IDE hangs on startup: "Error loading hardware platform: discovery teensy:teensy-discovery not found"
Hi
I'm having the same issue with Arduino 2.1.0 starting, it just keeps flashing on start up.
Please see log.
look forward to your response.
Thanks
2023-06-02 22:57:44 Using browser-only version of superagent in non-browser environment
2023-06-02 22:57:44 Configuration directory URI: 'file:///c%3A/Users/44782/.theia'
2023-06-02 22:57:44 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-06-02 22:57:44 2023-06-02T21:57:44.985Z root INFO Backend Object.initialize: 3.3 ms [Finished 1.143 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.986Z root INFO Backend Object.configure: 2.6 ms [Finished 1.143 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.986Z root INFO Backend MessagingContribution.onStart: 1.1 ms [Finished 1.143 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.986Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.172 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.987Z root INFO Backend DefaultWorkspaceServer.onStart: 0.2 ms [Finished 1.172 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.987Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.173 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.988Z root INFO Backend PluginLocalizationBackendContribution.initialize: 29.4 ms [Finished 1.173 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.988Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.173 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.989Z root INFO Backend ElectronTokenBackendContribution.configure: 0.6 ms [Finished 1.174 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.989Z config INFO >>> Initializing CLI configuration...
2023-06-02 22:57:44 2023-06-02T21:57:44.989Z root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 1.174 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.989Z root INFO Backend ConfigServiceImpl.onStart: 0.6 ms [Finished 1.174 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.990Z config INFO Loading CLI configuration from c:\Users\44782\.arduinoIDE\arduino-cli.yaml...
2023-06-02 22:57:44 2023-06-02T21:57:44.990Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.175 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.990Z root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 1.175 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.990Z root INFO Backend NodeFileUploadService.configure: 1.4 ms [Finished 1.176 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.990Z daemon INFO Starting daemon from C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z discovery-log INFO start
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z discovery-log INFO start new deferred
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 1.176 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z root INFO Backend BoardDiscovery.onStart: 0.7 ms [Finished 1.177 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.177 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.178 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.991Z root INFO Backend PluginApiContribution.configure: 0.3 ms [Finished 1.178 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.992Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 1.178 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.992Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 1.178 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.992Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 1.179 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.995Z root INFO Theia app listening on http://localhost:64074.
2023-06-02 22:57:44 2023-06-02T21:57:44.995Z root INFO Finished starting backend application: 4.5 ms [Finished 1.183 s after backend start]
2023-06-02 22:57:44 2023-06-02T21:57:44.999Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/plugins does not exist.
2023-06-02 22:57:44 2023-06-02T21:57:44.999Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/extensions does not exist.
2023-06-02 22:57:44 2023-06-02T21:57:44.999Z root WARN The local plugin referenced by local-dir:C:\Users\44782\.arduinoIDE\plugins does not exist.
2023-06-02 22:57:45 2023-06-02T21:57:45.012Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 22:57:45 2023-06-02T21:57:45.012Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.013Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.014Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.014Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 22:57:45 2023-06-02T21:57:45.014Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-06-02 22:57:45 2023-06-02T21:57:45.016Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\44782\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\44782\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\44782\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-06-02 22:57:45 2023-06-02T21:57:45.016Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-06-02 22:57:45 2023-06-02T21:57:45.017Z config INFO Loaded the CLI configuration.
2023-06-02 22:57:45 2023-06-02T21:57:45.017Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/44782/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/44782/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-06-02 22:57:45 2023-06-02T21:57:45.017Z config INFO Validating the CLI configuration...
2023-06-02 22:57:45 2023-06-02T21:57:45.018Z config INFO The CLI config is valid.
2023-06-02 22:57:45 2023-06-02T21:57:45.018Z config INFO <<< Initialized the CLI configuration.
2023-06-02 22:57:45 2023-06-02T21:57:45.026Z root INFO Resolve plugins list: 36.4 ms [Finished 1.213 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.029Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 2.9 ms [Finished 1.217 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.031Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.2 ms [Finished 1.219 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.037Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 5.7 ms [Finished 1.225 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.047Z daemon INFO e[36mINFOe[0m[0000] Using config file: c:\Users\44782\.arduinoIDE\arduino-cli.yaml
e[36mINFOe[0m[0000] arduino-cli.exe version 0.32.2
e[36mINFOe[0m[0000] Executing `arduino-cli daemon`
Daemon is now listening on 127.0.0.1:64075
{"IP":"127.0.0.1","Port":"64075"}
2023-06-02 22:57:45 2023-06-02T21:57:45.047Z daemon INFO Daemon is running.
2023-06-02 22:57:45 2023-06-02T21:57:45.055Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 18.2 ms [Finished 1.243 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.059Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 3.5 ms [Finished 1.246 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.059Z daemon INFO e[36mINFOe[0m[0000] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 22:57:45 2023-06-02T21:57:45.113Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 53.8 ms [Finished 1.300 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.113Z daemon INFO e[36mINFOe[0m[0000] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
e[36mINFOe[0m[0000] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
e[36mINFOe[0m[0000] Loaded platform                               e[36mplatforme[0m="arduino:avr@1.8.6"
e[36mINFOe[0m[0000] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
e[36mINFOe[0m[0000] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="arduino:arduinoOTA@1.3.0"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="arduino:avrdude@6.3.0-arduino17"
e[36mINFOe[0m[0000] Loading package builtin from: C:\Users\44782\AppData\Local\Arduino15\packages\builtin
e[36mINFOe[0m[0000] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
e[36mINFOe[0m[0000] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="builtin:ctags@5.8-arduino11"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.9"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="builtin:serial-discovery@1.4.0"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="builtin:serial-monitor@0.13.0"
e[36mINFOe[0m[0000] Loading package esp32 from: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\hardware
e[36mINFOe[0m[0000] Loaded platform                               e[36mplatforme[0m="esp32:esp32@1.0.6"
e[36mINFOe[0m[0000] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
e[36mINFOe[0m[0000] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="esp32:esptool_py@3.0.0"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="esp32:mkspiffs@0.2.3"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
e[36mINFOe[0m[0000] Loading package teensy from: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\hardware
e[36mINFOe[0m[0000] Adding monitor tool                           e[36mprotocole[0m=teensy e[36mtoole[0m="teensy:teensy-monitor"
e[36mINFOe[0m[0000] Loaded platform                               e[36mplatforme[0m="teensy:avr@1.57.2"
e[36mINFOe[0m[0000] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
e[36mINFOe[0m[0000] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="teensy:teensy-compile@5.4.1"
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="teensy:teensy-tools@1.57.2"
e[36mINFOe[0m[0000] Checking signature                            e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json" e[36msignatureFilee[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json.sig" e[36mtrustede[0m=true
e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" e[36mlocatione[0m=platform
e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" e[36mlocatione[0m=platform
e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" e[36mlocatione[0m=platform
e[36mINFOe[0m[0000] Loading libraries index file                  e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\library_index.json"
2023-06-02 22:57:45 2023-06-02T21:57:45.114Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 22:57:45 2023-06-02T21:57:45.175Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 61.8 ms [Finished 1.362 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.245Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 70.1 ms [Finished 1.432 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.245Z daemon INFO e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\Documents\\Arduino\\libraries" e[36mlocatione[0m=user
2023-06-02 22:57:45 2023-06-02T21:57:45.301Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 56.5 ms [Finished 1.489 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.341Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 39.5 ms [Finished 1.528 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.371Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 30.3 ms [Finished 1.559 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.411Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 40.1 ms [Finished 1.599 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.451Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 39.6 ms [Finished 1.638 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.492Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 40.7 ms [Finished 1.679 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.508Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 16.7 ms [Finished 1.696 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.550Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 41.0 ms [Finished 1.737 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.590Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 40.9 ms [Finished 1.778 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.636Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 45.6 ms [Finished 1.824 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.675Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 39.1 ms [Finished 1.863 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.703Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 27.7 ms [Finished 1.890 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.742Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 39.0 ms [Finished 1.929 s after backend start]
2023-06-02 22:57:45 2023-06-02T21:57:45.742Z root INFO Deploy plugins list: 36.4 ms [Finished 1.930 s after backend start]
2023-06-02 22:57:46 2023-06-02T21:57:46.735Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-06-02 22:57:46 2023-06-02T21:57:46.736Z daemon INFO e[36mINFOe[0m[0001] Updating index                                e[36murle[0m="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-02 22:57:46 2023-06-02T21:57:46.736Z daemon INFO e[36mINFOe[0m[0001] Starting download                             e[36murle[0m="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-02 22:57:46 2023-06-02T21:57:46.737Z root INFO core-client-provider [platform-index]
2023-06-02 22:57:47 2023-06-02T21:57:47.082Z daemon INFO e[36mINFOe[0m[0002] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 22:57:47 2023-06-02T21:57:47.083Z daemon INFO e[36mINFOe[0m[0002] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
2023-06-02 22:57:47 2023-06-02T21:57:47.084Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
e[36mINFOe[0m[0002] Loaded platform                               e[36mplatforme[0m="arduino:avr@1.8.6"
2023-06-02 22:57:47 2023-06-02T21:57:47.085Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
e[36mINFOe[0m[0002] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
2023-06-02 22:57:47 2023-06-02T21:57:47.085Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:arduinoOTA@1.3.0"
2023-06-02 22:57:47 2023-06-02T21:57:47.085Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-02 22:57:47 2023-06-02T21:57:47.085Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avrdude@6.3.0-arduino17"
2023-06-02 22:57:47 2023-06-02T21:57:47.085Z daemon INFO e[36mINFOe[0m[0002] Loading package builtin from: C:\Users\44782\AppData\Local\Arduino15\packages\builtin
2023-06-02 22:57:47 2023-06-02T21:57:47.086Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
e[36mINFOe[0m[0002] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
2023-06-02 22:57:47 2023-06-02T21:57:47.086Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:ctags@5.8-arduino11"
2023-06-02 22:57:47 2023-06-02T21:57:47.086Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.9"
2023-06-02 22:57:47 2023-06-02T21:57:47.086Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-discovery@1.4.0"
2023-06-02 22:57:47 2023-06-02T21:57:47.086Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-monitor@0.13.0"
2023-06-02 22:57:47 2023-06-02T21:57:47.087Z daemon INFO e[36mINFOe[0m[0002] Loading package esp32 from: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\hardware
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
e[36mINFOe[0m[0002] Loaded platform                               e[36mplatforme[0m="esp32:esp32@1.0.6"
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
e[36mINFOe[0m[0002] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:esptool_py@3.0.0"
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:mkspiffs@0.2.3"
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2023-06-02 22:57:47 2023-06-02T21:57:47.094Z daemon INFO e[36mINFOe[0m[0002] Loading package teensy from: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\hardware
2023-06-02 22:57:47 2023-06-02T21:57:47.096Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=teensy e[36mtoole[0m="teensy:teensy-monitor"
e[36mINFOe[0m[0002] Loaded platform                               e[36mplatforme[0m="teensy:avr@1.57.2"
2023-06-02 22:57:47 2023-06-02T21:57:47.096Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
e[36mINFOe[0m[0002] Loading tools from dir: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
2023-06-02 22:57:47 2023-06-02T21:57:47.096Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-compile@5.4.1"
2023-06-02 22:57:47 2023-06-02T21:57:47.097Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-tools@1.57.2"
2023-06-02 22:57:47 2023-06-02T21:57:47.105Z daemon INFO e[36mINFOe[0m[0002] Checking signature                            e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json" e[36msignatureFilee[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json.sig" e[36mtrustede[0m=true
2023-06-02 22:57:47 2023-06-02T21:57:47.106Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 22:57:47 2023-06-02T21:57:47.107Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 22:57:47 2023-06-02T21:57:47.109Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 22:57:47 2023-06-02T21:57:47.110Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" e[36mlocatione[0m=platform
e[36mINFOe[0m[0002] Loading libraries index file                  e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\library_index.json"
2023-06-02 22:57:47 2023-06-02T21:57:47.222Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
2023-06-02 22:57:47 2023-06-02T21:57:47.222Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\Documents\\Arduino\\libraries" e[36mlocatione[0m=user
2023-06-02 22:57:47 2023-06-02T21:57:47.462Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 122.3 ms [Finished 1.323 s after frontend start]
2023-06-02 22:57:48 2023-06-02T21:57:48.682Z root ERROR Uncaught Exception:
2023-06-02 22:57:48 2023-06-02T21:57:48.682Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
    at isIndexUpdateRequiredBeforeInit (C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
    at CoreClientProvider.evaluateErrorStatus (C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
    at processTicksAndRejections (node:internal/process/task_queues:96:5)
    at async ClientReadableStreamImpl.<anonymous> (C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184:31)
2023-06-02 23:02:38 Using browser-only version of superagent in non-browser environment
2023-06-02 23:02:38 Configuration directory URI: 'file:///c%3A/Users/44782/.theia'
2023-06-02 23:02:38 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-06-02 23:02:38 2023-06-02T22:02:38.553Z root INFO Backend Object.initialize: 3.1 ms [Finished 1.152 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.553Z root INFO Backend Object.configure: 2.5 ms [Finished 1.152 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.553Z root INFO Backend MessagingContribution.onStart: 1.0 ms [Finished 1.152 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.554Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.182 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.554Z root INFO Backend DefaultWorkspaceServer.onStart: 0.2 ms [Finished 1.182 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.555Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.182 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.556Z root INFO Backend PluginLocalizationBackendContribution.initialize: 29.9 ms [Finished 1.182 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.556Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.182 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.556Z root INFO Backend ElectronTokenBackendContribution.configure: 0.6 ms [Finished 1.183 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.557Z config INFO >>> Initializing CLI configuration...
2023-06-02 23:02:38 2023-06-02T22:02:38.557Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.183 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.557Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.183 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z config INFO Loading CLI configuration from c:\Users\44782\.arduinoIDE\arduino-cli.yaml...
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.184 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 1.185 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend NodeFileUploadService.configure: 1.5 ms [Finished 1.185 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z daemon INFO Starting daemon from C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z discovery-log INFO start
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z discovery-log INFO start new deferred
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 1.186 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend BoardDiscovery.onStart: 0.7 ms [Finished 1.186 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.558Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.186 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.559Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.187 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.559Z root INFO Backend PluginApiContribution.configure: 0.3 ms [Finished 1.187 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.559Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 1.188 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.559Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 1.188 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.559Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 1.189 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.562Z root INFO Theia app listening on http://localhost:59695.
2023-06-02 23:02:38 2023-06-02T22:02:38.562Z root INFO Finished starting backend application: 3.9 ms [Finished 1.191 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.566Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/plugins does not exist.
2023-06-02 23:02:38 2023-06-02T22:02:38.566Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/extensions does not exist.
2023-06-02 23:02:38 2023-06-02T22:02:38.566Z root WARN The local plugin referenced by local-dir:C:\Users\44782\.arduinoIDE\plugins does not exist.
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.579Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.580Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-06-02 23:02:38 2023-06-02T22:02:38.583Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\44782\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\44782\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\44782\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-06-02 23:02:38 2023-06-02T22:02:38.583Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-06-02 23:02:38 2023-06-02T22:02:38.583Z config INFO Loaded the CLI configuration.
2023-06-02 23:02:38 2023-06-02T22:02:38.584Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/44782/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/44782/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-06-02 23:02:38 2023-06-02T22:02:38.584Z config INFO Validating the CLI configuration...
2023-06-02 23:02:38 2023-06-02T22:02:38.585Z config INFO The CLI config is valid.
2023-06-02 23:02:38 2023-06-02T22:02:38.585Z config INFO <<< Initialized the CLI configuration.
2023-06-02 23:02:38 2023-06-02T22:02:38.592Z root INFO Resolve plugins list: 34.5 ms [Finished 1.221 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.595Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 2.8 ms [Finished 1.224 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.597Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.1 ms [Finished 1.226 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.603Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 5.8 ms [Finished 1.232 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.603Z daemon INFO e[36mINFOe[0m[0000] Using config file: c:\Users\44782\.arduinoIDE\arduino-cli.yaml
2023-06-02 23:02:38 2023-06-02T22:02:38.613Z daemon INFO Daemon is now listening on 127.0.0.1:59696
{"IP":"127.0.0.1","Port":"59696"}
2023-06-02 23:02:38 2023-06-02T22:02:38.613Z daemon INFO Daemon is running.
2023-06-02 23:02:38 2023-06-02T22:02:38.618Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 14.7 ms [Finished 1.247 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.625Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 7.3 ms [Finished 1.254 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.625Z daemon INFO e[36mINFOe[0m[0000] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 23:02:38 2023-06-02T22:02:38.678Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 53.5 ms [Finished 1.308 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.679Z daemon INFO e[36mINFOe[0m[0000] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
e[36mINFOe[0m[0000] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.6"
2023-06-02 23:02:38 2023-06-02T22:02:38.680Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 23:02:38 2023-06-02T22:02:38.741Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 62.1 ms [Finished 1.370 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.811Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 70.0 ms [Finished 1.440 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.811Z daemon INFO e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
2023-06-02 23:02:38 2023-06-02T22:02:38.867Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 56.1 ms [Finished 1.496 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.907Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 40.3 ms [Finished 1.536 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.938Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 30.9 ms [Finished 1.567 s after backend start]
2023-06-02 23:02:38 2023-06-02T22:02:38.980Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 41.4 ms [Finished 1.609 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.023Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 43.3 ms [Finished 1.652 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.064Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 40.8 ms [Finished 1.693 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.081Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 16.9 ms [Finished 1.710 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.123Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 42.4 ms [Finished 1.752 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.165Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 41.6 ms [Finished 1.794 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.209Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 43.8 ms [Finished 1.838 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.249Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 40.6 ms [Finished 1.879 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.277Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 27.2 ms [Finished 1.906 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.314Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 37.4 ms [Finished 1.943 s after backend start]
2023-06-02 23:02:39 2023-06-02T22:02:39.314Z root INFO Deploy plugins list: 34.5 ms [Finished 1.943 s after backend start]
2023-06-02 23:02:40 2023-06-02T22:02:40.337Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-06-02 23:02:40 2023-06-02T22:02:40.340Z root INFO core-client-provider [platform-index]
2023-06-02 23:02:40 2023-06-02T22:02:40.340Z daemon INFO e[36mINFOe[0m[0001] Updating index                                e[36murle[0m="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-02 23:02:40 2023-06-02T22:02:40.664Z daemon INFO e[36mINFOe[0m[0002] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 23:02:40 2023-06-02T22:02:40.664Z daemon INFO e[36mINFOe[0m[0002] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:arduinoOTA@1.3.0"
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avrdude@6.3.0-arduino17"
2023-06-02 23:02:40 2023-06-02T22:02:40.666Z daemon INFO e[36mINFOe[0m[0002] Loading package builtin from: C:\Users\44782\AppData\Local\Arduino15\packages\builtin
2023-06-02 23:02:40 2023-06-02T22:02:40.667Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
2023-06-02 23:02:40 2023-06-02T22:02:40.667Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:ctags@5.8-arduino11"
2023-06-02 23:02:40 2023-06-02T22:02:40.667Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.6"
2023-06-02 23:02:40 2023-06-02T22:02:40.667Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-discovery@1.4.0"
2023-06-02 23:02:40 2023-06-02T22:02:40.667Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-monitor@0.13.0"
2023-06-02 23:02:40 2023-06-02T22:02:40.668Z daemon INFO e[36mINFOe[0m[0002] Loading package esp32 from: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\hardware
2023-06-02 23:02:40 2023-06-02T22:02:40.674Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
2023-06-02 23:02:40 2023-06-02T22:02:40.675Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
2023-06-02 23:02:40 2023-06-02T22:02:40.675Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:esptool_py@3.0.0"
2023-06-02 23:02:40 2023-06-02T22:02:40.675Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:mkspiffs@0.2.3"
2023-06-02 23:02:40 2023-06-02T22:02:40.675Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2023-06-02 23:02:40 2023-06-02T22:02:40.675Z daemon INFO e[36mINFOe[0m[0002] Loading package teensy from: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\hardware
2023-06-02 23:02:40 2023-06-02T22:02:40.677Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=teensy e[36mtoole[0m="teensy:teensy-monitor"
2023-06-02 23:02:40 2023-06-02T22:02:40.677Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
2023-06-02 23:02:40 2023-06-02T22:02:40.677Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-compile@5.4.1"
2023-06-02 23:02:40 2023-06-02T22:02:40.677Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-tools@1.57.2"
2023-06-02 23:02:40 2023-06-02T22:02:40.685Z daemon INFO e[36mINFOe[0m[0002] Checking signature                            e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json" e[36msignatureFilee[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json.sig" e[36mtrustede[0m=true
2023-06-02 23:02:40 2023-06-02T22:02:40.687Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 23:02:40 2023-06-02T22:02:40.688Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:02:40 2023-06-02T22:02:40.690Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:02:40 2023-06-02T22:02:40.691Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:02:40 2023-06-02T22:02:40.797Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
2023-06-02 23:02:40 2023-06-02T22:02:40.797Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\Documents\\Arduino\\libraries" e[36mlocatione[0m=user
2023-06-02 23:02:41 2023-06-02T22:02:41.036Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 122.9 ms [Finished 1.332 s after frontend start]
2023-06-02 23:02:42 2023-06-02T22:02:42.252Z root ERROR Uncaught Exception:
2023-06-02 23:02:42 2023-06-02T22:02:42.252Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
2023-06-02 23:04:20 Using browser-only version of superagent in non-browser environment
2023-06-02 23:04:20 Configuration directory URI: 'file:///c%3A/Users/44782/.theia'
2023-06-02 23:04:20 Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-06-02 23:04:20 2023-06-02T22:04:20.584Z root INFO Backend Object.initialize: 3.2 ms [Finished 1.131 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.584Z root INFO Backend Object.configure: 2.6 ms [Finished 1.131 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.584Z root INFO Backend MessagingContribution.onStart: 1.1 ms [Finished 1.131 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.585Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.161 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.585Z root INFO Backend DefaultWorkspaceServer.onStart: 0.2 ms [Finished 1.161 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.586Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.161 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.587Z root INFO Backend PluginLocalizationBackendContribution.initialize: 29.4 ms [Finished 1.161 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.587Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.161 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.587Z root INFO Backend ElectronTokenBackendContribution.configure: 0.6 ms [Finished 1.162 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.588Z config INFO >>> Initializing CLI configuration...
2023-06-02 23:04:20 2023-06-02T22:04:20.588Z root INFO Backend PluginDeployerContribution.initialize: 0.4 ms [Finished 1.162 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.588Z root INFO Backend ConfigServiceImpl.onStart: 0.6 ms [Finished 1.162 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z config INFO Loading CLI configuration from c:\Users\44782\.arduinoIDE\arduino-cli.yaml...
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.163 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 1.164 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z root INFO Backend NodeFileUploadService.configure: 1.4 ms [Finished 1.164 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z daemon INFO Starting daemon from C:\Program Files (x86)\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z discovery-log INFO start
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z discovery-log INFO start new deferred
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 1.164 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.589Z root INFO Backend BoardDiscovery.onStart: 0.7 ms [Finished 1.165 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.165 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend AuthenticationServiceImpl.onStart: 0.3 ms [Finished 1.166 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend PluginApiContribution.configure: 0.3 ms [Finished 1.166 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 1.166 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 1.167 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.590Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 1.167 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.593Z root INFO Theia app listening on http://localhost:54898.
2023-06-02 23:04:20 2023-06-02T22:04:20.594Z root INFO Finished starting backend application: 4.1 ms [Finished 1.170 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.597Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/plugins does not exist.
2023-06-02 23:04:20 2023-06-02T22:04:20.597Z root WARN The local plugin referenced by local-dir:/c%3A/Users/44782/.arduinoIDE/extensions does not exist.
2023-06-02 23:04:20 2023-06-02T22:04:20.597Z root WARN The local plugin referenced by local-dir:C:\Users\44782\.arduinoIDE\plugins does not exist.
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.8" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.610Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.611Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-06-02 23:04:20 2023-06-02T22:04:20.614Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\44782\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\44782\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\44782\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-06-02 23:04:20 2023-06-02T22:04:20.614Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-06-02 23:04:20 2023-06-02T22:04:20.614Z config INFO Loaded the CLI configuration.
2023-06-02 23:04:20 2023-06-02T22:04:20.615Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/44782/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/44782/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-06-02 23:04:20 2023-06-02T22:04:20.615Z config INFO Validating the CLI configuration...
2023-06-02 23:04:20 2023-06-02T22:04:20.616Z config INFO The CLI config is valid.
2023-06-02 23:04:20 2023-06-02T22:04:20.616Z config INFO <<< Initialized the CLI configuration.
2023-06-02 23:04:20 2023-06-02T22:04:20.624Z root INFO Resolve plugins list: 35.8 ms [Finished 1.201 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.627Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 2.9 ms [Finished 1.204 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.630Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.8" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.2 ms [Finished 1.207 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.635Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 5.7 ms [Finished 1.212 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.645Z daemon INFO e[36mINFOe[0m[0000] Using config file: c:\Users\44782\.arduinoIDE\arduino-cli.yaml
Daemon is now listening on 127.0.0.1:54899
{"IP":"127.0.0.1","Port":"54899"}
2023-06-02 23:04:20 2023-06-02T22:04:20.645Z daemon INFO Daemon is running.
2023-06-02 23:04:20 2023-06-02T22:04:20.653Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 17.8 ms [Finished 1.230 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.657Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 3.6 ms [Finished 1.234 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.657Z daemon INFO e[36mINFOe[0m[0000] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 23:04:20 2023-06-02T22:04:20.710Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 53.7 ms [Finished 1.287 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.711Z daemon INFO e[36mINFOe[0m[0000] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
2023-06-02 23:04:20 2023-06-02T22:04:20.712Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 23:04:20 2023-06-02T22:04:20.772Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 61.2 ms [Finished 1.349 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.842Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 69.8 ms [Finished 1.418 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.842Z daemon INFO e[36mINFOe[0m[0000] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
2023-06-02 23:04:20 2023-06-02T22:04:20.898Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 56.3 ms [Finished 1.475 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.937Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 39.5 ms [Finished 1.514 s after backend start]
2023-06-02 23:04:20 2023-06-02T22:04:20.969Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 31.6 ms [Finished 1.546 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.010Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 40.5 ms [Finished 1.587 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.050Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 40.2 ms [Finished 1.627 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.092Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 42.1 ms [Finished 1.669 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.109Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 16.7 ms [Finished 1.686 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.151Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 41.7 ms [Finished 1.728 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.191Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 40.1 ms [Finished 1.768 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.235Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 44.0 ms [Finished 1.812 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.275Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 40.2 ms [Finished 1.852 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.301Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 25.8 ms [Finished 1.878 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.340Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files (x86)\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 39.1 ms [Finished 1.917 s after backend start]
2023-06-02 23:04:21 2023-06-02T22:04:21.340Z root INFO Deploy plugins list: 35.8 ms [Finished 1.917 s after backend start]
2023-06-02 23:04:22 2023-06-02T22:04:22.307Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-06-02 23:04:22 2023-06-02T22:04:22.308Z daemon INFO e[36mINFOe[0m[0001] Updating index                                e[36murle[0m="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-02 23:04:22 2023-06-02T22:04:22.308Z daemon INFO e[36mINFOe[0m[0001] Starting download                             e[36murle[0m="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-06-02 23:04:22 2023-06-02T22:04:22.309Z root INFO core-client-provider [platform-index]
2023-06-02 23:04:22 2023-06-02T22:04:22.683Z daemon INFO e[36mINFOe[0m[0002] Loading hardware from: C:\Users\44782\AppData\Local\Arduino15\packages
2023-06-02 23:04:22 2023-06-02T22:04:22.684Z daemon INFO e[36mINFOe[0m[0002] Loading package arduino from: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\hardware
2023-06-02 23:04:22 2023-06-02T22:04:22.685Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
2023-06-02 23:04:22 2023-06-02T22:04:22.685Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\arduino\tools
2023-06-02 23:04:22 2023-06-02T22:04:22.685Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:arduinoOTA@1.3.0"
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="arduino:avrdude@6.3.0-arduino17"
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Loading package builtin from: C:\Users\44782\AppData\Local\Arduino15\packages\builtin
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\builtin\tools
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:ctags@5.8-arduino11"
2023-06-02 23:04:22 2023-06-02T22:04:22.686Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:mdns-discovery@1.0.9"
2023-06-02 23:04:22 2023-06-02T22:04:22.687Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-discovery@1.4.0"
2023-06-02 23:04:22 2023-06-02T22:04:22.687Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="builtin:serial-monitor@0.13.0"
2023-06-02 23:04:22 2023-06-02T22:04:22.687Z daemon INFO e[36mINFOe[0m[0002] Loading package esp32 from: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\hardware
2023-06-02 23:04:22 2023-06-02T22:04:22.694Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=serial e[36mtoole[0m="builtin:serial-monitor"
2023-06-02 23:04:22 2023-06-02T22:04:22.694Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\esp32\tools
2023-06-02 23:04:22 2023-06-02T22:04:22.695Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:esptool_py@3.0.0"
2023-06-02 23:04:22 2023-06-02T22:04:22.695Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:mkspiffs@0.2.3"
2023-06-02 23:04:22 2023-06-02T22:04:22.695Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="esp32:xtensa-esp32-elf-gcc@1.22.0-97-gc752ad5-5.2.0"
2023-06-02 23:04:22 2023-06-02T22:04:22.695Z daemon INFO e[36mINFOe[0m[0002] Loading package teensy from: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\hardware
2023-06-02 23:04:22 2023-06-02T22:04:22.697Z daemon INFO e[36mINFOe[0m[0002] Adding monitor tool                           e[36mprotocole[0m=teensy e[36mtoole[0m="teensy:teensy-monitor"
2023-06-02 23:04:22 2023-06-02T22:04:22.697Z daemon INFO e[36mINFOe[0m[0002] Checking existence of 'tools' path: C:\Users\44782\AppData\Local\Arduino15\packages\teensy\tools
2023-06-02 23:04:22 2023-06-02T22:04:22.697Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-compile@5.4.1"
2023-06-02 23:04:22 2023-06-02T22:04:22.697Z daemon INFO e[36mINFOe[0m[0002] Loaded tool                                   e[36mtoole[0m="teensy:teensy-tools@1.57.2"
2023-06-02 23:04:22 2023-06-02T22:04:22.705Z daemon INFO e[36mINFOe[0m[0002] Checking signature                            e[36mindexe[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json" e[36msignatureFilee[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\package_index.json.sig" e[36mtrustede[0m=true
2023-06-02 23:04:22 2023-06-02T22:04:22.707Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
2023-06-02 23:04:22 2023-06-02T22:04:22.708Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:04:22 2023-06-02T22:04:22.709Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:04:22 2023-06-02T22:04:22.711Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\libraries" e[36mlocatione[0m=platform
2023-06-02 23:04:22 2023-06-02T22:04:22.821Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\AppData\\Local\\Arduino15\\libraries" e[36mlocatione[0m=ide
2023-06-02 23:04:22 2023-06-02T22:04:22.821Z daemon INFO e[36mINFOe[0m[0002] Adding libraries dir                          e[36mdire[0m="C:\\Users\\44782\\Documents\\Arduino\\libraries" e[36mlocatione[0m=user
2023-06-02 23:04:23 2023-06-02T22:04:23.070Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 126.6 ms [Finished 1.333 s after frontend start]
2023-06-02 23:04:24 2023-06-02T22:04:24.301Z root ERROR Uncaught Exception:
2023-06-02 23:04:24 2023-06-02T22:04:24.301Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
@ptillisch Have you had chance to review my log ?
