IDE hangs on startup: "connectex: A connection attempt failed because the connected party did not properly respond after a period of time ..."
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
PS C:\Program Files\Arduino IDE> Starting backend process. PID: 8772
PS C:\Program Files\Arduino IDE> eragent in non-browser environment
PS C:\Program Files\Arduino IDE> daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-26T16:17:46+05:30"} Configuration directory URI: 'file:///c%3A/Users/Chinthaka/.theia'
{"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-26T16:17:46+05:30"} INFO Backend Object.configure: 3.6 ms [Finished 1.241 s after backend start]
{"level":"info","msg":"Updating index","time":"2022-10-26T16:17:46+05:30","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}aceServer.onStart: 0.3 ms [Finished 1.295 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.2 ms [Finished 1.295 s after backend start]
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-26T16:18:28+05:30"}um 50 milliseconds: 53.5
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-26T16:18:28+05:30"}d ElectronTokenBackendContribution.configure: 1.4 ms [Finished 1.297 s after backend start]
{"level":"info","msg":"Updating index","time":"2022-10-26T16:18:28+05:30","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}dSecurityWarnings.initialize: 0.4 ms [Finished 1.299 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.1 ms [Finished 1.300 s after backend start]
[10868:1026/161903.038:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
root ERROR Uncaught Exception: m C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\ard
root ERROR Error: 13 INTERNAL: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.json.gz': Get "https://downloads.arduino.cc/libraries/library_index.json.gz": dial tcp 104.18.12.241:443: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.[Finished 1.301 s after backend start]
    at Object.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26) Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 1.303 s after backend start]
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:349:49)O Backend HostedPluginReader.configure: 0.3 ms [Finished 1.304 s after backend start]
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:328:181)terBackendContribution.configure: 0.9 ms [Finished 1.306 s after backend start]
    at C:\Program Files\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:187:78
    at processTicksAndRejections (node:internal/process/task_queues:78:11)after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/Chinthaka/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/Chinthaka/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\Chinthaka\.arduinoProIDE\plugins does not exist.
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root INFO ---- DURATION: loadCliConfig took 61.223 ms. Args: [] ----
root INFO Resolve plugins list: 69.8 ms [Finished 1.372 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 15.1 ms [Finished 1.387 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\Chinthaka\\.arduinoIDE\\arduino-cli.yaml","time":"2022-10-26T16:17:04+05:30"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-10-26T16:17:04+05:30"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-10-26T16:17:04+05:30"}
daemon INFO {"IP":"127.0.0.1","Port":"54089"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 35.7 ms [Finished 1.423 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 21.7 ms [Finished 1.445 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 7.3 ms [Finished 1.452 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: C:\\Users\\Chinthaka\\AppData\\Local\\Arduino15\\packages","time":"2022-10-26T16:17:04+05:30"}
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Chinthaka\AppData\Local\Arduino15\package_index.json: open C:\Users\Chinthaka\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Chinthaka\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
daemon INFO {"index":"C:\\Users\\Chinthaka\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-10-26T16:17:04+05:30"}
{"dir":"C:\\Users\\Chinthaka\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-10-26T16:17:04+05:30"}
{"dir":"C:\\Users\\Chinthaka\\Documents\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-10-26T16:17:04+05:30"}
root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 13.0 ms [Finished 1.465 s after backend start]
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-10-26T16:17:04+05:30"}
{"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-10-26T16:17:04+05:30"}
{"level":"info","msg":"Updating index","time":"2022-10-26T16:17:04+05:30","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 145.2 ms [Finished 1.611 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 105.1 ms [Finished 1.716 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 109.9 ms [Finished 1.826 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 99.4 ms [Finished 1.925 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 74.0 ms [Finished 1.999 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 74.7 ms [Finished 2.074 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 23.3 ms [Finished 2.097 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 102.1 ms [Finished 2.199 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 102.7 ms [Finished 2.302 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 74.3 ms [Finished 2.376 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 72.0 ms [Finished 2.448 s after backend start]
root INFO Deploy plugins list: 69.8 ms [Finished 2.457 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 169.7 ms [Finished 1.848 s after frontend start]
Hi @chinthakara.
Does this error still occur if you try starting the Arduino IDE again now?
This type of error might sometimes be caused by a transient network outage. These usually resolve themselves after a matter of minutes or hours at worst. If so, I would expect you would no longer get the error now.
