PS C:\Users\KSaleh\AppData\Local\Programs\arduino-ide>
Arduino IDE 2.1.0
Starting backend process. PID: 19824
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/KSaleh/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-07-05T15:12:08.554Z root INFO Backend Object.initialize: 4.0 ms [Finished 1.650 s after backend start]
2023-07-05T15:12:08.554Z root INFO Backend Object.configure: 3.2 ms [Finished 1.650 s after backend start]
2023-07-05T15:12:08.556Z root INFO Backend MessagingContribution.onStart: 1.4 ms [Finished 1.650 s after backend start]
2023-07-05T15:12:08.556Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.688 s after backend start]
2023-07-05T15:12:08.557Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.688 s after backend start]2023-07-05T15:12:08.558Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.688 s after backend start]
2023-07-05T15:12:08.559Z root INFO Backend PluginLocalizationBackendContribution.initialize: 37.7 ms [Finished 1.689 s after backend start]
2023-07-05T15:12:08.559Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.689 s after backend start]
2023-07-05T15:12:08.560Z root INFO Backend ElectronTokenBackendContribution.configure: 2.3 ms [Finished 1.691 s after backend start]
2023-07-05T15:12:08.561Z config INFO >>> Initializing CLI configuration...
2023-07-05T15:12:08.561Z root INFO Backend PluginDeployerContribution.initialize: 0.6 ms [Finished 1.691 s after backend start]
2023-07-05T15:12:08.561Z root INFO Backend ConfigServiceImpl.onStart: 1.0 ms [Finished 1.692 s after backend start]
2023-07-05T15:12:08.562Z config INFO Loading CLI configuration from c:\Users\KSaleh\.arduinoIDE\arduino-cli.yaml...
2023-07-05T15:12:08.563Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 1.693 s after backend start]
2023-07-05T15:12:08.563Z root INFO Backend ArduinoDaemonImpl.onStart: 1.2 ms [Finished 1.694 s after backend start]
2023-07-05T15:12:08.563Z root INFO Backend NodeFileUploadService.configure: 2.0 ms [Finished 1.694 s after backend start]
2023-07-05T15:12:08.563Z daemon INFO Starting daemon from C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-07-05T15:12:08.563Z discovery-log INFO start
2023-07-05T15:12:08.564Z discovery-log INFO start new deferred
2023-07-05T15:12:08.564Z root INFO Backend HostedPluginLocalizationService.initialize: 0.4 ms [Finished 1.695 s after backend start]
2023-07-05T15:12:08.564Z root INFO Backend BoardDiscovery.onStart: 1.1 ms [Finished 1.696 s after backend start]
2023-07-05T15:12:08.564Z root INFO Backend FileDownloadEndpoint.configure: 1.1 ms [Finished 1.696 s after backend start]2023-07-05T15:12:08.564Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.698 s after backend start]
2023-07-05T15:12:08.564Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.698 s after backend start]
2023-07-05T15:12:08.566Z root INFO Backend HostedPluginReader.configure: 0.4 ms [Finished 1.699 s after backend start]
2023-07-05T15:12:08.568Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.699 s after backend start]
2023-07-05T15:12:08.568Z root INFO Backend PlotterBackendContribution.configure: 1.1 ms [Finished 1.700 s after backend start]
2023-07-05T15:12:08.570Z root INFO Theia app listening on http://localhost:61834.
2023-07-05T15:12:08.571Z root INFO Finished starting backend application: 7.2 ms [Finished 1.705 s after backend start]
2023-07-05T15:12:08.585Z root WARN The local plugin referenced by local-dir:/c%3A/Users/KSaleh/.arduinoIDE/plugins does not exist.
2023-07-05T15:12:08.585Z root WARN The local plugin referenced by local-dir:/c%3A/Users/KSaleh/.arduinoIDE/extensions does not exist.
2023-07-05T15:12:08.588Z root WARN The local plugin referenced by local-dir:C:\Users\KSaleh\.arduinoIDE\plugins does not exist.
2023-07-05T15:12:08.612Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.612Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-07-05T15:12:08.615Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.626Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-07-05T15:12:08.627Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.627Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-07-05T15:12:08.632Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.633Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-07-05T15:12:08.634Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.635Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-07-05T15:12:08.635Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.637Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-07-05T15:12:08.638Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.642Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-07-05T15:12:08.643Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.643Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-07-05T15:12:08.644Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-07-05T15:12:08.644Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.645Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-07-05T15:12:08.645Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.648Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-07-05T15:12:08.654Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.654Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-07-05T15:12:08.655Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.656Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-07-05T15:12:08.656Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.659Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-07-05T15:12:08.661Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.664Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-07-05T15:12:08.665Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.665Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-07-05T15:12:08.666Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.667Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-07-05T15:12:08.668Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.668Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-07-05T15:12:08.671Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.675Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-07-05T15:12:08.676Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.676Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-07-05T15:12:08.677Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-07-05T15:12:08.677Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-07-05T15:12:08.684Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\KSaleh\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\KSaleh\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-07-05T15:12:08.684Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-07-05T15:12:08.688Z config INFO Loaded the CLI configuration.
2023-07-05T15:12:08.689Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/KSaleh/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/KSaleh/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-07-05T15:12:08.689Z config INFO Validating the CLI configuration...
2023-07-05T15:12:08.691Z config INFO The CLI config is valid.
2023-07-05T15:12:08.692Z config INFO <<< Initialized the CLI configuration.
2023-07-05T15:12:08.708Z root INFO Resolve plugins list: 145.8 ms [Finished 1.842 s after backend start]
2023-07-05T15:12:08.712Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\cortex-debug\extension\dist\extension.js": 3.8 ms [Finished 1.846 s after backend start]
2023-07-05T15:12:08.717Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 5.2 ms [Finished 1.852 s after backend start]
2023-07-05T15:12:08.725Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-cpp\extension": 8.4 ms [Finished 1.860 s after backend start]
2023-07-05T15:12:08.727Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json\extension": 1.9 ms [Finished 1.862 s after backend start]
2023-07-05T15:12:08.728Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.6 ms [Finished 1.863 s after backend start]
2023-07-05T15:12:08.808Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-bg\extension": 79.9 ms [Finished 1.943 s after backend start]
2023-07-05T15:12:08.830Z daemon INFO INFO[0000] Using config file: c:\Users\KSaleh\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.32.2
INFO[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:61835
{"IP":"127.0.0.1","Port":"61835"}
2023-07-05T15:12:08.831Z daemon INFO Daemon is running.
2023-07-05T15:12:08.944Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-cs\extension": 135.9 ms [Finished 2.079 s after backend start]
2023-07-05T15:12:08.949Z daemon INFO INFO[0000] Loading hardware from: C:\Users\KSaleh\AppData\Local\Arduino15\packages
2023-07-05T15:12:09.041Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-de\extension": 97.2 ms [Finished 2.176 s after backend start]
2023-07-05T15:12:09.042Z daemon INFO INFO[0000] Loading package arduino from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\hardware
INFO[0000] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0000] Loaded platform platform="arduino:avr@1.8.4"
INFO[0000] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\tools
INFO[0000] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0000] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0000] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0000] Loading package builtin from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
INFO[0000] Loading package teensy from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\hardware
INFO[0000] Adding monitor tool protocol=teensy tool="teensy:teensy-monitor"
INFO[0000] Loaded platform platform="teensy:avr@1.57.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loaded tool tool="teensy:teensy-compile@5.4.1"
INFO[0000] Loaded tool tool="teensy:teensy-tools@1.57.2"
INFO[0000] Loaded tool tool="teensy:teensy-tools@teensy-discovery"
INFO[0000] Loaded tool tool="teensy:teensy-tools@teensy-monitor"
INFO[0000] Checking signature index="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\libraries" location=platform
INFO[0000] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" location=platform
INFO[0000] Loading libraries index file index="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-05T15:12:09.045Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-07-05T15:12:09.124Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-es\extension": 83.3 ms [Finished 2.259 s after backend start]
2023-07-05T15:12:09.193Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-fr\extension": 68.4 ms [Finished 2.328 s after backend start]
2023-07-05T15:12:09.193Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\libraries" location=ide
INFO[0000] Adding libraries dir dir="C:\\Users\\KSaleh\\Documents\\Arduino\\libraries" location=user
2023-07-05T15:12:09.243Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-hu\extension": 49.7 ms [Finished 2.377 s after backend start]
2023-07-05T15:12:09.312Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-it\extension": 69.5 ms [Finished 2.447 s after backend start]
2023-07-05T15:12:09.375Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ja\extension": 63.1 ms [Finished 2.510 s after backend start]
2023-07-05T15:12:09.444Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ko\extension": 68.1 ms [Finished 2.578 s after backend start]
2023-07-05T15:12:09.485Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-nl\extension": 41.0 ms [Finished 2.619 s after backend start]
2023-07-05T15:12:09.546Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pl\extension": 61.6 ms [Finished 2.681 s after backend start]
2023-07-05T15:12:09.605Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-pt-BR\extension": 59.1 ms [Finished 2.740 s after backend start]
2023-07-05T15:12:09.674Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-ru\extension": 68.1 ms [Finished 2.808 s after backend start]
2023-07-05T15:12:09.731Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-tr\extension": 57.4 ms [Finished 2.866 s after backend start]
2023-07-05T15:12:09.770Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-uk\extension": 38.7 ms [Finished 2.905 s after backend start]
2023-07-05T15:12:09.843Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\plugins\vscode-language-pack-zh-hans\extension": 72.6 ms [Finished 2.977 s after backend start]
2023-07-05T15:12:09.843Z root INFO Deploy plugins list: 145.8 ms [Finished 2.977 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-07-05T15:12:10.355Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 174.0 ms [Finished 1.680 s after frontend start]
2023-07-05T15:12:11.807Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-07-05T15:12:11.808Z daemon INFO INFO[0003] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-07-05T15:12:11.811Z root INFO core-client-provider [platform-index]
2023-07-05T15:12:11.815Z daemon INFO INFO[0003] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-07-05T15:12:12.273Z daemon INFO INFO[0003] Loading hardware from: C:\Users\KSaleh\AppData\Local\Arduino15\packages
2023-07-05T15:12:12.274Z daemon INFO INFO[0003] Loading package arduino from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\hardware
2023-07-05T15:12:12.277Z daemon INFO INFO[0003] Adding monitor tool protocol=serial tool="builtin:serial-monitor"
INFO[0003] Loaded platform platform="arduino:avr@1.8.4"
2023-07-05T15:12:12.277Z daemon INFO INFO[0003] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\tools
INFO[0003] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\arduino\tools
2023-07-05T15:12:12.280Z daemon INFO INFO[0003] Loaded tool tool="arduino:arduinoOTA@1.3.0"
INFO[0003] Loaded tool tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
INFO[0003] Loaded tool tool="arduino:avrdude@6.3.0-arduino17"
INFO[0003] Loading package builtin from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin
INFO[0003] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin\tools
INFO[0003] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\builtin\tools
INFO[0003] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0003] Loaded tool tool="builtin:dfu-discovery@0.1.2"
INFO[0003] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0003] Loaded tool tool="builtin:mdns-discovery@1.0.9"
INFO[0003] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0003] Loaded tool tool="builtin:serial-monitor@0.13.0"
2023-07-05T15:12:12.281Z daemon INFO INFO[0003] Loading package teensy from: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\hardware
2023-07-05T15:12:12.286Z daemon INFO INFO[0003] Adding monitor tool protocol=teensy tool="teensy:teensy-monitor"
INFO[0003] Loaded platform platform="teensy:avr@1.57.2"
2023-07-05T15:12:12.288Z daemon INFO INFO[0003] Checking existence of 'tools' path: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\tools
INFO[0003] Loading tools from dir: C:\Users\KSaleh\AppData\Local\Arduino15\packages\teensy\tools
INFO[0003] Loaded tool tool="teensy:teensy-compile@5.4.1"
INFO[0003] Loaded tool tool="teensy:teensy-tools@1.57.2"
INFO[0003] Loaded tool tool="teensy:teensy-tools@teensy-discovery"
INFO[0003] Loaded tool tool="teensy:teensy-tools@teensy-monitor"
2023-07-05T15:12:12.298Z daemon INFO INFO[0003] Checking signature index="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\package_index.json" signatureFile="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
2023-07-05T15:12:12.301Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-07-05T15:12:12.305Z daemon INFO INFO[0003] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.4\\libraries" location=platform
2023-07-05T15:12:12.307Z daemon INFO INFO[0003] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" location=platform
INFO[0003] Loading libraries index file index="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\library_index.json"
2023-07-05T15:12:12.433Z daemon INFO INFO[0003] Adding libraries dir dir="C:\\Users\\KSaleh\\AppData\\Local\\Arduino15\\libraries" location=ide
2023-07-05T15:12:12.434Z daemon INFO INFO[0003] Adding libraries dir dir="C:\\Users\\KSaleh\\Documents\\Arduino\\libraries" location=user
2023-07-05T15:12:14.892Z root ERROR Uncaught Exception:
2023-07-05T15:12:14.893Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
at isIndexUpdateRequiredBeforeInit (C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
at CoreClientProvider.evaluateErrorStatus (C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async ClientReadableStreamImpl.<anonymous> (C:\Users\KSaleh\AppData\Local\Programs\arduino-ide\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184:31)
[168:0705/101407.152:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
I have found that if you delete the package_teensy_index.json file in the arduino15 folder in AppData\local\arduino15 and delete the teensy folder in the packages folder and start the ide it fires right up. You will just have to follow the instructions for reinstalling teensy for Arduino 2.x
