IDE hangs on startup: "discovery teensy:teensy-discovery not found"
Here is the Powershell data as per earlier posts
PS C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide> ".\Arduino IDE"
.\Arduino IDE
PS C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide> .\"Arduino IDE"
PS C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide> Arduino IDE 2.0.3
Starting backend process. PID: 22400
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/PaulC.CYBERKIN/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-02-26T20:17:13.428Z root INFO Backend Object.initialize: 3.5 ms [Finished 1.364 s after backend start]
2023-02-26T20:17:13.428Z root INFO Backend Object.configure: 2.8 ms [Finished 1.364 s after backend start]
2023-02-26T20:17:13.428Z root INFO Backend MessagingContribution.onStart: 1.1 ms [Finished 1.364 s after backend start]
2023-02-26T20:17:13.428Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.403 s after backend start]
2023-02-26T20:17:13.429Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.403 s after backend start]
2023-02-26T20:17:13.430Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.403 s after backend start]
2023-02-26T20:17:13.431Z root INFO Backend PluginLocalizationBackendContribution.initialize: 38.7 ms [Finished 1.403 s after backend start]
2023-02-26T20:17:13.431Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.403 s after backend start]
2023-02-26T20:17:13.432Z root INFO Backend ElectronTokenBackendContribution.configure: 0.8 ms [Finished 1.404 s after backend start]
2023-02-26T20:17:13.432Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.404 s after backend start]
2023-02-26T20:17:13.432Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.405 s after backend start]
2023-02-26T20:17:13.433Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.406 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend ArduinoDaemonImpl.onStart: 1.0 ms [Finished 1.406 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend NodeFileUploadService.configure: 1.8 ms [Finished 1.407 s after backend start]
2023-02-26T20:17:13.434Z daemon INFO Starting daemon from C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-02-26T20:17:13.434Z discovery-log INFO start
2023-02-26T20:17:13.434Z discovery-log INFO start new deferred
2023-02-26T20:17:13.434Z root INFO Backend HostedPluginLocalizationService.initialize: 0.4 ms [Finished 1.407 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend BoardDiscovery.onStart: 0.7 ms [Finished 1.408 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.408 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.409 s after backend start]
2023-02-26T20:17:13.434Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.409 s after backend start]
2023-02-26T20:17:13.435Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 1.410 s after backend start]
2023-02-26T20:17:13.436Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.410 s after backend start]
2023-02-26T20:17:13.436Z root INFO Backend PlotterBackendContribution.configure: 0.9 ms [Finished 1.411 s after backend start]
2023-02-26T20:17:13.438Z root INFO Theia app listening on http://localhost:61871.
2023-02-26T20:17:13.461Z root INFO Finished starting backend application: 4.1 ms [Finished 1.414 s after backend start]
2023-02-26T20:17:13.468Z root WARN The local plugin referenced by local-dir:/c%3A/Users/PaulC.CYBERKIN/.arduinoIDE/plugins does not exist.
2023-02-26T20:17:13.468Z root WARN The local plugin referenced by local-dir:/c%3A/Users/PaulC.CYBERKIN/.arduinoIDE/extensions does not exist.
2023-02-26T20:17:13.470Z root WARN The local plugin referenced by local-dir:C:\Users\PaulC.CYBERKIN\.arduinoProIDE\plugins does not exist.
2023-02-26T20:17:13.490Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.493Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-02-26T20:17:13.494Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.495Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
2023-02-26T20:17:13.496Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.497Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-02-26T20:17:13.497Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.498Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-02-26T20:17:13.500Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.501Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-02-26T20:17:13.502Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.503Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-02-26T20:17:13.504Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.505Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-02-26T20:17:13.505Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.507Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-02-26T20:17:13.508Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.509Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-02-26T20:17:13.510Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.511Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-02-26T20:17:13.512Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.514Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-02-26T20:17:13.515Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.516Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-02-26T20:17:13.538Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.540Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-02-26T20:17:13.541Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.542Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-02-26T20:17:13.543Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.544Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-02-26T20:17:13.545Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.546Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-02-26T20:17:13.547Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.548Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-02-26T20:17:13.549Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.550Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-02-26T20:17:13.550Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.551Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-02-26T20:17:13.552Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.554Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-02-26T20:17:13.572Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-02-26T20:17:13.574Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-02-26T20:17:13.586Z root INFO Resolve plugins list: 153.2 ms [Finished 1.562 s after backend start]
2023-02-26T20:17:13.590Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.5 ms [Finished 1.565 s after backend start]
2023-02-26T20:17:13.600Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 10.6 ms [Finished 1.576 s after backend start]
2023-02-26T20:17:13.608Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-cpp\extension": 7.4 ms [Finished 1.584 s after backend start]
2023-02-26T20:17:13.616Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json\extension": 7.9 ms [Finished 1.592 s after backend start]
2023-02-26T20:17:13.616Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.7 ms [Finished 1.592 s after backend start]
2023-02-26T20:17:13.679Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-bg\extension": 62.5 ms [Finished 1.655 s after backend start]
2023-02-26T20:17:13.758Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-cs\extension": 78.6 ms [Finished 1.733 s after backend start]
2023-02-26T20:17:13.844Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-de\extension": 86.5 ms [Finished 1.820 s after backend start]
2023-02-26T20:17:13.912Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-es\extension": 67.3 ms [Finished 1.887 s after backend start]
2023-02-26T20:17:13.964Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-fr\extension": 52.8 ms [Finished 1.940 s after backend start]
2023-02-26T20:17:14.005Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-hu\extension": 40.2 ms [Finished 1.980 s after backend start]
2023-02-26T20:17:14.061Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-it\extension": 56.4 ms [Finished 2.037 s after backend start]
2023-02-26T20:17:14.112Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ja\extension": 51.2 ms [Finished 2.088 s after backend start]
2023-02-26T20:17:14.131Z daemon INFO INFO[0000] Using config file: c:\Users\PaulC.CYBERKIN\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
{"IP":"127.0.0.1","Port":"49290"}
2023-02-26T20:17:14.131Z daemon INFO Daemon is running.
2023-02-26T20:17:14.191Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ko\extension": 78.6 ms [Finished 2.167 s after backend start]
2023-02-26T20:17:14.220Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-nl\extension": 28.9 ms [Finished 2.196 s after backend start]
2023-02-26T20:17:14.221Z daemon INFO INFO[0000] Loading hardware from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages
INFO[0000] Loading package CubeCell from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\hardware
INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="CubeCell:CubeCell@1.3.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\tools
INFO[0000] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\tools
INFO[0000] Loaded tool                                   tool="CubeCell:CubeCellelftool@0.0.1"
INFO[0000] Loaded tool                                   tool="CubeCell:CubeCellflash@0.0.1"
INFO[0000] Loaded tool                                   tool="CubeCell:gcc-arm-none-eabi@8-2019-q3"
INFO[0000] Loading package builtin from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loading package esp32 from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\hardware
2023-02-26T20:17:14.276Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pl\extension": 55.5 ms [Finished 2.251 s after backend start]
2023-02-26T20:17:14.276Z daemon INFO INFO[0000] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform                               platform="esp32:esp32@2.0.0"
INFO[0000] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\tools
INFO[0000] Loaded tool                                   tool="esp32:esptool_py@3.1.0"
INFO[0000] Loaded tool                                   tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0000] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0000] Loaded tool                                   tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0000] Loaded tool                                   tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0000] Loading package teensy from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\hardware
INFO[0000] Adding monitor tool                           protocol=teensy tool="teensy:teensy-monitor"
INFO[0000] Loaded platform                               platform="teensy:avr@1.57.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loaded tool                                   tool="teensy:teensy-compile@5.4.1"
INFO[0000] Loaded tool                                   tool="teensy:teensy-tools@1.57.2"
INFO[0000] Checking signature                            index="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\CubeCell\\hardware\\CubeCell\\1.3.0\\libraries" location=platform
INFO[0000] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.0\\libraries" location=platform
INFO[0000] Loading libraries index file                  index="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\library_index.json"
2023-02-26T20:17:14.278Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-02-26T20:17:14.336Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pt-BR\extension": 60.1 ms [Finished 2.312 s after backend start]
2023-02-26T20:17:14.394Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ru\extension": 58.0 ms [Finished 2.370 s after backend start]
2023-02-26T20:17:14.394Z daemon INFO INFO[0000] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\Documents\\Arduino\\libraries" location=user
2023-02-26T20:17:14.447Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-tr\extension": 53.0 ms [Finished 2.423 s after backend start]
2023-02-26T20:17:14.484Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-uk\extension": 36.6 ms [Finished 2.459 s after backend start]
2023-02-26T20:17:14.537Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-zh-hans\extension": 53.3 ms [Finished 2.513 s after backend start]
2023-02-26T20:17:14.537Z root INFO Deploy plugins list: 153.2 ms [Finished 2.513 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-02-26T20:17:15.111Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 182.7 ms [Finished 1.577 s after frontend start]
2023-02-26T20:17:18.224Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-02-26T20:17:18.226Z daemon INFO INFO[0004] Updating index                                url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-02-26T20:17:18.228Z root INFO core-client-provider [platform-index]
2023-02-26T20:17:19.014Z daemon INFO INFO[0004] Loading hardware from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages
2023-02-26T20:17:19.015Z daemon INFO INFO[0004] Loading package CubeCell from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\hardware
2023-02-26T20:17:19.019Z daemon INFO INFO[0004] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0004] Loaded platform                               platform="CubeCell:CubeCell@1.3.0"
2023-02-26T20:17:19.019Z daemon INFO INFO[0004] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\tools
INFO[0004] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\CubeCell\tools
2023-02-26T20:17:19.020Z daemon INFO INFO[0004] Loaded tool                                   tool="CubeCell:CubeCellelftool@0.0.1"
INFO[0004] Loaded tool                                   tool="CubeCell:CubeCellflash@0.0.1"
INFO[0004] Loaded tool                                   tool="CubeCell:gcc-arm-none-eabi@8-2019-q3"
2023-02-26T20:17:19.021Z daemon INFO INFO[0004] Loading package builtin from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin
2023-02-26T20:17:19.022Z daemon INFO INFO[0004] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin\tools
INFO[0004] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\builtin\tools
INFO[0004] Loaded tool                                   tool="builtin:ctags@5.8-arduino11"
2023-02-26T20:17:19.023Z daemon INFO INFO[0004] Loaded tool                                   tool="builtin:mdns-discovery@1.0.8"
INFO[0004] Loaded tool                                   tool="builtin:serial-discovery@1.4.0"
INFO[0004] Loaded tool                                   tool="builtin:serial-monitor@0.13.0"
2023-02-26T20:17:19.024Z daemon INFO INFO[0004] Loading package esp32 from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\hardware
2023-02-26T20:17:19.039Z daemon INFO INFO[0005] Adding monitor tool                           protocol=serial tool="builtin:serial-monitor"
INFO[0005] Loaded platform                               platform="esp32:esp32@2.0.0"
2023-02-26T20:17:19.049Z daemon INFO INFO[0005] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\tools
INFO[0005] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\esp32\tools
INFO[0005] Loaded tool                                   tool="esp32:esptool_py@3.1.0"
INFO[0005] Loaded tool                                   tool="esp32:mklittlefs@3.0.0-gnu12-dc7f933"
INFO[0005] Loaded tool                                   tool="esp32:mkspiffs@0.2.3"
INFO[0005] Loaded tool                                   tool="esp32:riscv32-esp-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0005] Loaded tool                                   tool="esp32:xtensa-esp32-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0005] Loaded tool                                   tool="esp32:xtensa-esp32s2-elf-gcc@gcc8_4_0-esp-2021r1"
INFO[0005] Loading package teensy from: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\hardware
INFO[0005] Adding monitor tool                           protocol=teensy tool="teensy:teensy-monitor"
INFO[0005] Loaded platform                               platform="teensy:avr@1.57.2"
INFO[0005] Checking existence of 'tools' path: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\tools
INFO[0005] Loading tools from dir: C:\Users\PaulC.CYBERKIN\AppData\Local\Arduino15\packages\teensy\tools
INFO[0005] Loaded tool                                   tool="teensy:teensy-compile@5.4.1"
INFO[0005] Loaded tool                                   tool="teensy:teensy-tools@1.57.2"
INFO[0005] Checking signature                            index="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-02-26T20:17:19.051Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-02-26T20:17:19.053Z daemon INFO INFO[0005] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\CubeCell\\hardware\\CubeCell\\1.3.0\\libraries" location=platform
2023-02-26T20:17:19.055Z daemon INFO INFO[0005] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" location=platform
2023-02-26T20:17:19.058Z daemon INFO INFO[0005] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.0\\libraries" location=platform
INFO[0005] Loading libraries index file                  index="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\library_index.json"
2023-02-26T20:17:19.228Z daemon INFO INFO[0005] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-02-26T20:17:19.228Z daemon INFO INFO[0005] Adding libraries dir                          dir="C:\\Users\\PaulC.CYBERKIN\\Documents\\Arduino\\libraries" location=user
2023-02-26T20:17:22.950Z root ERROR Uncaught Exception:
2023-02-26T20:17:22.950Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
    at isIndexUpdateRequiredBeforeInit (C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:378:11)
    at CoreClientProvider.evaluateErrorStatus (C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:190:16)
    at ClientReadableStreamImpl.<anonymous> (C:\Users\PaulC.CYBERKIN\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:175:36)
    at ClientReadableStreamImpl.emit (node:events:394:28)
    at endReadableNT (node:internal/streams/readable:1331:12)
    at processTicksAndRejections (node:internal/process/task_queues:83:21)
Closing channel on service path '/services/electron-window-ext'.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Stored workspaces roots:
Hi @lateralleap. It seems your installation of the Teensy platform has somehow been corrupted:
Please try this:
  1. Close the Arduino IDE window if you still have it open.
  2. Delete the folder at the following path:
    :exclamation: If looking for it with your file browser or command line, note that the <!-- TODO: path --> folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
    :warning: Please be very careful when deleting things from your computer. When in doubt, back up!
  3. Start Arduino IDE.
Hopefully Arduino IDE will start up successfully now.
If you need the Teensy boards platform, follow the instructions here to install it again:
https://www.pjrc.com/arduino-ide-2-0-0-teensy-support/
Many thanks, that's fixed it
Much appreciated :slight_smile:
You are welcome. I'm glad it is working now.
Regards,
Per
There is a dedicated IDE 2.0 section on the forum; your topic has been moved there.
