_addr=0x8000, size=0x1000) = 7306
checksumBuffer(start_addr=0x9000, size=0x1000) = 8cfe
checksumBuffer(start_addr=0xa000, size=0x1000) = 1462
checksumBuffer(start_addr=0xb000, size=0x1000) = 2fef
checksumBuffer(start_addr=0xc000, size=0x1000) = 34ae
checksumBuffer(start_addr=0xd000, size=0x68c) = c52f
Verify successful
done in 0.042 seconds
CPU reset.
writeWord(addr=0xe000ed0c,value=0x5fa0004)
SECOND UPLOAD IDE hangs:
Compiling sketch...
Compiling core...
No upload port found, using COM3 as fallback
"C:\Users\robbi\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.7.0-arduino3/bossac.exe" -i -d --port=COM3 -U true -i -e -w -v "C:\Users\robbi\AppData\Local\Temp\arduino\sketches\BDE0FE8FEAD443FF8D8DFB53673A3588/ZERO_BMP388_SD.ino.bin" -R
Another attempt:
Compiling sketch...
Compiling core...
Performing 1200-bps touch reset on serial port COM4
No upload port found, using COM4 as fallback
Set binary mode
chipId=0x10010005
Chip ID : 10010005
Address : 8192
Pages : 3968
Total Size : 248KB
Planes : 1
Lock Regions : 16
none
Security : false
Boot Flash : true
BOD : true
BOR : true
Erase flash
done in 0.822 seconds
done in 0.361 seconds
checksumBuffer(start_addr=0x2000, size=0x1000) = 51a9
Verify successful
done in 0.043 seconds
CPU reset.
