IDE hangs on startup: "Invalid additional URL"
Windows PowerShell
Copyright (C) Microsoft Corporation. All rights reserved.
Install the latest PowerShell for new features and improvements! https://aka.ms/PSWindows
PS C:\Users\xrost\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.4
Checking for frontend application configuration customizations. Module path: C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 22780
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/xrost/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-03-16T11:04:46.808Z root INFO Backend Object.initialize: 6.4 ms [Finished 1.003 s after backend start]
2025-03-16T11:04:46.810Z root INFO Backend Object.configure: 5.1 ms [Finished 1.003 s after backend start]
2025-03-16T11:04:46.810Z root INFO Backend s.onStart: 3.1 ms [Finished 1.003 s after backend start]
2025-03-16T11:04:46.810Z root INFO Backend s.configure: 0.7 ms [Finished 1.033 s after backend start]
2025-03-16T11:04:46.811Z root INFO Backend d.onStart: 0.5 ms [Finished 1.034 s after backend start]
2025-03-16T11:04:46.813Z root INFO Backend d.configure: 0.3 ms [Finished 1.034 s after backend start]
2025-03-16T11:04:46.815Z root INFO Backend d.initialize: 30.8 ms [Finished 1.034 s after backend start]
2025-03-16T11:04:46.815Z root INFO Backend c.onStart: 0.5 ms [Finished 1.034 s after backend start]
2025-03-16T11:04:46.816Z root INFO Backend a.configure: 2.0 ms [Finished 1.037 s after backend start]
2025-03-16T11:04:46.819Z config INFO >>> Initializing CLI configuration...
2025-03-16T11:04:46.819Z root INFO Backend c.initialize: 0.7 ms [Finished 1.037 s after backend start]
2025-03-16T11:04:46.819Z root INFO Backend x.onStart: 1.0 ms [Finished 1.038 s after backend start]
2025-03-16T11:04:46.820Z config INFO Loading CLI configuration from c:\Users\xrost\.arduinoIDE\arduino-cli.yaml...
2025-03-16T11:04:46.821Z daemon INFO Starting daemon from C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-03-16T11:04:46.821Z root INFO Backend a.initialize: 0.9 ms [Finished 1.039 s after backend start]
2025-03-16T11:04:46.821Z root INFO Backend w.onStart: 2.8 ms [Finished 1.041 s after backend start]
2025-03-16T11:04:46.821Z root INFO Backend r.configure: 3.9 ms [Finished 1.042 s after backend start]
2025-03-16T11:04:46.821Z discovery-log INFO start
2025-03-16T11:04:46.821Z discovery-log INFO start new deferred
2025-03-16T11:04:46.821Z root INFO Backend d.initialize: 1.0 ms [Finished 1.043 s after backend start]
2025-03-16T11:04:46.821Z root INFO Backend y.onStart: 3.4 ms [Finished 1.045 s after backend start]
2025-03-16T11:04:46.821Z root INFO Backend r.configure: 2.8 ms [Finished 1.046 s after backend start]
2025-03-16T11:04:46.822Z root INFO Backend a.onStart: 0.8 ms [Finished 1.048 s after backend start]
2025-03-16T11:04:46.822Z root INFO Backend h.configure: 0.7 ms [Finished 1.048 s after backend start]
2025-03-16T11:04:46.822Z root INFO Backend s.configure: 0.2 ms [Finished 1.048 s after backend start]
2025-03-16T11:04:46.822Z root INFO Backend l.configure: 0.1 ms [Finished 1.048 s after backend start]
2025-03-16T11:04:46.827Z root INFO Theia app listening on http://127.0.0.1:5738.
2025-03-16T11:04:46.827Z root INFO Finished starting backend application: 5.8 ms [Finished 1.054 s after backend start]
2025-03-16T11:04:46.828Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xrost/.arduinoIDE/plugins does not exist.
2025-03-16T11:04:46.828Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xrost/.arduinoIDE/extensions does not exist.
2025-03-16T11:04:46.828Z root WARN The local plugin referenced by local-dir:C:\Users\xrost\.arduinoIDE\plugins does not exist.
2025-03-16T11:04:46.846Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["compiler.cpp.extra_flags\": \"-std=c++17","http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\xrost\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\xrost\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\xrost\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\xrost\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"cs","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2025-03-16T11:04:46.846Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-03-16T11:04:46.846Z config INFO Loaded the CLI configuration.
Restoring workspace roots: c:\Users\xrost\Desktop\rccar\rccar.ino
isTempSketch: false. Input was c:\Users\xrost\Desktop\rccar\rccar.ino
2025-03-16T11:04:46.955Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/xrost/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/xrost/Documents/Arduino","additionalUrls":["compiler.cpp.extra_flags\": \"-std=c++17","http://arduino.esp8266.com/stable/package_esp8266com_index.json","https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"cs"}
2025-03-16T11:04:46.955Z config INFO Validating the CLI configuration...
2025-03-16T11:04:46.956Z config INFO The CLI config is valid.
2025-03-16T11:04:46.956Z config INFO <<< Initialized the CLI configuration.
2025-03-16T11:04:46.991Z root INFO Resolve plugins list: 171.1 ms [Finished 1.217 s after backend start]
2025-03-16T11:04:47.070Z daemon INFO time="2025-03-16T12:04:47+01:00" level=info msg="arduino-cli version 1.1.1"
2025-03-16T11:04:47.082Z daemon INFO time="2025-03-16T12:04:47+01:00" level=info msg="Using config file: c:\\Users\\xrost\\.arduinoIDE\\arduino-cli.yaml"
2025-03-16T11:04:47.082Z daemon INFO time="2025-03-16T12:04:47+01:00" level=info msg="Executing `arduino-cli daemon`"
2025-03-16T11:04:47.093Z daemon INFO Daemon is now listening on 127.0.0.1:5739
{"IP":"127.0.0.1","Port":"5739"}
2025-03-16T11:04:47.093Z daemon INFO Daemon is running.
2025-03-16T11:04:47.117Z root ERROR Detected an error response during the gRPC core client initialization: code: 3, message: Invalid additional URL: parse "compiler.cpp.extra_flags\": \"-std=c++17": first path segment in URL cannot contain colon
2025-03-16T11:04:47.117Z daemon INFO time="2025-03-16T12:04:47+01:00" level=info msg="Updating index" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-16T11:04:47.118Z daemon INFO time="2025-03-16T12:04:47+01:00" level=info msg="Starting download" url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2025-03-16T11:04:47.495Z daemon INFO time="2025-03-16T12:04:47+01:00" level=warning msg="unable to parse additional URL: compiler.cpp.extra_flags\": \"-std=c++17"
2025-03-16T11:04:47.500Z daemon INFO panic: runtime error: invalid memory address or nil pointer dereference
[signal 0xc0000005 code=0x0 addr=0x8 pc=0xea02b4]
goroutine 50 [running]:
net/url.(*URL).String(0x0)
        /usr/local/go/src/net/url/url.go:817 +0x34
2025-03-16T11:04:47.501Z daemon INFO github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex.func1(...)
        /home/build/commands/instances.go:538
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).UpdateIndex(0xc000094a80
2025-03-16T11:04:47.502Z daemon INFO , 0xc00040c940, {0x1ca5260, 0xc000095680})
2025-03-16T11:04:47.502Z daemon INFO 566 +0x79f
github.com/arduino/arduino-cli/commands.firstUpdate({0x1ca0308,
2025-03-16T11:04:47.502Z daemon INFO 0xc00012b2c0}, {0x1cb1468, 0xc000094a80}, 0xc00012b500, 0xc0000a22e0, 0xc0001d9bd0, {0xc000306660, 0x3, 0x4})
        /home/build/commands/instances.go:671 +0x437
github.com/arduino/arduino-cli/commands.(*arduinoCoreServerImpl).Init(0xc000094a80, 0xc000428730, {0x1ca5940, 0xc0001d9ba0})
        /home/build/commands/instances.go:193 +0x4e5
github.com/arduino/arduino-cli/rpc/cc/arduino/cli/commands/v1._ArduinoCoreService_Init_Handler({0x18ddd40, 0xc000094a80}, {0x1ca33b8, 0xc00025c0f0})
        /home/build/rpc/cc/arduino/cli/commands/v1/commands_grpc.pb.go:1191 +0x10a
google.golang.org/grpc.(*Server).processStreamingRPC(0xc00060a000, {0x1ca0308, 0xc00012b1d0}, {0x1ca7a60, 0xc0000e0b60}
2025-03-16T11:04:47.502Z daemon INFO , 0xc000098240, 0xc0004247b0, 0x241a260, 0x0)
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1688 +
2025-03-16T11:04:47.503Z daemon INFO 0x1208
google.golang.org/grpc.(*Server).handleStream(0xc00060a000, {0x1ca7a60, 0xc0000e0b60}, 0xc000098240)
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1809 +0xe3a
google.golang.org/grpc.(*Server).serveStreams.func2.1()
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1029 +0x8b
created by google.golang.org/grpc.(*Server).serveStreams.func2 in goroutine 12
        /go/pkg/mod/google.golang.org/grpc@v1.68.0/server.go:1040 +0x125
2025-03-16T11:04:47.513Z root ERROR Error occurred while initializing the core gRPC client provider Error: 14 UNAVAILABLE: read ECONNRESET
    at t.callErrorFromStatus (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
    at Object.onReceiveStatus (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:949334)
    at Object.onReceiveStatus (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
    at C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeServerStreamRequest (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:949101)
    at s.init (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
    at C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:776931
    at new Promise (<anonymous>)
    at v.initInstance (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:776897)
    at v.initInstanceWithFallback (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:775753)
    at v.create (C:\Users\xrost\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:775658)
    at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-03-16T11:04:47.513Z root ERROR Uncaught Exception:  Error: 14 UNAVAILABLE: read ECONNRESET
2025-03-16T11:04:47.514Z root ERROR Error: 14 UNAVAILABLE: read ECONNRESET
for call at
2025-03-16T11:04:47.521Z daemon INFO Daemon exited with exit code: 2.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-03-16T11:04:50.196Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 410.6 ms [Finished 3.200 s after frontend start]
2025-03-16T11:04:50.206Z root WARN A command editor.action.toggleStickyScroll is already registered.
[2796:0316/120450.380:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+´"
2025-03-16T11:04:50.472Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 119.8 ms [Finished 3.518 s after frontend start]
[2796:0316/120450.605:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+´"
2025-03-16T11:04:51.787Z root INFO Deploy plugins list: 171.1 ms [Finished 6.013 s after backend start]
Windows PowerShell
Arduino IDE 2.3.4
for call at
for call at
Close the IDE and edit the file C:\Users\xrost\.arduinoIDE\arduino-cli-all.yaml using a normal text editor. Below is what the beginnings will look like
board_manager:
    additional_urls:
        - https://arduino.esp8266.com/stable/package_esp8266com_index.json
        - https://downloadcd.dfrobot.com.cn/boards/package_DFRobot_index.json
        - https://espressif.github.io/arduino-esp32/package_esp32_index.json
        - https://github.com/HelTecAutomation/CubeCell-Arduino/releases/download/V1.5.0/package_CubeCell_index.json
        - https://mcudude.github.io/MegaCore/package_MCUdude_MegaCore_index.json
        - https://mcudude.github.io/MegaCoreX/package_MCUdude_MegaCoreX_index.json
        - https://mcudude.github.io/MicroCore/package_MCUdude_MicroCore_index.json
        - https://mcudude.github.io/MightyCore/package_MCUdude_MightyCore_index.json
        - https://mcudude.github.io/MiniCore/package_MCUdude_MiniCore_index.json
        - https://raw.githubusercontent.com/MHEtLive/arduino-boards-index/master/package_mhetlive_index.json
        - https://raw.githubusercontent.com/nulllaborg/arduino_nulllab/master/package_nulllab_boards_index.json
        - https://raw.githubusercontent.com/ricardoquesada/esp32-arduino-lib-builder/master/bluepad32_files/package_esp32_bluepad32_index.json
        - https://raw.githubusercontent.com/sparkfun/Arduino_Apollo3/main/package_sparkfun_apollo3_index.json
        - https://raw.githubusercontent.com/sparkfun/Arduino_Boards/main/IDE_Board_Manager/package_sparkfun_index.json
        - https://resource.heltec.cn/download/package_heltec_esp32_index.json
        - https://static-cdn.m5stack.com/resource/arduino/package_m5stack_index.json
        - https://www.pjrc.com/teensy/package_teensy_index.json
Find the offending line (or lines) that contain the part "compiler.cpp.extra_flags\": \"-std=c++17" and delete them. Next save the file and start the IDE.
Alternatively you can delete the file; it will be recreated but you will no longer have the additional boards manager URLs.
Note
I suspect that you just did an incorrect copy.
I have moved your topic to the dedicated IDE 2.x category of the forum.
thx now its work
