IDE hangs on startup: "discovery builtin:serial-discovery not found"
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> &".\ArduinoIDE"
& : The term '.\ArduinoIDE' is not recognized as the name of a cmdlet, function, script file, or operable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:2
+ &".\ArduinoIDE"
    + CategoryInfo          : ObjectNotFound: (.\ArduinoIDE:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> & ".\Arduino IDE"
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> &".\ArduinoIDE"
At line:1 char:62tend application configuration customizations. Module path: C:\Users\Admin\Downloads\arduino-ide_2.2.0_
+ ... S C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> &".\Ardui ...json': C:\Users\Admin\Downloads\arduino-i
The ampersand (&) character is not allowed. The & operator is reserved for future use; wrap an ampersand in double
quotation marks ("&") to pass it as part of a string.n configuration value to: "0.34.0" (type of string)
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException8-29T09:42:31.244Z" (type of string
    + FullyQualifiedErrorId : AmpersandNotAllowed
 rontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduin
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> & : The term '.\ArduinoIDE' is not recognized as the name of a cmdlet, function, script file, or operable program.le":"${rootName}${activeEditorShort}${appName}","files.autoSave":& : The term ':' is not recognized as the name of a cmdlet, function, script file, or operable program. Check the ggesti
spelling of the name, or if a path was included, verify that the path is correct and try again.ditor.bracketPairColoriza
At line:1 char:3lse,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":fal
+ & : The term '.\ArduinoIDE' is not recognized as the name of a cmdlet ...2:31.244Z"}
+   ~ing backend process. PID: 7044
    + CategoryInfo          : ObjectNotFound: (::String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException/.arduinoIDE'
 onfiguring to accept webviews on '^.+\.webview\..+$' hostname.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Check the spelling of the name, or if a path was included, verify that the path is correct and try again.ect.configure: 8.6 ms [Finished 1.146 s after backend start]
Check : The term 'Check' is not recognized as the name of a cmdlet, function, script file, or operable program. Check
the spelling of the name, or if a path was included, verify that the path is correct and try again.t]
At line:1 char:1:00.338Z root INFO Backend u.onStart: 0.5 ms [Finished 1.209 s after backend start]
+ Check the spelling of the name, or if a path was included, verify tha ...209 s after backend start]
+ ~~~~~-19T17:25:00.342Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 62.7 ms [
    + CategoryInfo          : ObjectNotFound: (Check:String) [], CommandNotFoundException
    + FullyQualifiedErrorId : CommandNotFoundException0.6 ms [Finished 1.210 s after backend start]
 024-03-19T17:25:00.344Z root INFO Backend s.configure: 5.9 ms [Finished 1.216 s after backend start]
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> At line:1 char:2
The AT command has been deprecated. Please use schtasks.exe instead.ished 1.217 s after backend start]
2024-03-19T17:25:00.351Z root INFO Backend P.onStart: 1.8 ms [Finished 1.218 s after backend start]
Invalid command.:00.352Z config INFO Loading CLI configuration from c:\Users\Admin\.arduinoIDE\arduino-cli.yaml...
2024-03-19T17:25:00.359Z daemon INFO Starting daemon from C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resou
The AT command schedules commands and programs to run on a computer at
a specified time and date. The Schedule service must be running to use      220 s after backend start]
the AT command.5:00.362Z root INFO Backend w.onStart: 2.5 ms [Finished 1.222 s after backend start]
                                                            ms [Finished 1.223 s after backend start]
AT [\\computername] [ [id] [/DELETE] | /DELETE [/YES]]
AT [\\computername] time [/INTERACTIVE]INFO start new deferred
    [ /EVERY:date[,...] | /NEXT:date[,...]] "command"ze: 1.0 ms [Finished 1.224 s after backend start]
2024-03-19T17:25:00.366Z root INFO Backend y.onStart: 5.0 ms [Finished 1.229 s after backend start]
\\computername     Specifies a remote computer. Commands are scheduled on the1 s after backend start]
                   local computer if this parameter is omitted.              s after backend start]
id                 Is an identification number assigned to a scheduled      42 s after backend start]
                   command.                                                 46 s after backend start]
/delete            Cancels a scheduled command. If id is omitted, all the1.249 s after backend start]
                   scheduled commands on the computer are canceled.ished 1.257 s after backend start]
/yes               Used with cancel all jobs command when no furtheralhost:49725.
                   confirmation is desired. starting backend application: 24.6 ms [Finished 1.268 s after backend start]
time               Specifies the time when command is to run.d by local-dir:/c%3A/Users/Admin/.arduinoIDE/plugins does n
/interactive       Allows the job to interact with the desktop of the user
                   who is logged on at the time the job runs.d by local-dir:/c%3A/Users/Admin/.arduinoIDE/extensions doe
/every:date[,...]  Runs the command on each specified day(s) of the week or
                   month. If date is omitted, the current day of the monthr:C:\Users\Admin\.arduinoIDE\plugins does not
                   is assumed.
/next:date[,...]   Runs the specified command on the next occurrence of therebase\mp_code_for_firebase.ino
                   day (for example, next Thursday).  If date is omitted, ther":{"additional_urls":[]},"build_cache":{"c
                   current day of the month is assumed.:{"port":"50051"},"directories":{"data":"C:\\Users\\Admin\\AppDat
"command"          Is the Windows NT command, or batch program to be run.no15\\staging","user":"C:\\Users\\Admin\\Docume
nts\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> + &".\ArduinoIDE"export_binaries":false},"updater":{"enableAt line:1 char:2rue}}
+ + &".\ArduinoIDE".911Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
+  ~-03-19T17:25:00.914Z config INFO Loaded the CLI configuration.
Missing expression after unary operator '+'.024-03-19T22:55:00+05:30" level=info msg="Using config file: c:\\Users\\Admi
At line:1 char:3arduino-cli.yaml"
+ + &".\ArduinoIDE":55:00+05:30" level=info msg="arduino-cli.exe version 0.34.0"
+   ~"2024-03-19T22:55:00+05:30" level=info msg="Executing `arduino-cli daemon`"
Unexpected token '&' in expression or statement.
    + FullyQualifiedErrorId : MissingExpressionAfterOperator
 024-03-19T17:25:00.952Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Admin/AppData/Local
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> +  ~~~~~~~~~~~~~~ionalUrls":[],"network":"none","locale":"eAt line:1 char:2
+ +  ~~~~~~~~~~~~~~.953Z config INFO Validating the CLI configuration...
+  ~-03-19T17:25:00.978Z config INFO The CLI config is valid.
Missing expression after unary operator '+'.tialized the CLI configuration.
At line:1 char:4:00.994Z daemon INFO time="2024-03-19T22:55:00+05:30" level=info msg="Updating libraries index"
+ +  ~~~~~~~~~~~~~~.997Z daemon INFO time="2024-03-19T22:55:00+05:30" level=info msg="Starting download" url="https://do
+    ~~~~~~~~~~~~~~libraries/library_index.tar.bz2"
Unexpected token '~~~~~~~~~~~~~~' in expression or statement.e during the gRPC core client initialization: code: 3, mess
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordExceptionr.bz2': Get "https://downloads.ardu
    + FullyQualifiedErrorId : MissingExpressionAfterOperatorwnloads.arduino.cc: no such host
 024-03-19T17:25:01.009Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, mess
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit>     + CategoryInfo          : ObjectNotFound: (.\ArduinoIDE:String) [], CommandNotFoundExceptionge_index.json: The system cannot find the file specified.
At line:1 char:6:01.010Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, mess
+     + CategoryInfo          : ObjectNotFound: (.\ArduinoIDE:String) [ ...t found
+      ~19T17:25:01.011Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, mess
Missing expression after unary operator '+'.ery builtin:mdns-discovery not found
At line:1 char:7:01.012Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, mess
+     + CategoryInfo          : ObjectNotFound: (.\ArduinoIDE:String) [ ...pData\Local\Arduino15\library_index.json: The
+       ~~~~~~~~~~~~the file specified.
Unexpected token 'CategoryInfo' in expression or statement.dexes are missing. Running indexes update before initializing
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordExceptiontializing the core gRPC client.
    + FullyQualifiedErrorId : MissingExpressionAfterOperatorinitialization:
 platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\Admin\AppData\Local\Arduino15\
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit>     + FullyQualifiedErrorId : CommandNotFoundException specAt line:1 char:6
+     + FullyQualifiedErrorId : CommandNotFoundExceptionare platform: discovery builtin:serial-discovery not found
+      ~m-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
Missing expression after unary operator '+'.index file: reading library_index.json: open C:\Users\Admin\AppData\Local\Ar
At line:1 char:7index.json: The system cannot find the file specified.
+       ~~~~~~~~~~~~~~~~~~~~~on INFO time="2024-03-19T22:55:01+05:30" level=info msg="Loading hardware from: C:\\Users\\
Unexpected token 'FullyQualifiedErrorId' in expression or statement.
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordException"C:\\Users\\Admin\\AppData\\Local\\
 ime="2024-03-19T22:55:01+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Admin\\AppData\\Local\\Arduino15\
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> & ".\Arduino IDE"
At line:1 char:6201.027Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Updating libraries index"
+ ... S C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> & ".\Ardu ...ownloads.arduino.cc/packages/package_inde
The ampersand (&) character is not allowed. The & operator is reserved for future use; wrap an ampersand in double ://do
    + CategoryInfo          : ParserError: (:) [], ParentContainsErrorRecordExceptionindex: package_index.tar.bz2
 024-03-19T17:25:01.035Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could n
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit>   at t.callErrorFromStatus (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.jsPS : Cannot find a process with the name "C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit>". Verify the
process name and call the cmdlet again.\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.j
At line:1 char:1
+ PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit>o-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.j
    + CategoryInfo          : ObjectNotFound: (C:\Users\Admin\..._Windows_64bit>:String) [Get-Process], ProcessCommand
   Exceptionss.processTicksAndRejections (node:internal/process/task_queues:77:11)
    + FullyQualifiedErrorId : NoProcessFoundForGivenName,Microsoft.PowerShell.Commands.GetProcessCommand
    at a.makeServerStreamRequest (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\mai
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Arduino IDE 2.2.0
Arduino : The term 'Arduino' is not recognized as the name of a cmdlet, function, script file, or operable program. 1846
At line:1 char:1Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587141
+ Arduino IDE 2.2.0in\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587489
+ ~~~~~~~w Promise (<anonymous>)
    + CategoryInfo          : ObjectNotFound: (Arduino:String) [], CommandNotFoundExceptionapp\lib\backend\main.js:2:587
    at _.updatePlatformIndex (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Checking for frontend application configuration customizations. Module path: C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\package.json
Checking : The term 'Checking' is not recognized as the name of a cmdlet, function, script file, or operable program. ma
At line:1 char:1rocessTicksAndRejections (node:internal/process/task_queues:95:5)
+ Checking for frontend application configuration customizations. Modul ...nloading index: library_index.tar.bz2
    + CategoryInfo          : ObjectNotFound: (Checking:String) [], CommandNotFoundExceptionng download" url="https://do
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.0" (type of string)ar.bz2"
Get-Content : A positional parameter cannot be found that accepts argument 'string'.client initialization: code: 3, mess
At line:1 char:89ading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.ardu
+ ... Version' application configuration value to: "2.2.0" (type of string).cc: no such host
+                                                           ~~~~~~~~~~~~~~gRPC core client initialization: code: 9, mess
    + CategoryInfo          : InvalidArgument: (:) [Get-Content], ParameterBindingExceptionkage_index.json: open C:\User
    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.GetContentCommand
 024-03-19T17:25:01.045Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Loading hardware from: C:\\Users\\
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)sg="Loading libraries index file" index="C:\\Users\\Admin\\AppData\\Local\\Get-Content : A positional parameter cannot be found that accepts argument 'string'.
At line:1 char:9022:55:01+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Admin\\AppData\\Local\\Arduino15\
+ ... ersion' application configuration value to: "0.34.0" (type of string)
+                                                           ~~~~~~~~~~~~~~="C:\\Users\\Admin\\Documents\\Arduino\\librar
    + FullyQualifiedErrorId : PositionalParameterNotFound,Microsoft.PowerShell.Commands.GetContentCommand: code: 9, mess
 ge: Error loading hardware platform: discovery builtin:serial-discovery not found
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-29T09:42:31.244Z" (type of string)iscovery not found
Get-Content : A positional parameter cannot be found that accepts argument 'string'.client initialization: code: 9, mess
At line:1 char:107 file: reading library_index.json: open C:\Users\Admin\AppData\Local\Arduino15\library_index.json: The
+ ... n configuration value to: "2023-08-29T09:42:31.244Z" (type of string)
+                                                           ~~~~~~~~~~~~~~of the cores and libraries must be updated bef
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.0","cliVersion":"0.34.0","buildDate":"2023-08-29T09:42:31.244Z"}ot ERROR Error: The index of the cores and libraries must be updated before initializing the At line:1 char:75
+ ... uration after modifications: {"applicationName":"Arduino IDE","defaul ...
+                                                    ~~~~~~~~~~~~~~on index file C:\Users\Admin\AppData\Local\Arduino15\
Unexpected token ':"Arduino IDE"' in expression or statement.15\package_index.json: The system cannot find the file spec
At line:1 char:89
+ ... ration after modifications: {"applicationName":"Arduino IDE","default ... builtin:serial-discovery not found
+        ~m: discovery builtin:mdns-discovery not found
Missing argument in parameter list. Loading index file: reading library_index.json: open C:\Users\Admin\AppData\Local\Ar
At line:1 char:113dex.json: The system cannot find the file specified.
+ ... onName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark": ...
+                                                  ~~~~~~~~~~~~~~~~ources\app\lib\backend\main.js:2:586285
Unexpected token ':"arduino-theme"' in expression or statement.ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js
At line:1 char:129
+ ... nName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":" ...5)
+        ~2.0_Windows_64bit\resources\app\lib\backend\main.js:2
At line:1 char:2121.078Z root INFO Resolve plugins list: 726.0 ms [Finished 1.957 s after backend start]
+ ... dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"def ...
Unexpected token ':' in expression or statement.nfigure took longer than the expected maximum 100 milliseconds: 8318.6 m
At line:1 char:299 s after frontend start]
+ ... ":{"window.title":"${rootName}${activeEditorShort}${appName}","files. ...s already registered.
+                      ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~k longer than the expected maximum 100 milliseconds:
Unexpected token ':"${rootName}${activeEditorShort}${appName}"' in expression or statement.
At line:1 char:3438.583Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 2871.6 ms
+ ... :{"window.title":"${rootName}${activeEditorShort}${appName}","files.a ...
+        ~inished 30.342 s after backend start]
At line:1 char:494
+ ... eyondLastLine":false,"editor.quickSuggestions":{"other":false,"commen ...
Unexpected token ':false' in expression or statement.
At line:1 char:500
+ ... yondLastLine":false,"editor.quickSuggestions":{"other":false,"comment ...
    + FullyQualifiedErrorId : UnexpectedToken
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Starting backend process. PID: 7044
Starting : The term 'Starting' is not recognized as the name of a cmdlet, function, script file, or operable program.
At line:1 char:1
+ Starting backend process. PID: 7044
    + CategoryInfo          : ObjectNotFound: (Starting:String) [], CommandNotFoundException
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Using browser-only version of superagent in non-browser environment
At line:1 char:6
+ Using browser-only version of superagent in non-browser environment
Missing using directive
    + FullyQualifiedErrorId : MissingUsingStatementDirective
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Configuration directory URI: 'file:///c%3A/Users/Admin/.arduinoIDE'
At line:1 char:29
+ Configuration directory URI: 'file:///c%3A/Users/Admin/.arduinoIDE'
Missing '{' in configuration statement.
    + FullyQualifiedErrorId : MissingCurlyInConfigurationStatement
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Configuring to accept webviews on '^.+\.webview\..+$' hostname.
Configuring : The term 'Configuring' is not recognized as the name of a cmdlet, function, script file, or operable
program. Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:1 char:1
+ Configuring to accept webviews on '^.+\.webview\..+$' hostname.
    + CategoryInfo          : ObjectNotFound: (Configuring:String) [], CommandNotFoundException
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.330Z root INFO Backend Object.initialize: 10.5 ms [Finished 1.146 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.330Z root INFO Backend Object.initialize: 10.5 ms ...
You must provide a value expression following the '-' operator.
At line:1 char:9
Unexpected token '19T17:25:00.330Z' in expression or statement.
    + FullyQualifiedErrorId : ExpectedValueExpression
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.334Z root INFO Backend Object.configure: 8.6 ms [Finished 1.146 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.334Z root INFO Backend Object.configure: 8.6 ms [ ...
At line:1 char:9
Unexpected token '19T17:25:00.334Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.335Z root INFO Backend a.onStart: 3.2 ms [Finished 1.146 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.335Z root INFO Backend a.onStart: 3.2 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.335Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.336Z root INFO Backend a.configure: 0.6 ms [Finished 1.209 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.336Z root INFO Backend a.configure: 0.6 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.336Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.338Z root INFO Backend u.onStart: 0.5 ms [Finished 1.209 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.338Z root INFO Backend u.onStart: 0.5 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.338Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.340Z root INFO Backend d.configure: 0.2 ms [Finished 1.209 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.340Z root INFO Backend d.configure: 0.2 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.340Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.342Z root WARN Backend d.initialize took longer than the expected maximum 50 milliseconds: 62.7 ms [Finished 1.210 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.342Z root WARN Backend d.initialize took longer t ...
At line:1 char:9
Unexpected token '19T17:25:00.342Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.343Z root INFO Backend c.onStart: 0.6 ms [Finished 1.210 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.343Z root INFO Backend c.onStart: 0.6 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.343Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.344Z root INFO Backend s.configure: 5.9 ms [Finished 1.216 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.344Z root INFO Backend s.configure: 5.9 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.344Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.348Z config INFO >>> Initializing CLI configuration...
At line:1 char:9
+ 2024-03-19T17:25:00.348Z config INFO >>> Initializing CLI configurati ...
At line:1 char:9
Unexpected token '19T17:25:00.348Z' in expression or statement.
At line:1 char:40
Missing file specification after redirection operator.
At line:1 char:40
The output stream for this command is already redirected.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.348Z root INFO Backend c.initialize: 1.3 ms [Finished 1.217 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.348Z root INFO Backend c.initialize: 1.3 ms [Fini ...
At line:1 char:9
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.351Z root INFO Backend P.onStart: 1.8 ms [Finished 1.218 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.351Z root INFO Backend P.onStart: 1.8 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.351Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.352Z config INFO Loading CLI configuration from c:\Users\Admin\.arduinoIDE\arduino-cli.yaml...
At line:1 char:9
+ 2024-03-19T17:25:00.352Z config INFO Loading CLI configuration from c ...
At line:1 char:9
Unexpected token '19T17:25:00.352Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.359Z daemon INFO Starting daemon from C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\resources\arduino-cli.exe...
At line:1 char:9
+ 2024-03-19T17:25:00.359Z daemon INFO Starting daemon from C:\Users\Ad ...
At line:1 char:9
Unexpected token '19T17:25:00.359Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.361Z root INFO Backend s.initialize: 0.8 ms [Finished 1.220 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.361Z root INFO Backend s.initialize: 0.8 ms [Fini ...
At line:1 char:9
Unexpected token '19T17:25:00.361Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.362Z root INFO Backend w.onStart: 2.5 ms [Finished 1.222 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.362Z root INFO Backend w.onStart: 2.5 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.362Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.363Z root INFO Backend r.configure: 4.8 ms [Finished 1.223 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.363Z root INFO Backend r.configure: 4.8 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.363Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.364Z discovery-log INFO start
At line:1 char:9
+ 2024-03-19T17:25:00.364Z discovery-log INFO start
At line:1 char:9
Unexpected token '19T17:25:00.364Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.364Z discovery-log INFO start new deferred
At line:1 char:9
+ 2024-03-19T17:25:00.364Z discovery-log INFO start new deferred
At line:1 char:9
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.365Z root INFO Backend d.initialize: 1.0 ms [Finished 1.224 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.365Z root INFO Backend d.initialize: 1.0 ms [Fini ...
At line:1 char:9
Unexpected token '19T17:25:00.365Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.366Z root INFO Backend y.onStart: 5.0 ms [Finished 1.229 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.366Z root INFO Backend y.onStart: 5.0 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.366Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.367Z root INFO Backend r.configure: 5.9 ms [Finished 1.231 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.367Z root INFO Backend r.configure: 5.9 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.367Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.369Z root INFO Backend s.onStart: 3.6 ms [Finished 1.241 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.369Z root INFO Backend s.onStart: 3.6 ms [Finishe ...
At line:1 char:9
Unexpected token '19T17:25:00.369Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.376Z root INFO Backend h.configure: 3.9 ms [Finished 1.242 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.376Z root INFO Backend h.configure: 3.9 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.376Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.377Z root INFO Backend a.configure: 2.5 ms [Finished 1.246 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.377Z root INFO Backend a.configure: 2.5 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.377Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.378Z root INFO Backend s.configure: 0.5 ms [Finished 1.249 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.378Z root INFO Backend s.configure: 0.5 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.378Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.379Z root INFO Backend l.configure: 0.3 ms [Finished 1.257 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.379Z root INFO Backend l.configure: 0.3 ms [Finis ...
At line:1 char:9
Unexpected token '19T17:25:00.379Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.388Z root INFO Theia app listening on http://localhost:49725.
At line:1 char:9
+ 2024-03-19T17:25:00.388Z root INFO Theia app listening on http://loca ...
At line:1 char:9
Unexpected token '19T17:25:00.388Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.390Z root INFO Finished starting backend application: 24.6 ms [Finished 1.268 s after backend start]
At line:1 char:9
+ 2024-03-19T17:25:00.390Z root INFO Finished starting backend applicat ...
At line:1 char:9
Unexpected token '19T17:25:00.390Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.421Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Admin/.arduinoIDE/plugins does not exist.
At line:1 char:9
+ 2024-03-19T17:25:00.421Z root WARN The local plugin referenced by loc ...
At line:1 char:9
Unexpected token '19T17:25:00.421Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.423Z root WARN The local plugin referenced by local-dir:/c%3A/Users/Admin/.arduinoIDE/extensions does not exist.
At line:1 char:9
+ 2024-03-19T17:25:00.423Z root WARN The local plugin referenced by loc ...
At line:1 char:9
Unexpected token '19T17:25:00.423Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.426Z root WARN The local plugin referenced by local-dir:C:\Users\Admin\.arduinoIDE\plugins does not exist.
At line:1 char:9
+ 2024-03-19T17:25:00.426Z root WARN The local plugin referenced by loc ...
At line:1 char:9
Unexpected token '19T17:25:00.426Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> Restoring workspace roots: e:\Mega project\Mega_project_code\mp_code_for_firebase\mp_code_for_firebase.ino
Restoring : The term 'Restoring' is not recognized as the name of a cmdlet, function, script file, or operable
At line:1 char:1
+ Restoring workspace roots: e:\Mega project\Mega_project_code\mp_code_ ...
    + CategoryInfo          : ObjectNotFound: (Restoring:String) [], CommandNotFoundException
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.910Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\Admin\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\Admin\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\Admin\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
At line:1 char:9
+ 2024-03-19T17:25:00.910Z config INFO Loaded CLI configuration: {"boar ...
At line:1 char:9
Unexpected token '19T17:25:00.910Z' in expression or statement.
At line:1 char:80
+ ... .910Z config INFO Loaded CLI configuration: {"board_manager":{"additi ...
At line:1 char:99
+ ... ded CLI configuration: {"board_manager":{"additional_urls":[]},"build ...
Unexpected token ':[]' in expression or statement.
At line:1 char:146
+ ... ional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":" ...
Unexpected token ':10' in expression or statement.
At line:1 char:149
+ ... onal_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"7 ...
At line:1 char:184
+ ... s_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"direc ...
Unexpected token ':"50051"' in expression or statement.
At line:1 char:215
+ ... tories":{"data":"C:\\Users\\Admin\\AppData\\Local\\Arduino15","downlo ...
Unexpected token ':"C:\\Users\\Admin\\AppData\\Local\\Arduino15"' in expression or statement.
At line:1 char:261
+ ... ories":{"data":"C:\\Users\\Admin\\AppData\\Local\\Arduino15","downloa ...
At line:1 char:410
+ ... Documents\\Arduino"},"library":{"enable_unsafe_install":false},"loggi ...
Not all parse errors were reported.  Correct the reported errors and try again.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.911Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
At line:1 char:9
+ 2024-03-19T17:25:00.911Z config INFO 'directories.data' and 'director ...
At line:1 char:9
Unexpected token '19T17:25:00.911Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.914Z config INFO Loaded the CLI configuration.
At line:1 char:9
+ 2024-03-19T17:25:00.914Z config INFO Loaded the CLI configuration.
At line:1 char:9
Unexpected token '19T17:25:00.914Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> 2024-03-19T17:25:00.930Z daemon INFO time="2024-03-19T22:55:00+05:30" level=info msg="Using config file: c:\\Users\\Admin\\.arduinoIDE\\arduino-cli.yaml"
At line:1 char:9
+ 2024-03-19T17:25:00.930Z daemon INFO time="2024-03-19T22:55:00+05:30" ...
At line:1 char:9
Unexpected token '19T17:25:00.930Z' in expression or statement.
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> time="2024-03-19T22:55:00+05:30" level=info msg="arduino-cli.exe version 0.34.0"
time=2024-03-19T22:55:00+05:30 : The term 'time=2024-03-19T22:55:00+05:30' is not recognized as the name of a cmdlet,
function, script file, or operable program. Check the spelling of the name, or if a path was included, verify that the
At line:1 char:1
+ time="2024-03-19T22:55:00+05:30" level=info msg="arduino-cli.exe vers ...
    + CategoryInfo          : ObjectNotFound: (time=2024-03-19T22:55:00+05:30:String) [], CommandNotFoundException
PS C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit> time="2024-03-19T22:55:00+05:30" level=info msg="Executing `arduino-cli daemon`"
>> Daemon is now listening on 127.0.0.1:49726
>> {"IP":"127.0.0.1","Port":"49726"}
>> 2024-03-19T17:25:00.930Z daemon INFO Daemon is running.
>> 2024-03-19T17:25:00.952Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/Admin/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/Admin/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
>> 2024-03-19T17:25:00.953Z config INFO Validating the CLI configuration...
>> 2024-03-19T17:25:00.978Z config INFO The CLI config is valid.
>> 2024-03-19T17:25:00.978Z config INFO <<< Initialized the CLI configuration.
>> 2024-03-19T17:25:00.994Z daemon INFO time="2024-03-19T22:55:00+05:30" level=info msg="Updating libraries index"
>> 2024-03-19T17:25:00.997Z daemon INFO time="2024-03-19T22:55:00+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
>> 2024-03-19T17:25:01.008Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
>> 2024-03-19T17:25:01.009Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Admin\AppData\Local\Arduino15\package_index.json: open C:\Users\Admin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
>> 2024-03-19T17:25:01.010Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
>> 2024-03-19T17:25:01.011Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
>> 2024-03-19T17:25:01.012Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Admin\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
>> 2024-03-19T17:25:01.021Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client The index of the cores and libraries must be updated before initializing the core gRPC client.
>> The following problems were detected during the gRPC client initialization:
>> [platform-index] - code: 9, message: Loading index file: loading json index file C:\Users\Admin\AppData\Local\Arduino15\package_index.json: open C:\Users\Admin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
>> [platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
>> [platform-index] - code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
>> [library-index] - code: 9, message: Loading index file: reading library_index.json: open C:\Users\Admin\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
>> 2024-03-19T17:25:01.026Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Loading hardware from: C:\\Users\\Admin\\AppData\\Local\\Arduino15\\packages"
>> time="2024-03-19T22:55:01+05:30" level=info msg="Loading libraries index file" index="C:\\Users\\Admin\\AppData\\Local\\Arduino15\\library_index.json"
>> time="2024-03-19T22:55:01+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Admin\\AppData\\Local\\Arduino15\\libraries" location=ide
>> time="2024-03-19T22:55:01+05:30" level=info msg="Adding libraries dir" dir="C:\\Users\\Admin\\Documents\\Arduino\\libraries" location=user
>> 2024-03-19T17:25:01.027Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Updating libraries index"
>> time="2024-03-19T22:55:01+05:30" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
>> 2024-03-19T17:25:01.029Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
>> 2024-03-19T17:25:01.031Z root INFO core-client-provider [platform-index] Downloading index: package_index.tar.bz2
>> 2024-03-19T17:25:01.035Z root ERROR Failed to update platform, library indexes. Error: 13 INTERNAL: Some indexes could not be updated.
>>     at t.callErrorFromStatus (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:726944)
>>     at Object.onReceiveStatus (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:754484)
>>     at Object.onReceiveStatus (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:747508)
>>     at C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:833052
>>     at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
>> for call at
>>     at a.makeServerStreamRequest (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:754251)
>>     at a.updateIndex (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:818460)
>>     at C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587141
>>     at C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587489
>>     at new Promise (<anonymous>)
>>     at _.doUpdateIndex (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587468)
>>     at _.updatePlatformIndex (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:587113)
>>     at _.updateIndex (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:586481)
>>     at _.initInstanceWithFallback (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:584725)
>>     at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
>> 2024-03-19T17:25:01.038Z root INFO core-client-provider [library-index] Downloading index: library_index.tar.bz2
>> 2024-03-19T17:25:01.040Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
>> 2024-03-19T17:25:01.041Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
>> 2024-03-19T17:25:01.043Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Error downloading index 'https://downloads.arduino.cc/libraries/library_index.tar.bz2': Get "https://downloads.arduino.cc/libraries/library_index.tar.bz2": dial tcp: lookup downloads.arduino.cc: no such host
>> 2024-03-19T17:25:01.044Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: loading json index file C:\Users\Admin\AppData\Local\Arduino15\package_index.json: open C:\Users\Admin\AppData\Local\Arduino15\package_index.json: The system cannot find the file specified.
>> 2024-03-19T17:25:01.045Z daemon INFO time="2024-03-19T22:55:01+05:30" level=info msg="Loading hardware from: C:\\Users\\Admin\\AppData\\Local\\Arduino15\\packages"
>> 2024-03-19T17:25:01.046Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:serial-discovery not found
>> 2024-03-19T17:25:01.046Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery builtin:mdns-discovery not found
>> 2024-03-19T17:25:01.057Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Loading index file: reading library_index.json: open C:\Users\Admin\AppData\Local\Arduino15\library_index.json: The system cannot find the file specified.
>> 2024-03-19T17:25:01.060Z root ERROR Uncaught Exception:  Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
>> 2024-03-19T17:25:01.060Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
>>     at C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:586285
>>     at _.evaluateErrorStatus (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:586301)
>>     at async s.<anonymous> (C:\Users\Admin\Downloads\arduino-ide_2.2.0_Windows_64bit\resources\app\lib\backend\main.js:2:585971)
>> 2024-03-19T17:25:01.078Z root INFO Resolve plugins list: 726.0 ms [Finished 1.957 s after backend start]
>> Opening channel for service path '/services/electron-window'.
>> Opening channel for service path '/services/ide-updater'.
>> 2024-03-19T17:25:13.461Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 8318.6 ms [Finished 11.248 s after frontend start]
>> 2024-03-19T17:25:13.462Z root WARN A command editor.action.toggleStickyScroll is already registered.
>> 2024-03-19T17:25:15.327Z root WARN Frontend keybindings.onStart took longer than the expected maximum 100 milliseconds: 1504.5 ms [Finished 12.806 s after frontend start]
>> 2024-03-19T17:25:18.583Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 2871.6 ms [Finished 15.780 s after frontend start]
>> 2024-03-19T17:25:29.462Z root INFO Deploy plugins list: 726.0 ms [Finished 30.342 s after backend start]
>> ^C520:0319/225659.225:ERROR:gpu_init.cc(523)] Passthrough is not supported, GL is disabled, ANGLE is
``` this is error i got with arduino ide.
Hi @nikita_08
I see the problem here:
On the first run after a fresh installation, Arduino IDE downloads some additional essential components from the Internet and installs them. If it can't install those components then the startup fails. So the computer must have access to the Internet on the first startup.
The errors indicate Arduino IDE is not able to access the Internet. If it is not already, please connect your computer to the Internet, close the Arduino IDE window, then start Arduino IDE again. This time it should start up successfully.
After that first run, an Internet connection is not required. However, there are some supplemental features such as "Library Manager" that have an inherent dependency on the Internet. Those features will not be usable while your computer is offline. But the essential functionality of editing, compiling, and uploading sketches will be available even without an Internet connection.
