IDE hangs on startup: "13 INTERNAL: Received RST_STREAM with code 1"
Hi all,
I'm experiencing hanging issues on the software when opening. I was first experiencing this on version 2.2.1 but the issue still remained when updating to 2.3.2.
We are an FE college and this is present any various modules for a number of courses so assistance on this would be massively appreciated.
Happy to answer any questions you may have.
Also, apologies if I was incorrect where and how to approach this.
Error logs below...
PS C:\Program Files\Arduino IDE> & ".\arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 3236
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/jongreenway/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-17T13:13:25.733Z root INFO Backend Object.initialize: 3.2 ms [Finished 0.380 s after backend start]
2024-10-17T13:13:25.733Z root INFO Backend Object.configure: 2.7 ms [Finished 0.380 s after backend start]
2024-10-17T13:13:25.733Z root INFO Backend s.onStart: 1.3 ms [Finished 0.380 s after backend start]
2024-10-17T13:13:25.734Z root INFO Backend s.configure: 0.2 ms [Finished 0.398 s after backend start]
2024-10-17T13:13:25.734Z root INFO Backend d.onStart: 0.2 ms [Finished 0.398 s after backend start]
2024-10-17T13:13:25.735Z root INFO Backend d.configure: 0.1 ms [Finished 0.398 s after backend start]
2024-10-17T13:13:25.735Z root INFO Backend d.initialize: 18.1 ms [Finished 0.398 s after backend start]
2024-10-17T13:13:25.735Z root INFO Backend c.onStart: 0.2 ms [Finished 0.398 s after backend start]
2024-10-17T13:13:25.736Z root INFO Backend a.configure: 0.9 ms [Finished 0.399 s after backend start]
2024-10-17T13:13:25.737Z config INFO >>> Initializing CLI configuration...
2024-10-17T13:13:25.737Z root INFO Backend c.initialize: 0.3 ms [Finished 0.399 s after backend start]
2024-10-17T13:13:25.737Z root INFO Backend R.onStart: 0.5 ms [Finished 0.400 s after backend start]
2024-10-17T13:13:25.738Z config INFO Loading CLI configuration from c:\Users\jongreenway\.arduinoIDE\arduino-cli.yaml...
2024-10-17T13:13:25.738Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-17T13:13:25.738Z root INFO Backend a.initialize: 0.3 ms [Finished 0.400 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend w.onStart: 0.9 ms [Finished 0.401 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend r.configure: 1.4 ms [Finished 0.401 s after backend start]
2024-10-17T13:13:25.738Z discovery-log INFO start
2024-10-17T13:13:25.738Z discovery-log INFO start new deferred
2024-10-17T13:13:25.738Z root INFO Backend d.initialize: 0.4 ms [Finished 0.402 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend y.onStart: 1.5 ms [Finished 0.403 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend r.configure: 1.3 ms [Finished 0.403 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend a.onStart: 0.4 ms [Finished 0.404 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend h.configure: 0.3 ms [Finished 0.404 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend s.configure: 0.1 ms [Finished 0.404 s after backend start]
2024-10-17T13:13:25.738Z root INFO Backend l.configure: 0.0 ms [Finished 0.404 s after backend start]
2024-10-17T13:13:25.740Z root INFO Theia app listening on http://127.0.0.1:50481.
2024-10-17T13:13:25.740Z root INFO Finished starting backend application: 1.8 ms [Finished 0.406 s after backend start]
2024-10-17T13:13:25.748Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/pluginsdoes not exist.
2024-10-17T13:13:25.748Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/extensions does not exist.
2024-10-17T13:13:25.748Z root WARN The local plugin referenced by local-dir:C:\Users\jongreenway\.arduinoIDE\plugins does not exist.
2024-10-17T13:13:25.759Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\jongreenway\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\jongreenway\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\jongreenway\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-17T13:13:25.759Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-17T13:13:25.759Z config INFO Loaded the CLI configuration.
2024-10-17T13:13:25.769Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/jongreenway/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/jongreenway/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-10-17T13:13:25.769Z config INFO Validating the CLI configuration...
2024-10-17T13:13:25.769Z config INFO The CLI config is valid.
2024-10-17T13:13:25.769Z config INFO <<< Initialized the CLI configuration.
2024-10-17T13:13:25.806Z root INFO Resolve plugins list: 67.4 ms [Finished 0.470 s after backend start]
2024-10-17T13:13:26.482Z root INFO Deploy plugins list: 67.4 ms [Finished 1.148 s after backend start]
2024-10-17T13:13:26.567Z daemon INFO time="2024-10-17T14:13:26+01:00" level=info msg="Using config file: c:\\Users\\jongreenway\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-17T14:13:26+01:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-10-17T13:13:26.567Z daemon I^EO time="2024-10-17T14:13:26+01:00" level=info msg="Executing `arduino-cli daemon`"
2024-10-17T13:13:26.572Z daemon INFO Daemon is now listening on 127.0.0.1:50484
{"IP":"127.0.0.1","Port":"50484"}
2024-10-17T13:13:26.572Z daemon INFO Daemon is running.
2024-10-17T13:13:26.587Z root ERROR Uncaught Exception:  Error: 13 INTERNAL: Received RST_STREAM with code 1
2024-10-17T13:13:26.587Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 1
    at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:763461)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:788777)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784657)
    at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:784102)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:870224
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
    at s.makeUnaryRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:788318)
    at s.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:855121)
    at instance (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621987)
    at new Promise (<anonymous>)
    at E.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621964)
    at E.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:620823)
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:619701
    at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062813
    at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1062903)
    at s.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1064706)
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-17T13:13:27.369Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 174.6 ms [Finished 1.521 s after frontend start]
2024-10-17T13:13:27.369Z root WARN A command editor.action.toggleStickyScroll is already registered.
Thank you
I have not seen a solution for that problem on the forum yet but there are a few topics with that error.
Can you please follow the instructions in Arduino ide 2.3.3 blank screen - #6 by ptillisch and post the result here.
I have no idea what the additional output that you get means (see Arduino ide 2.3.3 blank screen - #7 by ezuralski). It might shine a light on the issue and it might speed up the process if you post the results.
As the issue seems to be networking related and localhost is involved, can you ping localhost (both in IP4 and IP6 mode)? That's all that I can suggest.
I can't provide a fix for this but just to say it looks like you're getting exactly the same error as we are. Also an FE college.
For the moment we've gone back to 1.8.19 which our tutors are happy with.
Hi, apologies for the delay with this, error logs shown below...
Arduino IDE 2.3.2
Starting backend process. PID: 18192
2024-11-08T08:05:01.448Z root INFO Backend Object.initialize: 3.2 ms [Finished 0.377 s after backend start]
2024-11-08T08:05:01.448Z root INFO Backend Object.configure: 2.5 ms [Finished 0.377 s after backend start]
2024-11-08T08:05:01.448Z root INFO Backend s.onStart: 1.1 ms [Finished 0.377 s after backend start]
2024-11-08T08:05:01.449Z root INFO Backend s.configure: 0.3 ms [Finished 0.392 s after backend start]
2024-11-08T08:05:01.449Z root INFO Backend d.onStart: 0.2 ms [Finished 0.392 s after backend start]
2024-11-08T08:05:01.450Z root INFO Backend d.configure: 0.1 ms [Finished 0.392 s after backend start]
2024-11-08T08:05:01.451Z root INFO Backend d.initialize: 15.2 ms [Finished 0.393 s after backend start]
2024-11-08T08:05:01.451Z root INFO Backend c.onStart: 0.2 ms [Finished 0.393 s after backend start]
2024-11-08T08:05:01.452Z root INFO Backend a.configure: 1.0 ms [Finished 0.394 s after backend start]
2024-11-08T08:05:01.454Z config INFO >>> Initializing CLI configuration...
2024-11-08T08:05:01.454Z root INFO Backend c.initialize: 0.6 ms [Finished 0.394 s after backend start]
2024-11-08T08:05:01.454Z root INFO Backend R.onStart: 0.6 ms [Finished 0.394 s after backend start]
2024-11-08T08:05:01.454Z config INFO Loading CLI configuration from c:\Users\jongreenway\.arduinoIDE\arduino-cli.yaml...
2024-11-08T08:05:01.455Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-08T08:05:01.455Z root INFO Backend a.initialize: 0.3 ms [Finished 0.395 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend w.onStart: 0.9 ms [Finished 0.396 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend r.configure: 1.6 ms [Finished 0.396 s after backend start]
2024-11-08T08:05:01.455Z discovery-log INFO start
2024-11-08T08:05:01.455Z discovery-log INFO start new deferred
2024-11-08T08:05:01.455Z root INFO Backend d.initialize: 0.8 ms [Finished 0.397 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend y.onStart: 2.5 ms [Finished 0.399 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend r.configure: 2.0 ms [Finished 0.399 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend a.onStart: 0.4 ms [Finished 0.400 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend h.configure: 0.3 ms [Finished 0.400 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend s.configure: 0.1 ms [Finished 0.400 s after backend start]
2024-11-08T08:05:01.455Z root INFO Backend l.configure: 0.0 ms [Finished 0.400 s after backend start]
2024-11-08T08:05:01.457Z root INFO Theia app listening on http://127.0.0.1:60868.
2024-11-08T08:05:01.457Z root INFO Finished starting backend application: 2.0 ms [Finished 0.402 s after backend start]
2024-11-08T08:05:01.457Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/plugins does not exist.
2024-11-08T08:05:01.457Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/extensions does not exist.
2024-11-08T08:05:01.457Z root WARN The local plugin referenced by local-dir:C:\Users\jongreenway\.arduinoIDE\plugins does not exist.
2024-11-08T08:05:01.462Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\jongreenway\\
2024-11-08T08:05:01.462Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-11-08T08:05:01.462Z config INFO Loaded the CLI configuration.
2024-11-08T08:05:01.485Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/jongreenway/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/jongreenway/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-08T08:05:01.485Z config INFO Validating the CLI configuration...
2024-11-08T08:05:01.493Z config INFO The CLI config is valid.
2024-11-08T08:05:01.493Z config INFO <<< Initialized the CLI configuration.
2024-11-08T08:05:01.585Z root INFO Resolve plugins list: 129.7 ms [Finished 0.529 s after backend start]
2024-11-08T08:05:02.439Z root INFO Deploy plugins list: 129.7 ms [Finished 1.384 s after backend start]
2024-11-08T08:05:02.604Z daemon INFO time="2024-11-08T08:05:02Z" level=info msg="Using config file: c:\\Users\\jongreenway\\.arduinoIDE\\arduino-cli.yaml"
time="2024-11-08T08:05:02Z" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-11-08T08:05:02Z" level=info msg="Executing `arduino-cli daemon`"
2024-11-08T08:05:02.608Z daemon INFO Daemon is now listening on 127.0.0.1:60871
{"IP":"127.0.0.1","Port":"60871"}
2024-11-08T08:05:02.608Z daemon INFO Daemon is running.
2024-11-08T08:05:02.621Z root ERROR Uncaught Exception:  Error: 13 INTERNAL: Received RST_STREAM with code 1
2024-11-08T08:05:02.621Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 1
for call at
2024-11-08T08:05:03.426Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 211.5 ms [Finished 1.830 s after frontend start]
2024-11-08T08:05:03.426Z root WARN A command editor.action.toggleStickyScroll is already registered.
Thanks all, massively grateful
Hi @jmg0301. I don't see the additional debugging output I would expect from following the instructions linked by @sterretje. Please try again to make sure you followed the instructions correctly. To ensure the instructions are clear, I'll post them here:
I'm going to ask you to provide the logs produced by Arduino IDE when some additional debugging output is enabled.
:exclamation: This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    ⓘ The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
    A context menu will open.
  4. Select "Open PowerShell window here" from the menu.
    PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    $Env:GRPC_VERBOSITY = "DEBUG"
  6. Press the Enter key.
  7. Type the following command in the terminal:
    $Env:GRPC_TRACE = "all"
  8. Press the Enter key.
  9. Type the following command:
    & ".\Arduino IDE"
  10. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts (or fails to start).
  11. Wait for Arduino IDE to .
  12. Switch back to the PowerShell window if the Arduino IDE window took the focus.
  13. Press the Ctrl+Shift+A keyboard shortcut.
    This will select all the text in the PowerShell window.
  14. Press the Ctrl+C keyboard shortcut.
    This will copy the contents of the PowerShell window to the clipboard.
  15. Open a forum reply here by clicking the "Reply" button.
  16. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
  17. Press the Ctrl+V keyboard shortcut.
    This will paste the output into the code block.
  18. Move the cursor outside of the code block markup before you add any additional text to your reply.
  19. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Hi, Please see the below...
[quote="ptillisch, post:5, topic:1318487"]
`all`
[/quote]
PS C:\Program Files\Arduino IDE> $Env:GRPC_VERBOSITY = "DEBUG"
PS C:\Program Files\Arduino IDE> $Env:GRPC_TRACE = "all"
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
D 2024-11-08T11:23:20.362Z | index | Loading @grpc/grpc-js version 1.9.5
Arduino IDE 2.3.2
Starting backend process. PID: 6020
D 2024-11-08T11:23:21.561Z | index | Loading @grpc/grpc-js version 1.9.5
2024-11-08T11:23:21.626Z root INFO Backend Object.initialize: 2.9 ms [Finished 0.463 s after backend start]
2024-11-08T11:23:21.626Z root INFO Backend Object.configure: 2.4 ms [Finished 0.463 s after backend start]
2024-11-08T11:23:21.626Z root INFO Backend s.onStart: 1.1 ms [Finished 0.463 s after backend start]
2024-11-08T11:23:21.627Z root INFO Backend s.configure: 0.3 ms [Finished 0.477 s after backend start]
2024-11-08T11:23:21.627Z root INFO Backend d.onStart: 0.2 ms [Finished 0.477 s after backend start]
2024-11-08T11:23:21.627Z root INFO Backend d.configure: 0.1 ms [Finished 0.477 s after backend start]
2024-11-08T11:23:21.628Z root INFO Backend d.initialize: 14.5 ms [Finished 0.477 s after backend start]
2024-11-08T11:23:21.628Z root INFO Backend c.onStart: 0.2 ms [Finished 0.477 s after backend start]
2024-11-08T11:23:21.629Z root INFO Backend a.configure: 0.3 ms [Finished 0.478 s after backend start]
2024-11-08T11:23:21.630Z config INFO >>> Initializing CLI configuration...
2024-11-08T11:23:21.630Z root INFO Backend c.initialize: 0.3 ms [Finished 0.478 s after backend start]
2024-11-08T11:23:21.631Z root INFO Backend R.onStart: 0.5 ms [Finished 0.478 s after backend start]
2024-11-08T11:23:21.631Z config INFO Loading CLI configuration from c:\Users\jongreenway\.arduinoIDE\arduino-cli.yaml...
2024-11-08T11:23:21.631Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-11-08T11:23:21.632Z root INFO Backend a.initialize: 0.2 ms [Finished 0.479 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend w.onStart: 0.8 ms [Finished 0.479 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend r.configure: 1.3 ms [Finished 0.480 s after backend start]
2024-11-08T11:23:21.632Z discovery-log INFO start
2024-11-08T11:23:21.632Z discovery-log INFO start new deferred
2024-11-08T11:23:21.632Z root INFO Backend d.initialize: 0.4 ms [Finished 0.480 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend y.onStart: 2.2 ms [Finished 0.482 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend r.configure: 1.9 ms [Finished 0.482 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend a.onStart: 0.4 ms [Finished 0.483 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend h.configure: 0.3 ms [Finished 0.483 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend s.configure: 0.1 ms [Finished 0.483 s after backend start]
2024-11-08T11:23:21.632Z root INFO Backend l.configure: 0.0 ms [Finished 0.483 s after backend start]
2024-11-08T11:23:21.634Z root INFO Theia app listening on http://127.0.0.1:62512.
2024-11-08T11:23:21.634Z root INFO Finished starting backend application: 2.1 ms [Finished 0.485 s after backend start]
2024-11-08T11:23:21.634Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/plugins does not exist.
2024-11-08T11:23:21.634Z root WARN The local plugin referenced by local-dir:/c%3A/Users/jongreenway/.arduinoIDE/extensions does not exist.
2024-11-08T11:23:21.634Z root WARN The local plugin referenced by local-dir:C:\Users\jongreenway\.arduinoIDE\plugins does not exist.
2024-11-08T11:23:21.638Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\jongreenway\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\jongreenway\\AppData\\Local\\Arduino15\\staging","user":"C:\\Users\\jongreenway\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-11-08T11:23:21.638Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-11-08T11:23:21.638Z config INFO Loaded the CLI configuration.
2024-11-08T11:23:21.650Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/jongreenway/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/jongreenway/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-11-08T11:23:21.650Z config INFO Validating the CLI configuration...
2024-11-08T11:23:21.653Z config INFO The CLI config is valid.
2024-11-08T11:23:21.653Z config INFO <<< Initialized the CLI configuration.
2024-11-08T11:23:21.723Z root INFO Resolve plugins list: 91.5 ms [Finished 0.573 s after backend start]
2024-11-08T11:23:22.548Z root INFO Deploy plugins list: 91.5 ms [Finished 1.399 s after backend start]
2024-11-08T11:23:22.581Z daemon INFO time="2024-11-08T11:23:22Z" level=info msg="Using config file: c:\\Users\\jongreenway\\.arduinoIDE\\arduino-cli.yaml"
time="2024-11-08T11:23:22Z" level=info msg="arduino-cli.exe version 0.35.3"
2024-11-08T11:23:22.581Z daemon INFO time="2024-11-08T11:23:22Z" level=info msg="Executing `arduino-cli daemon`"
2024-11-08T11:23:22.587Z daemon INFO Daemon is now listening on 127.0.0.1:62515
{"IP":"127.0.0.1","Port":"62515"}
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.584Z | resolving_load_balancer | dns:localhost:62515 IDLE -> IDLE
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.584Z | connectivity_state | (1) dns:localhost:62515 IDLE -> IDLE
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.584Z | dns_resolver | Resolver constructed for target dns:localhost:62515
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.585Z | channel | (1) dns:localhost:62515 Channel constructed with options {
  "grpc.max_send_message_length": 536870912,
  "grpc.max_receive_message_length": 536870912,
  "grpc.primary_user_agent": "arduino-ide/2.3.2"
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.585Z | channel_stacktrace | (1) Channel constructed
    at new t.InternalChannel (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:816617)
    at new t.ChannelImplementation (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:769298)
    at new t.Client (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:786799)
    at new s (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:854732)
    at E.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:621779)
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.585Z | channel | (1) dns:localhost:62515 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.585Z | resolving_call | [0] Created
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.585Z | resolving_call | [0] Deadline: Infinity
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.586Z | resolving_call | [0] start called
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.586Z | dns_resolver | Looking up DNS hostname localhost
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | resolving_load_balancer | dns:localhost:62515 IDLE -> CONNECTING
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | connectivity_state | (1) dns:localhost:62515 IDLE -> CONNECTING
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | channel | (1) dns:localhost:62515 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | resolving_call | [0] startRead called
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | resolving_call | [0] write() called with message of length 0
2024-11-08T11:23:22.587Z root ERROR D 2024-11-08T11:23:22.587Z | resolving_call | [0] halfClose called
2024-11-08T11:23:22.587Z daemon INFO Daemon is running.
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | dns_resolver | Resolved addresses for target dns:localhost:62515: [::1:62515,127.0.0.1:62515]
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | subchannel | (2) ::1:62515 Subchannel constructed with options {
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | subchannel_refcount | (2) ::1:62515 refcount 0 -> 1
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | subchannel | (3) 127.0.0.1:62515 Subchannel constructed with options {
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | subchannel_refcount | (3) 127.0.0.1:62515 refcount 0 -> 1
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.588Z | subchannel_refcount | (2) ::1:62515 refcount 1 -> 2
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | subchannel_refcount | (3) 127.0.0.1:62515 refcount 1 -> 2
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | pick_first | Start connecting to subchannel with address ::1:62515
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | pick_first | IDLE -> CONNECTING
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | resolving_load_balancer | dns:localhost:62515 CONNECTING -> CONNECTING
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | channel | (1) dns:localhost:62515 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2024-11-08T11:23:22.589Z root ERROR D 2024-11-08T11:23:22.589Z | connectivity_state | (1) dns:localhost:62515 CONNECTING -> CONNECTING
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.589Z | subchannel | (2) ::1:62515 IDLE -> CONNECTING
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.590Z | transport | dns:localhost:62515 creating HTTP/2 session to ::1:62515
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.590Z | channel | (1) dns:localhost:62515 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.590Z | resolving_call | [0] Created child [1]
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.590Z | retrying_call | [1] start called
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | channel | (1) dns:localhost:62515 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | retrying_call | [1] Created child call [2] for attempt 1
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | load_balancing_call | [2] start called
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | load_balancing_call | [2] Pick called
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | channel | (1) dns:localhost:62515 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | retrying_call | [1] startRead called
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | load_balancing_call | [2] startRead called
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | retrying_call | [1] write() called with message of length 5
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | load_balancing_call | [2] write() called with message of length 5
2024-11-08T11:23:22.591Z root ERROR D 2024-11-08T11:23:22.591Z | retrying_call | [1] halfClose called
2024-11-08T11:23:22.592Z root ERROR D 2024-11-08T11:23:22.592Z | transport | dns:localhost:62515 connection failed with error connect ECONNREFUSED ::1:62515
2024-11-08T11:23:22.592Z root ERROR D 2024-11-08T11:23:22.592Z | subchannel | (2) ::1:62515 CONNECTING -> TRANSIENT_FAILURE
2024-11-08T11:23:22.592Z root ERROR D 2024-11-08T11:23:22.592Z | pick_first | Start connecting to subchannel with address 127.0.0.1:62515
2024-11-08T11:23:22.593Z root ERROR D 2024-11-08T11:23:22.592Z | subchannel | (3) 127.0.0.1:62515 IDLE -> CONNECTING
2024-11-08T11:23:22.593Z root ERROR D 2024-11-08T11:23:22.593Z | transport | dns:localhost:62515 creating HTTP/2 session to 127.0.0.1:62515
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | subchannel | (3) 127.0.0.1:62515 CONNECTING -> READY
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | pick_first | Pick subchannel with address 127.0.0.1:62515
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | subchannel_refcount | (3) 127.0.0.1:62515 refcount 2 -> 3
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | subchannel_refcount | (2) ::1:62515 refcount 2 -> 1
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | subchannel_refcount | (3) 127.0.0.1:62515 refcount 3 -> 2
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | pick_first | CONNECTING -> READY
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | resolving_load_balancer | dns:localhost:62515 CONNECTING -> READY
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | channel | (1) dns:localhost:62515 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | load_balancing_call | [2] Pick called
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | load_balancing_call | [2] Pick result: COMPLETE subchannel: (3) 127.0.0.1:62515 status: undefined undefined
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.594Z | connectivity_state | (1) dns:localhost:62515 CONNECTING -> READY
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.595Z | transport_flowctrl | (4) 127.0.0.1:62515 local window size: 65535 remote window size: 65535
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.595Z | transport_internals | (4) 127.0.0.1:62515 session.closed=false session.destroyed=false session.socket.destroyed=false
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.595Z | load_balancing_call | [2] Created child call [3]
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.596Z | subchannel_call | [3] write() called with message of length 5
2024-11-08T11:23:22.596Z root ERROR D 2024-11-08T11:23:22.596Z | subchannel_call | [3] sending data chunk of length 5
2024-11-08T11:23:22.597Z root ERROR D 2024-11-08T11:23:22.597Z | load_balancing_call | [2] halfClose called
2024-11-08T11:23:22.597Z root ERROR D 2024-11-08T11:23:22.597Z | subchannel_call | [3] end() called
2024-11-08T11:23:22.597Z root ERROR D 2024-11-08T11:23:22.597Z | subchannel_call | [3] calling end() on HTTP/2 stream
2024-11-08T11:23:22.598Z root ERROR D 2024-11-08T11:23:22.598Z | transport | (4) 127.0.0.1:62515 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2024-11-08T11:23:22.602Z root ERROR D 2024-11-08T11:23:22.601Z | subchannel_call | [3] Received server headers:
                :status: 200
                content-type: application/grpc
2024-11-08T11:23:22.602Z root ERROR D 2024-11-08T11:23:22.601Z | load_balancing_call | [2] Received metadata
2024-11-08T11:23:22.602Z root ERROR D 2024-11-08T11:23:22.602Z | retrying_call | [1] Received metadata from child [2]
2024-11-08T11:23:22.602Z root ERROR D 2024-11-08T11:23:22.602Z | retrying_call | [1] Committing call [2] at index 0
2024-11-08T11:23:22.602Z root ERROR D 2024-11-08T11:23:22.602Z | resolving_call | [0] Received metadata
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | subchannel_call | [3] receive HTTP/2 data frame of length 9
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | subchannel_call | [3] parsed message of length 9
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | subchannel_call | [3] pushing to reader message of length 9
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | load_balancing_call | [2] Received message
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | retrying_call | [1] Received message from child [2]
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.602Z | resolving_call | [0] Received message
2024-11-08T11:23:22.604Z root ERROR D 2024-11-08T11:23:22.603Z | resolving_call | [0] Finished filtering received message
2024-11-08T11:23:22.606Z root ERROR D 2024-11-08T11:23:22.605Z | subchannel_call | [3] HTTP/2 stream closed with code 1
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.605Z | subchannel_call | [3] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | load_balancing_call | [2] Received status
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | load_balancing_call | [2] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | retrying_call | [1] Received status from child [2]
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | retrying_call | [1] state=COMMITTED handling status with progress PROCESSED from child [2]in state ACTIVE
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | retrying_call | [1] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | resolving_call | [0] Received status
2024-11-08T11:23:22.607Z root ERROR D 2024-11-08T11:23:22.606Z | resolving_call | [0] ended with status: code=13 details="Received RST_STREAM with code 1"
2024-11-08T11:23:22.607Z root ERROR Uncaught Exception:  Error: 13 INTERNAL: Received RST_STREAM with code 1
2024-11-08T11:23:22.607Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 1
for call at
2024-11-08T11:23:23.272Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 151.3 ms [Finished 1.524 s after frontend start]
2024-11-08T11:23:23.272Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-11-08T11:23:23.593Z root ERROR D 2024-11-08T11:23:23.593Z | subchannel | (2) ::1:62515 TRANSIENT_FAILURE -> CONNECTING
2024-11-08T11:23:23.593Z root ERROR D 2024-11-08T11:23:23.593Z | transport | dns:localhost:62515 creating HTTP/2 session to ::1:62515
2024-11-08T11:23:23.594Z root ERROR D 2024-11-08T11:23:23.594Z | transport | dns:localhost:62515 connection failed with error connect ECONNREFUSED ::1:62515
2024-11-08T11:23:23.594Z root ERROR D 2024-11-08T11:23:23.594Z | subchannel | (2) ::1:62515 CONNECTING -> TRANSIENT_FAILURE
2024-11-08T11:23:23.594Z root ERROR D 2024-11-08T11:23:23.594Z | subchannel | (2) ::1:62515 TRANSIENT_FAILURE -> IDLE
2024-11-08T11:23:32.597Z root ERROR D 2024-11-08T11:23:32.592Z | subchannel_refcount | (2) ::1:62515 refcount 1 -> 0
Thanks
Hi all,
Any help with this would be amazing.
Thanks,
Jon
