IDE hangs on startup: "Received RST_STREAM with code 1"
PS C:\Users\NeginER\AppData\Local\Programs\arduino IDE> $Env:GRPC_VERBOSITY = "DEBUG"
PS C:\Users\NeginER\AppData\Local\Programs\arduino IDE> $Env:GRPC_TRACE = "all"
PS C:\Users\NeginER\AppData\Local\Programs\arduino IDE> & ".\arduino IDE.exe"
D 2024-01-25T10:20:21.215Z | index | Loading @grpc/grpc-js version 1.8.18
Arduino IDE 2.2.1
Checking for frontend application configuration customizations. Module path: C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.2.1" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.34.0" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2023-08-31T14:35:44.802Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.2.1","cliVersion":"0.34.0","buildDate":"2023-08-31T14:35:44.802Z"}
Starting backend process. PID: 13880
D 2024-01-25T10:20:21.954Z | index | Loading @grpc/grpc-js version 1.8.18
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/NeginER/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-01-25T10:20:22.066Z root INFO Backend Object.initialize: 5.1 ms [Finished 0.541 s after backend start]
2024-01-25T10:20:22.067Z root INFO Backend Object.configure: 4.3 ms [Finished 0.541 s after backend start]
2024-01-25T10:20:22.067Z root INFO Backend a.onStart: 1.7 ms [Finished 0.541 s after backend start]
2024-01-25T10:20:22.067Z root INFO Backend a.configure: 0.3 ms [Finished 0.570 s after backend start]
2024-01-25T10:20:22.068Z root INFO Backend u.onStart: 0.3 ms [Finished 0.570 s after backend start]
2024-01-25T10:20:22.070Z root INFO Backend d.configure: 0.1 ms [Finished 0.570 s after backend start]
2024-01-25T10:20:22.071Z root INFO Backend d.initialize: 28.8 ms [Finished 0.570 s after backend start]
2024-01-25T10:20:22.072Z root INFO Backend c.onStart: 0.3 ms [Finished 0.570 s after backend start]
2024-01-25T10:20:22.072Z root INFO Backend s.configure: 1.0 ms [Finished 0.571 s after backend start]
2024-01-25T10:20:22.074Z config INFO >>> Initializing CLI configuration...
2024-01-25T10:20:22.074Z root INFO Backend c.initialize: 0.4 ms [Finished 0.571 s after backend start]
2024-01-25T10:20:22.075Z root INFO Backend P.onStart: 1.1 ms [Finished 0.572 s after backend start]
2024-01-25T10:20:22.076Z config INFO Loading CLI configuration from c:\Users\NeginER\.arduinoIDE\arduino-cli.yaml...
2024-01-25T10:20:22.076Z daemon INFO Starting daemon from C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-01-25T10:20:22.076Z root INFO Backend s.initialize: 0.5 ms [Finished 0.574 s after backend start]
2024-01-25T10:20:22.077Z root INFO Backend w.onStart: 1.6 ms [Finished 0.575 s after backend start]
2024-01-25T10:20:22.077Z root INFO Backend r.configure: 3.3 ms [Finished 0.576 s after backend start]
2024-01-25T10:20:22.077Z discovery-log INFO start
2024-01-25T10:20:22.077Z discovery-log INFO start new deferred
2024-01-25T10:20:22.077Z root INFO Backend d.initialize: 0.4 ms [Finished 0.576 s after backend start]
2024-01-25T10:20:22.078Z root INFO Backend y.onStart: 2.3 ms [Finished 0.578 s after backend start]
2024-01-25T10:20:22.078Z root INFO Backend r.configure: 2.2 ms [Finished 0.579 s after backend start]
2024-01-25T10:20:22.078Z root INFO Backend s.onStart: 0.6 ms [Finished 0.580 s after backend start]
2024-01-25T10:20:22.078Z root INFO Backend h.configure: 0.7 ms [Finished 0.581 s after backend start]
2024-01-25T10:20:22.078Z root INFO Backend a.configure: 0.6 ms [Finished 0.582 s after backend start]
2024-01-25T10:20:22.079Z root INFO Backend s.configure: 0.1 ms [Finished 0.582 s after backend start]
2024-01-25T10:20:22.079Z root INFO Backend l.configure: 0.1 ms [Finished 0.582 s after backend start]
2024-01-25T10:20:22.083Z root INFO Theia app listening on http://localhost:55082.
2024-01-25T10:20:22.084Z root INFO Finished starting backend application: 6.3 ms [Finished 0.587 s after backend start]
2024-01-25T10:20:22.092Z root WARN The local plugin referenced by local-dir:/c%3A/Users/NeginER/.arduinoIDE/plugins does not exist.
2024-01-25T10:20:22.096Z root WARN The local plugin referenced by local-dir:/c%3A/Users/NeginER/.arduinoIDE/extensions does not exist.
2024-01-25T10:20:22.096Z root WARN The local plugin referenced by local-dir:C:\Users\NeginER\.arduinoIDE\plugins does not exist.
2024-01-25T10:20:22.159Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\NeginER\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\NeginER\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\NeginER\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-01-25T10:20:22.160Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-01-25T10:20:22.162Z config INFO Loaded the CLI configuration.
2024-01-25T10:20:22.240Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/NeginER/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/NeginER/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-01-25T10:20:22.242Z config INFO Validating the CLI configuration...
2024-01-25T10:20:22.247Z config INFO The CLI config is valid.
2024-01-25T10:20:22.247Z config INFO <<< Initialized the CLI configuration.
2024-01-25T10:20:22.279Z root INFO Resolve plugins list: 203.9 ms [Finished 0.783 s after backend start]
2024-01-25T10:20:22.707Z daemon INFO time="2024-01-25T15:20:22+05:00" level=info msg="Using config file: c:\\Users\\NeginER\\.arduinoIDE\\arduino-cli.yaml"
time="2024-01-25T15:20:22+05:00" level=info msg="arduino-cli.exe version 0.34.0"
time="2024-01-25T15:20:22+05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:55083
{"IP":"127.0.0.1","Port":"55083"}
2024-01-25T10:20:22.720Z root ERROR D 2024-01-25T10:20:22.703Z | resolving_load_balancer | dns:localhost:55083 IDLE -> IDLE
2024-01-25T10:20:22.722Z root ERROR D 2024-01-25T10:20:22.703Z | connectivity_state | (1) dns:localhost:55083 IDLE -> IDLE
2024-01-25T10:20:22.728Z root ERROR D 2024-01-25T10:20:22.703Z | dns_resolver | Resolver constructed for target dns:localhost:55083
2024-01-25T10:20:22.731Z root ERROR D 2024-01-25T10:20:22.705Z | channel | (1) dns:localhost:55083 Channel constructed with options {
  "grpc.max_send_message_length": 536870912,
  "grpc.max_receive_message_length": 536870912,
  "grpc.primary_user_agent": "arduino-ide/2.2.1"
2024-01-25T10:20:22.737Z root ERROR D 2024-01-25T10:20:22.705Z | channel_stacktrace | (1) Channel constructed
    at new t.InternalChannel (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:779807)
    at new t.ChannelImplementation (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:732712)
    at new t.Client (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:750201)
    at new a (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:818067)
    at _.createClient (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:585187)
    at _.create (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:584231)
    at C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:583109
    at C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:1039338
    at i.invoke (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:1039428)
    at a.fire (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:1041222)
2024-01-25T10:20:22.737Z root ERROR D 2024-01-25T10:20:22.705Z | channel | (1) dns:localhost:55083 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2024-01-25T10:20:22.737Z root ERROR D 2024-01-25T10:20:22.705Z | resolving_call | [0] Created
2024-01-25T10:20:22.737Z root ERROR D 2024-01-25T10:20:22.705Z | resolving_call | [0] Deadline: Infinity
2024-01-25T10:20:22.737Z root ERROR D 2024-01-25T10:20:22.706Z | resolving_call | [0] start called
2024-01-25T10:20:22.738Z root ERROR D 2024-01-25T10:20:22.706Z | dns_resolver | Looking up DNS hostname localhost
2024-01-25T10:20:22.738Z root ERROR D 2024-01-25T10:20:22.707Z | resolving_load_balancer | dns:localhost:55083 IDLE -> CONNECTING
2024-01-25T10:20:22.738Z root ERROR D 2024-01-25T10:20:22.707Z | connectivity_state | (1) dns:localhost:55083 IDLE -> CONNECTING
2024-01-25T10:20:22.738Z root ERROR D 2024-01-25T10:20:22.707Z | channel | (1) dns:localhost:55083 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2024-01-25T10:20:22.738Z root ERROR D 2024-01-25T10:20:22.707Z | resolving_call | [0] startRead called
2024-01-25T10:20:22.739Z root ERROR D 2024-01-25T10:20:22.707Z | resolving_call | [0] write() called with message of length 0
2024-01-25T10:20:22.739Z root ERROR D 2024-01-25T10:20:22.707Z | resolving_call | [0] halfClose called
2024-01-25T10:20:22.739Z daemon INFO Daemon is running.
2024-01-25T10:20:22.742Z root ERROR D 2024-01-25T10:20:22.740Z | dns_resolver | Resolved addresses for target dns:localhost:55083: [::1:55083,127.0.0.1:55083]
2024-01-25T10:20:22.744Z root ERROR D 2024-01-25T10:20:22.741Z | pick_first | Connect to address list ::1:55083,127.0.0.1:55083
2024-01-25T10:20:22.745Z root ERROR D 2024-01-25T10:20:22.741Z | subchannel | (2) ::1:55083 Subchannel constructed with options {
2024-01-25T10:20:22.745Z root ERROR D 2024-01-25T10:20:22.742Z | subchannel_refcount | (2) ::1:55083 refcount 0 -> 1
2024-01-25T10:20:22.745Z root ERROR D 2024-01-25T10:20:22.742Z | subchannel | (3) 127.0.0.1:55083 Subchannel constructed with options {
2024-01-25T10:20:22.745Z root ERROR D 2024-01-25T10:20:22.742Z | subchannel_refcount | (3) 127.0.0.1:55083 refcount 0 -> 1
2024-01-25T10:20:22.746Z root ERROR D 2024-01-25T10:20:22.742Z | subchannel_refcount | (2) ::1:55083 refcount 1 -> 2
2024-01-25T10:20:22.746Z root ERROR D 2024-01-25T10:20:22.742Z | subchannel_refcount | (3) 127.0.0.1:55083 refcount 1 -> 2
2024-01-25T10:20:22.747Z root ERROR D 2024-01-25T10:20:22.742Z | pick_first | Start connecting to subchannel with address ::1:55083
2024-01-25T10:20:22.747Z root ERROR D 2024-01-25T10:20:22.742Z | pick_first | IDLE -> CONNECTING
2024-01-25T10:20:22.749Z root ERROR D 2024-01-25T10:20:22.742Z | resolving_load_balancer | dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.749Z root ERROR D 2024-01-25T10:20:22.742Z | channel | (1) dns:localhost:55083 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2024-01-25T10:20:22.749Z root ERROR D 2024-01-25T10:20:22.742Z | connectivity_state | (1) dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.755Z root ERROR D 2024-01-25T10:20:22.750Z | subchannel | (2) ::1:55083 IDLE -> CONNECTING
2024-01-25T10:20:22.757Z root ERROR D 2024-01-25T10:20:22.750Z | pick_first | CONNECTING -> CONNECTING
2024-01-25T10:20:22.757Z root ERROR D 2024-01-25T10:20:22.750Z | resolving_load_balancer | dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.757Z root ERROR D 2024-01-25T10:20:22.750Z | connectivity_state | (1) dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.757Z root ERROR D 2024-01-25T10:20:22.750Z | subchannel | (3) 127.0.0.1:55083 IDLE -> CONNECTING
2024-01-25T10:20:22.758Z root ERROR D 2024-01-25T10:20:22.750Z | pick_first | CONNECTING -> CONNECTING
2024-01-25T10:20:22.758Z root ERROR D 2024-01-25T10:20:22.750Z | resolving_load_balancer | dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.758Z root ERROR D 2024-01-25T10:20:22.750Z | connectivity_state | (1) dns:localhost:55083 CONNECTING -> CONNECTING
2024-01-25T10:20:22.760Z root ERROR D 2024-01-25T10:20:22.751Z | transport | [object Object] creating HTTP/2 session to ::1:55083
2024-01-25T10:20:22.763Z root ERROR D 2024-01-25T10:20:22.752Z | transport | [object Object] creating HTTP/2 session to 127.0.0.1:55083
2024-01-25T10:20:22.773Z root ERROR D 2024-01-25T10:20:22.754Z | channel | (1) dns:localhost:55083 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-01-25T10:20:22.779Z root ERROR D 2024-01-25T10:20:22.754Z | resolving_call | [0] Created child [1]
2024-01-25T10:20:22.780Z root ERROR D 2024-01-25T10:20:22.754Z | retrying_call | [1] start called
2024-01-25T10:20:22.781Z root ERROR D 2024-01-25T10:20:22.754Z | channel | (1) dns:localhost:55083 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-01-25T10:20:22.790Z root ERROR D 2024-01-25T10:20:22.754Z | retrying_call | [1] Created child call [2] for attempt 1
2024-01-25T10:20:22.792Z root ERROR D 2024-01-25T10:20:22.754Z | load_balancing_call | [2] start called
2024-01-25T10:20:22.799Z root ERROR D 2024-01-25T10:20:22.754Z | load_balancing_call | [2] Pick called
2024-01-25T10:20:22.800Z root ERROR D 2024-01-25T10:20:22.754Z | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2024-01-25T10:20:22.810Z root ERROR D 2024-01-25T10:20:22.754Z | channel | (1) dns:localhost:55083 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2024-01-25T10:20:22.812Z root ERROR D 2024-01-25T10:20:22.755Z | retrying_call | [1] startRead called
2024-01-25T10:20:22.814Z root ERROR D 2024-01-25T10:20:22.755Z | load_balancing_call | [2] startRead called
2024-01-25T10:20:22.820Z root ERROR D 2024-01-25T10:20:22.759Z | retrying_call | [1] write() called with message of length 5
2024-01-25T10:20:22.823Z root ERROR D 2024-01-25T10:20:22.760Z | load_balancing_call | [2] write() called with message of length 5
2024-01-25T10:20:22.824Z root ERROR D 2024-01-25T10:20:22.760Z | retrying_call | [1] halfClose called
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | subchannel | (3) 127.0.0.1:55083 CONNECTING -> READY
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | pick_first | Pick subchannel with address 127.0.0.1:55083
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | subchannel_refcount | (3) 127.0.0.1:55083 refcount 2 -> 3
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | subchannel_refcount | (2) ::1:55083 refcount 2 -> 1
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | subchannel_refcount | (3) 127.0.0.1:55083 refcount 3 -> 2
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | pick_first | CONNECTING -> READY
2024-01-25T10:20:22.833Z root ERROR D 2024-01-25T10:20:22.830Z | resolving_load_balancer | dns:localhost:55083 CONNECTING -> READY
2024-01-25T10:20:22.834Z root ERROR D 2024-01-25T10:20:22.830Z | channel | (1) dns:localhost:55083 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2024-01-25T10:20:22.834Z root ERROR D 2024-01-25T10:20:22.830Z | load_balancing_call | [2] Pick called
2024-01-25T10:20:22.834Z root ERROR D 2024-01-25T10:20:22.830Z | load_balancing_call | [2] Pick result: COMPLETE subchannel: (3) 127.0.0.1:55083 status: undefined undefined
2024-01-25T10:20:22.834Z root ERROR D 2024-01-25T10:20:22.830Z | connectivity_state | (1) dns:localhost:55083 CONNECTING -> READY
2024-01-25T10:20:22.834Z root ERROR D 2024-01-25T10:20:22.832Z | transport_flowctrl | (4) 127.0.0.1:55083 local window size: 65535 remote window size: 65535
2024-01-25T10:20:22.839Z root ERROR D 2024-01-25T10:20:22.832Z | transport_internals | (4) 127.0.0.1:55083 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-01-25T10:20:22.842Z root ERROR D 2024-01-25T10:20:22.832Z | load_balancing_call | [2] Created child call [3]
2024-01-25T10:20:22.845Z root ERROR D 2024-01-25T10:20:22.832Z | subchannel_call | [3] write() called with message of length 5
2024-01-25T10:20:22.845Z root ERROR D 2024-01-25T10:20:22.832Z | subchannel_call | [3] sending data chunk of length 5
2024-01-25T10:20:22.847Z root ERROR D 2024-01-25T10:20:22.847Z | load_balancing_call | [2] halfClose called
2024-01-25T10:20:22.848Z root ERROR D 2024-01-25T10:20:22.847Z | subchannel_call | [3] end() called
2024-01-25T10:20:22.848Z root ERROR D 2024-01-25T10:20:22.847Z | subchannel_call | [3] calling end() on HTTP/2 stream
2024-01-25T10:20:22.996Z root ERROR D 2024-01-25T10:20:22.996Z | transport | (4) 127.0.0.1:55083 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2024-01-25T10:20:22.999Z root ERROR D 2024-01-25T10:20:22.999Z | subchannel_call | [3] Received server headers:
                :status: 200
                content-type: application/grpc
2024-01-25T10:20:22.999Z root ERROR D 2024-01-25T10:20:22.999Z | load_balancing_call | [2] Received metadata
2024-01-25T10:20:22.999Z root ERROR D 2024-01-25T10:20:22.999Z | retrying_call | [1] Received metadata from child [2]
2024-01-25T10:20:22.999Z root ERROR D 2024-01-25T10:20:22.999Z | retrying_call | [1] Committing call [2] at index 0
2024-01-25T10:20:23.000Z root ERROR D 2024-01-25T10:20:22.999Z | resolving_call | [0] Received metadata
2024-01-25T10:20:23.001Z root ERROR D 2024-01-25T10:20:23.000Z | subchannel_call | [3] receive HTTP/2 data frame of length 9
2024-01-25T10:20:23.003Z root ERROR D 2024-01-25T10:20:23.000Z | subchannel_call | [3] parsed message of length 9
2024-01-25T10:20:23.003Z root ERROR D 2024-01-25T10:20:23.000Z | subchannel_call | [3] pushing to reader message of length 9
2024-01-25T10:20:23.010Z root ERROR D 2024-01-25T10:20:23.000Z | load_balancing_call | [2] Received message
2024-01-25T10:20:23.011Z root ERROR D 2024-01-25T10:20:23.000Z | retrying_call | [1] Received message from child [2]
2024-01-25T10:20:23.011Z root ERROR D 2024-01-25T10:20:23.000Z | resolving_call | [0] Received message
2024-01-25T10:20:23.011Z root ERROR D 2024-01-25T10:20:23.000Z | resolving_call | [0] Finished filtering received message
2024-01-25T10:20:23.015Z root ERROR D 2024-01-25T10:20:23.014Z | subchannel_call | [3] HTTP/2 stream closed with code 1
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.014Z | subchannel_call | [3] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | load_balancing_call | [2] Received status
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | load_balancing_call | [2] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | retrying_call | [1] Received status from child [2]
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | retrying_call | [1] state=COMMITTED handling status with progress PROCESSED from child [2] in state ACTIVE
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | retrying_call | [1] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-01-25T10:20:23.016Z root ERROR D 2024-01-25T10:20:23.015Z | resolving_call | [0] Received status
2024-01-25T10:20:23.017Z root ERROR D 2024-01-25T10:20:23.015Z | resolving_call | [0] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-01-25T10:20:23.017Z root ERROR Uncaught Exception:  Error: 13 INTERNAL: Received RST_STREAM with code 1
2024-01-25T10:20:23.018Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 1
    at t.callErrorFromStatus (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:726940)
    at Object.onReceiveStatus (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:752179)
    at Object.onReceiveStatus (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:748059)
    at Object.onReceiveStatus (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:747504)
    at C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:833048
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at a.makeUnaryRequest (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:751720)
    at a.create (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:818456)
    at instance (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:585395)
    at new Promise (<anonymous>)
    at _.createClient (C:\Users\NeginER\AppData\Local\Programs\arduino IDE\resources\app\lib\backend\main.js:2:585372)
2024-01-25T10:20:23.782Z root ERROR D 2024-01-25T10:20:23.782Z | resolving_load_balancer | dns:localhost:55083 READY -> READY
2024-01-25T10:20:23.783Z root ERROR D 2024-01-25T10:20:23.782Z | connectivity_state | (1) dns:localhost:55083 READY -> READY
2024-01-25T10:20:23.864Z root ERROR D 2024-01-25T10:20:23.864Z | transport | [object Object] connection failed with error connect ECONNREFUSED ::1:55083
2024-01-25T10:20:23.864Z root ERROR D 2024-01-25T10:20:23.864Z | subchannel | (2) ::1:55083 CONNECTING -> TRANSIENT_FAILURE
2024-01-25T10:20:23.865Z root ERROR D 2024-01-25T10:20:23.865Z | subchannel | (2) ::1:55083 TRANSIENT_FAILURE -> IDLE
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-01-25T10:20:25.311Z root INFO Deploy plugins list: 203.9 ms [Finished 3.815 s after backend start]
2024-01-25T10:20:25.460Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 611.9 ms [Finished 3.191 s after frontend start]
2024-01-25T10:20:25.464Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-01-25T10:20:25.880Z root WARN Frontend D.onStart took longer than the expected maximum 100 milliseconds: 247.4 ms [Finished 3.693 s after frontend start]
2024-01-25T10:20:32.743Z root ERROR D 2024-01-25T10:20:32.743Z | subchannel_refcount | (2) ::1:55083 refcount 1 -> 0
Don't know, but see here if something helps, looks pretty similar:
Already seen it, doesn't fit...
Your first error line ("resolving_load_balancer | dns:localhost:55083 IDLE -> IDLE") looks like something related to local workers (Arduino IDE has some of them, using TCP over localhost) and/or failure connecting to them.
Are you sure you don't have any kinda firewall software blocking connections even if for "localhost"?
Otherwise I'd try uninstalling and reinstalling the IDE (the "portable" one, if possible).
