Has anyone found a fix for this? I also cannot get Arduino IDE 2.?.? to run on windows 11. I do have an old windows 10 computer and it works on there. If it is an OneDrive issue, it is unacceptable for me to unistall OneDrive on my main computer where I want to run the Arduino IDE. It used to work so I did a windows update break it?
Please describe the exact symptoms? Pulsating logo? Stuck on downloading an index file? Something else ...
Further please follow the instructions linked to in post #9 for more help.
It is the pulsating logo. Never goes beyond that. I will look into the other post, sometime. Thanks
Read the second paragraph of my post #11.
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 6788
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/rboec/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2025-01-26T22:08:43.007Z root INFO Backend Object.initialize: 5.3 ms [Finished 0.517 s after backend start]
2025-01-26T22:08:43.011Z root INFO Backend Object.configure: 4.9 ms [Finished 0.518 s after backend start]
2025-01-26T22:08:43.011Z root INFO Backend a.onStart: 1.8 ms [Finished 0.518 s after backend start]
2025-01-26T22:08:43.012Z root INFO Backend a.configure: 0.3 ms [Finished 0.540 s after backend start]
2025-01-26T22:08:43.012Z root INFO Backend d.onStart: 0.2 ms [Finished 0.540 s after backend start]
2025-01-26T22:08:43.013Z root INFO Backend d.configure: 0.1 ms [Finished 0.540 s after backend start]
2025-01-26T22:08:43.014Z root INFO Backend d.initialize: 21.9 ms [Finished 0.540 s after backend start]
2025-01-26T22:08:43.014Z root INFO Backend c.onStart: 0.2 ms [Finished 0.540 s after backend start]
2025-01-26T22:08:43.015Z root INFO Backend s.configure: 3.8 ms [Finished 0.544 s after backend start]
2025-01-26T22:08:43.016Z config INFO >>> Initializing CLI configuration...
2025-01-26T22:08:43.016Z root INFO Backend c.initialize: 0.5 ms [Finished 0.544 s after backend start]
2025-01-26T22:08:43.016Z root INFO Backend x.onStart: 1.1 ms [Finished 0.545 s after backend start]
2025-01-26T22:08:43.017Z config INFO Loading CLI configuration from c:\Users\rboec\.arduinoIDE\arduino-cli.yaml...
2025-01-26T22:08:43.018Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-26T22:08:43.018Z root INFO Backend s.initialize: 0.4 ms [Finished 0.546 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend w.onStart: 1.4 ms [Finished 0.547 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend r.configure: 2.0 ms [Finished 0.547 s after backend start]
2025-01-26T22:08:43.018Z discovery-log INFO start
2025-01-26T22:08:43.018Z discovery-log INFO start new deferred
2025-01-26T22:08:43.018Z root INFO Backend d.initialize: 0.5 ms [Finished 0.548 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend y.onStart: 1.7 ms [Finished 0.549 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend r.configure: 1.4 ms [Finished 0.549 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend s.onStart: 0.4 ms [Finished 0.550 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend h.configure: 0.4 ms [Finished 0.550 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend a.configure: 0.1 ms [Finished 0.551 s after backend start]
2025-01-26T22:08:43.018Z root INFO Backend l.configure: 0.1 ms [Finished 0.551 s after backend start]
2025-01-26T22:08:43.021Z root INFO Theia app listening on http://127.0.0.1:54159.
2025-01-26T22:08:43.021Z root INFO Finished starting backend application: 3.2 ms [Finished 0.554 s after backend start]
2025-01-26T22:08:43.022Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rboec/.arduinoIDE/plugins does not exist.
2025-01-26T22:08:43.022Z root WARN The local plugin referenced by local-dir:/c%3A/Users/rboec/.arduinoIDE/extensions does not exist.
2025-01-26T22:08:43.022Z root WARN The local plugin referenced by local-dir:C:\Users\rboec\.arduinoIDE\plugins does not exist.
Restoring workspace roots: c:\Users\rboec\OneDrive\Documents\Arduino\RM_Test_Stand_With_Countdown_Timer\RM_Test_Stand_With_Countdown_Timer_2_With_Bluetooth\RM_Test_Stand_With_Countdown_Timer_2_With_Bluetooth.ino
2025-01-26T22:08:43.045Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json"]},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\rboec\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\rboec\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\rboec\\AppData\\Local\\Arduino15\\staging","user":"c:\\Users\\rboec\\OneDrive\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2025-01-26T22:08:43.046Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-01-26T22:08:43.046Z config INFO Loaded the CLI configuration.
2025-01-26T22:08:43.081Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/rboec/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/rboec/OneDrive/Documents/Arduino","additionalUrls":["http://arduino.esp8266.com/stable/package_esp8266com_index.json"],"network":"none","locale":"en"}
2025-01-26T22:08:43.081Z config INFO Validating the CLI configuration...
2025-01-26T22:08:43.081Z config INFO The CLI config is valid.
2025-01-26T22:08:43.081Z config INFO <<< Initialized the CLI configuration.
2025-01-26T22:08:43.100Z root INFO Resolve plugins list: 83.4 ms [Finished 0.632 s after backend start]
2025-01-26T22:08:43.119Z daemon INFO time="2025-01-26T16:08:43-06:00" level=info msg="arduino-cli version 1.0.4"
2025-01-26T22:08:43.127Z daemon INFO time="2025-01-26T16:08:43-06:00" level=info msg="Using config file: c:\\Users\\rboec\\.arduinoIDE\\arduino-cli.yaml"
2025-01-26T22:08:43.127Z daemon INFO time="2025-01-26T16:08:43-06:00" level=info msg="Executing `arduino-cli daemon`"
2025-01-26T22:08:43.162Z daemon INFO Daemon is now listening on 127.0.0.1:54160
{"IP":"127.0.0.1","Port":"54160"}
2025-01-26T22:08:43.163Z daemon I^CO Daemon is running.
PS C:\Program Files\Arduino IDE> OR Uncaught Exception: Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: Protocol error
2025-01-26T22:08:43.177Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: Protocol error
at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:912720)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:938041)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:933919)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:933364)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1019505
at process.processTicksAndRejections (node:internal/process/task_queues:77:11)
for call at
at a.makeUnaryRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:937582)
at a.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1004397)
at instance (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:769581)
at new Promise (<anonymous>)
at v.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:769558)
at v.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:768466)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:767362
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1212097
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1212187)
at a.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1213990)
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-01-26T22:08:44.819Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 230.9 ms [Finished 1.684 s after frontend start]
2025-01-26T22:08:44.828Z root WARN A command editor.action.toggleStickyScroll is already registered.
2025-01-26T22:08:46.105Z root INFO Deploy plugins list: 83.4 ms [Finished 3.637 s after backend start]
Thanks jdtech76,
I searched the the forum (https://forum.arduino.cc/search?q=%23development-tools%3Aide-2-x%20Error%3A%2013%20INTERNAL%3A%20Received%20RST_STREAM%20with%20code%202%20triggered%20by%20internal%20client%20error%3A%20Protocol%20error) and found two other topics with the same error.
See if the posts by ptillisch in IDE hangs on startup: "Received RST_STREAM with code 2 triggered by internal client error: Protocol error" and the follow up posts help you to solve the issue.
Hello
I have several users experiencing this issue both W11 & W10. I cannot replicate it on either my W11 or W10 machines. The first time few times they launch IDE it opens and works. But if they close it and launch again later, it hangs on the loading screen with the pulsing logo. If they leave it for many hours and try it, it will work.
This is the error info from a W10 machine. I do not find any reference to a proxy, which was the resolution in one of the links you share.
I have all the corporate endpoint security tools installed on my machine. On this user's machine we removed the ENS FW & AV for testing, and it still does not work. We have tried in the office and on VPN.
Do you see anything that could be causing the failure to launch?
Many thanks!
Arduino IDE 2.3.4
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.4" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.1.1" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-12-03T10:03:03.490Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.4","cliVersion":"1.1.1","buildDate":"2024-12-03T10:03:03.490Z"}
Starting backend process. PID: 24660
D 2025-01-28T19:48:39.754Z | index | Loading @grpc/grpc-js version 1.9.5
Configuration directory URI: 'file:///c%3A/Users/xxxxxx/.arduinoIDE'
2025-01-28T19:48:39.823Z root INFO Backend Object.initialize: 3.5 ms [Finished 0.417 s after backend start]
2025-01-28T19:48:39.823Z root INFO Backend Object.configure: 2.9 ms [Finished 0.417 s after backend start]
2025-01-28T19:48:39.823Z root INFO Backend s.onStart: 1.4 ms [Finished 0.417 s after backend start]
2025-01-28T19:48:39.824Z root INFO Backend s.configure: 0.2 ms [Finished 0.435 s after backend start]
2025-01-28T19:48:39.824Z root INFO Backend d.onStart: 0.2 ms [Finished 0.435 s after backend start]
2025-01-28T19:48:39.825Z root INFO Backend d.configure: 0.1 ms [Finished 0.435 s after backend start]
2025-01-28T19:48:39.825Z root INFO Backend d.initialize: 17.8 ms [Finished 0.435 s after backend start]
2025-01-28T19:48:39.825Z root INFO Backend c.onStart: 0.2 ms [Finished 0.435 s after backend start]
2025-01-28T19:48:39.826Z root INFO Backend a.configure: 0.3 ms [Finished 0.436 s after backend start]
2025-01-28T19:48:39.827Z config INFO >>> Initializing CLI configuration...
2025-01-28T19:48:39.827Z root INFO Backend c.initialize: 0.4 ms [Finished 0.436 s after backend start]
2025-01-28T19:48:39.827Z root INFO Backend x.onStart: 0.6 ms [Finished 0.436 s after backend start]
2025-01-28T19:48:39.827Z config INFO Loading CLI configuration from c:\Users\xxxxxx\.arduinoIDE\arduino-cli.yaml...
2025-01-28T19:48:39.828Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2025-01-28T19:48:39.828Z root INFO Backend a.initialize: 0.3 ms [Finished 0.437 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend w.onStart: 1.0 ms [Finished 0.438 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend r.configure: 1.5 ms [Finished 0.438 s after backend start]
2025-01-28T19:48:39.828Z discovery-log INFO start
2025-01-28T19:48:39.828Z discovery-log INFO start new deferred
2025-01-28T19:48:39.828Z root INFO Backend d.initialize: 0.3 ms [Finished 0.438 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend y.onStart: 1.3 ms [Finished 0.439 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend r.configure: 1.1 ms [Finished 0.439 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend a.onStart: 0.3 ms [Finished 0.440 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend h.configure: 0.3 ms [Finished 0.440 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend s.configure: 0.1 ms [Finished 0.440 s after backend start]
2025-01-28T19:48:39.828Z root INFO Backend l.configure: 0.0 ms [Finished 0.440 s after backend start]
2025-01-28T19:48:39.830Z root INFO Theia app listening on http://127.0.0.1:60294.
2025-01-28T19:48:39.830Z root INFO Finished starting backend application: 2.2 ms [Finished 0.442 s after backend start]
2025-01-28T19:48:39.831Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xxxxxx/.arduinoIDE/plugins does not exist.
2025-01-28T19:48:39.831Z root WARN The local plugin referenced by local-dir:/c%3A/Users/xxxxxx/.arduinoIDE/extensions does not exist.
2025-01-28T19:48:39.831Z root WARN The local plugin referenced by local-dir:C:\Users\xxxxxx\.arduinoIDE\plugins does not exist.
2025-01-28T19:48:39.836Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"builtin":{"libraries":"C:\\Users\\xxxxxx\\AppData\\Local\\Arduino15\\libraries"},"data":"c:\\Users\\xxxxxx\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\xxxxxx\\AppData\\Local\\Arduino15\\staging","user":"d:\\MyDisk\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"locale":"en","logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2025-01-28T19:48:39.836Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2025-01-28T19:48:39.836Z config INFO Loaded the CLI configuration.
Restoring workspace roots: d:\MyDisk\Documents\Arduino\sketch_feb22a
isTempSketch: false. Input was d:\MyDisk\Documents\Arduino\sketch_feb22a\sketch_feb22a.ino
2025-01-28T19:48:39.847Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/xxxxxx/AppData/Local/Arduino15","sketchDirUri":"file:///d%3A/MyDisk/Documents/Arduino","additionalUrls":["https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json"],"network":"none","locale":"en"}
2025-01-28T19:48:39.847Z config INFO Validating the CLI configuration...
2025-01-28T19:48:39.847Z config INFO The CLI config is valid.
2025-01-28T19:48:39.847Z config INFO <<< Initialized the CLI configuration.
2025-01-28T19:48:39.861Z root INFO Resolve plugins list: 33.4 ms [Finished 0.473 s after backend start]
2025-01-28T19:48:39.928Z daemon INFO time="2025-01-28T14:48:39-05:00" level=info msg="arduino-cli version 1.1.1"
time="2025-01-28T14:48:39-05:00" level=info msg="Using config file: c:\\Users\\xxxxxx\\.arduinoIDE\\arduino-cli.yaml"
time="2025-01-28T14:48:39-05:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:60296
{"IP":"127.0.0.1","Port":"60296"}
2025-01-28T19:48:39.928Z root ERROR D 2025-01-28T19:48:39.926Z | proxy | Proxy server 127.0.0.1:9000 set by environment variable http_proxy
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.926Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> IDLE
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.926Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> IDLE
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.926Z | dns_resolver | Resolver constructed for target dns:127.0.0.1:9000
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.927Z | channel | (1) dns:127.0.0.1:9000 Channel constructed with options {
"grpc.max_send_message_length": 536870912,
"grpc.max_receive_message_length": 536870912,
"grpc.primary_user_agent": "arduino-ide/2.3.4"
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.927Z | channel_stacktrace | (1) Channel constructed
at new t.InternalChannel (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:974883)
at new t.ChannelImplementation (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:927551)
at new t.Client (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:945055)
at new s (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013000)
at t.createArduinoCoreServiceClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:41260)
at v.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776583)
at v.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:775541)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:774437
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221089
at i.invoke (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1221179)
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.927Z | channel | (1) dns:127.0.0.1:9000 createResolvingCall [0] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create", deadline=Infinity
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] Created
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] Deadline: Infinity
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] start called
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | channel | (1) dns:127.0.0.1:9000 callRefTimer.ref | configSelectionQueue.length=1 pickQueue.length=0
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] startRead called
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] write() called with message of length 0
2025-01-28T19:48:39.929Z root ERROR D 2025-01-28T19:48:39.928Z | resolving_call | [0] halfClose called
2025-01-28T19:48:39.929Z daemon INFO Daemon is running.
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.929Z | subchannel | (2) 127.0.0.1:9000 Subchannel constructed with options {
"grpc.primary_user_agent": "arduino-ide/2.3.4",
"grpc.http_connect_target": "dns:localhost:60296"
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.929Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 0 -> 1
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.929Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.929Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | channel | (1) dns:127.0.0.1:9000 callRefTimer.unref | configSelectionQueue.length=1 pickQueue.length=0
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.932Z root ERROR D 2025-01-28T19:48:39.930Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | channel | (1) dns:127.0.0.1:9000 createRetryingCall [1] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | resolving_call | [0] Created child [1]
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | retrying_call | [1] start called
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | channel | (1) dns:127.0.0.1:9000 createLoadBalancingCall [2] method="/cc.arduino.cli.commands.v1.ArduinoCoreService/Create"
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | retrying_call | [1] Created child call [2] for attempt 1
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | load_balancing_call | [2] start called
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | load_balancing_call | [2] Pick called
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | load_balancing_call | [2] Pick result: QUEUE subchannel: null status: undefined undefined
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | channel | (1) dns:127.0.0.1:9000 callRefTimer.ref | configSelectionQueue.length=0 pickQueue.length=1
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | retrying_call | [1] startRead called
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.932Z | load_balancing_call | [2] startRead called
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.933Z | retrying_call | [1] write() called with message of length 5
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.933Z | load_balancing_call | [2] write() called with message of length 5
2025-01-28T19:48:39.933Z root ERROR D 2025-01-28T19:48:39.933Z | retrying_call | [1] halfClose called
2025-01-28T19:48:39.977Z root ERROR D 2025-01-28T19:48:39.976Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:39.977Z root ERROR D 2025-01-28T19:48:39.976Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:39.977Z root ERROR D 2025-01-28T19:48:39.977Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | channel | (1) dns:127.0.0.1:9000 callRefTimer.unref | configSelectionQueue.length=0 pickQueue.length=0
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | load_balancing_call | [2] Pick called
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | load_balancing_call | [2] Pick result: COMPLETE subchannel: (2) 127.0.0.1:9000 status: undefined undefined
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.977Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.978Z | transport_flowctrl | (3) 127.0.0.1:9000 local window size: 65535 remote window size: 65535
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.978Z | transport_internals | (3) 127.0.0.1:9000 session.closed=false session.destroyed=false session.socket.destroyed=false
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.978Z | load_balancing_call | [2] Created child call [3]
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.978Z | subchannel_call | [3] write() called with message of length 5
2025-01-28T19:48:39.978Z root ERROR D 2025-01-28T19:48:39.978Z | subchannel_call | [3] sending data chunk of length 5
2025-01-28T19:48:39.979Z root ERROR D 2025-01-28T19:48:39.979Z | load_balancing_call | [2] halfClose called
2025-01-28T19:48:39.979Z root ERROR D 2025-01-28T19:48:39.979Z | subchannel_call | [3] end() called
2025-01-28T19:48:39.979Z root ERROR D 2025-01-28T19:48:39.979Z | subchannel_call | [3] calling end() on HTTP/2 stream
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.979Z | subchannel_call | [3] Node error event: message=Protocol error code=ERR_HTTP2_ERROR errno=Unknown system error -505 syscall=undefined
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | subchannel_call | [3] HTTP/2 stream closed with code 2
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | subchannel_call | [3] ended with status: code=13 details="Received RST_STREAM with code 2 triggered by internal client error: Protocol error"
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | load_balancing_call | [2] Received status
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | load_balancing_call | [2] ended with status: code=13 details="Received RST_STREAM with code 2 triggered by internal client error: Protocol error"
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | retrying_call | [1] Received status from child [2]
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | retrying_call | [1] state=TRANSPARENT_ONLY handling status with progress PROCESSED from child [2] in state ACTIVE
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | retrying_call | [1] ended with status: code=13 details="Received RST_STREAM with code 2 triggered by internal client error: Protocol error"
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | resolving_call | [0] Received status
2025-01-28T19:48:39.980Z root ERROR D 2025-01-28T19:48:39.980Z | resolving_call | [0] ended with status: code=13 details="Received RST_STREAM with code 2 triggered by internal client error: Protocol error"
2025-01-28T19:48:39.981Z root ERROR Uncaught Exception: Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: Protocol error
2025-01-28T19:48:39.981Z root ERROR Error: 13 INTERNAL: Received RST_STREAM with code 2 triggered by internal client error: Protocol error
at t.callErrorFromStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:921712)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:947033)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942911)
at Object.onReceiveStatus (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:942356)
at C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1028497
for call at
at s.makeUnaryRequest (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:946574)
at s.create (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1013389)
at instance (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776656)
at v.createClient (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:776633)
at s.fire (C:\Program Files\Arduino IDE\resources\app\lib\backend\main.js:2:1222982)
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | transport | (3) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | transport | (3) 127.0.0.1:9000 session closed
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | pick_first | READY -> IDLE
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.981Z root ERROR D 2025-01-28T19:48:39.981Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.982Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:39.983Z root ERROR D 2025-01-28T19:48:39.983Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.017Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.018Z root ERROR D 2025-01-28T19:48:40.018Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | transport | (4) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | transport | (4) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.020Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.021Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.021Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.021Z root ERROR D 2025-01-28T19:48:40.021Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.024Z root ERROR D 2025-01-28T19:48:40.022Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.033Z root ERROR D 2025-01-28T19:48:40.033Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | transport | (5) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | transport | (5) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.063Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.064Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.064Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.064Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.064Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.064Z root ERROR D 2025-01-28T19:48:40.064Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.065Z root ERROR D 2025-01-28T19:48:40.064Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.073Z root ERROR D 2025-01-28T19:48:40.073Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.073Z root ERROR D 2025-01-28T19:48:40.073Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.073Z root ERROR D 2025-01-28T19:48:40.073Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.073Z root ERROR D 2025-01-28T19:48:40.073Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.073Z root ERROR D 2025-01-28T19:48:40.073Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.074Z root ERROR D 2025-01-28T19:48:40.073Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.074Z root ERROR D 2025-01-28T19:48:40.073Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.074Z root ERROR D 2025-01-28T19:48:40.073Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.074Z root ERROR D 2025-01-28T19:48:40.073Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.074Z root ERROR D 2025-01-28T19:48:40.073Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | transport | (6) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | transport | (6) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.114Z root ERROR D 2025-01-28T19:48:40.114Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.116Z root ERROR D 2025-01-28T19:48:40.114Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.142Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.142Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.143Z root ERROR D 2025-01-28T19:48:40.143Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | transport | (7) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | transport | (7) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.143Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.144Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.144Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.144Z root ERROR D 2025-01-28T19:48:40.144Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.145Z root ERROR D 2025-01-28T19:48:40.145Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.178Z root ERROR D 2025-01-28T19:48:40.178Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | transport | (8) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | transport | (8) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.179Z root ERROR D 2025-01-28T19:48:40.179Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.181Z root ERROR D 2025-01-28T19:48:40.180Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.190Z root ERROR D 2025-01-28T19:48:40.190Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | transport | (9) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | transport | (9) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.218Z root ERROR D 2025-01-28T19:48:40.218Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.219Z root ERROR D 2025-01-28T19:48:40.218Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.225Z root ERROR D 2025-01-28T19:48:40.225Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | transport | (10) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | transport | (10) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.255Z root ERROR D 2025-01-28T19:48:40.255Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.256Z root ERROR D 2025-01-28T19:48:40.256Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.256Z root ERROR D 2025-01-28T19:48:40.256Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.257Z root ERROR D 2025-01-28T19:48:40.256Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.257Z root ERROR D 2025-01-28T19:48:40.256Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.257Z root ERROR D 2025-01-28T19:48:40.256Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.257Z root ERROR D 2025-01-28T19:48:40.256Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.257Z root ERROR D 2025-01-28T19:48:40.256Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.264Z root ERROR D 2025-01-28T19:48:40.264Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | transport | (11) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | transport | (11) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.267Z root ERROR D 2025-01-28T19:48:40.267Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.271Z root ERROR D 2025-01-28T19:48:40.270Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.307Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.307Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.307Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.308Z root ERROR D 2025-01-28T19:48:40.308Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | transport | (12) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | transport | (12) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.311Z root ERROR D 2025-01-28T19:48:40.311Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.317Z root ERROR D 2025-01-28T19:48:40.316Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.354Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.354Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.354Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.355Z root ERROR D 2025-01-28T19:48:40.355Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.356Z root ERROR D 2025-01-28T19:48:40.356Z | transport | (13) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | transport | (13) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.357Z root ERROR D 2025-01-28T19:48:40.356Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.358Z root ERROR D 2025-01-28T19:48:40.357Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.369Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.369Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.369Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.370Z root ERROR D 2025-01-28T19:48:40.370Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | transport | (14) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | transport | (14) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.400Z root ERROR D 2025-01-28T19:48:40.400Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.405Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.405Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.405Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.406Z root ERROR D 2025-01-28T19:48:40.406Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | transport | (15) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | transport | (15) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.438Z root ERROR D 2025-01-28T19:48:40.438Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.438Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.439Z root ERROR D 2025-01-28T19:48:40.439Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.460Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.461Z root ERROR D 2025-01-28T19:48:40.461Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | transport | (16) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | transport | (16) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.462Z root ERROR D 2025-01-28T19:48:40.462Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.463Z root ERROR D 2025-01-28T19:48:40.463Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.495Z root ERROR D 2025-01-28T19:48:40.495Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | transport | (17) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | transport | (17) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.497Z root ERROR D 2025-01-28T19:48:40.497Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.498Z root ERROR D 2025-01-28T19:48:40.498Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.498Z root ERROR D 2025-01-28T19:48:40.498Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.498Z root ERROR D 2025-01-28T19:48:40.498Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.498Z root ERROR D 2025-01-28T19:48:40.498Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.498Z root ERROR D 2025-01-28T19:48:40.498Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.499Z root ERROR D 2025-01-28T19:48:40.498Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.499Z root ERROR D 2025-01-28T19:48:40.498Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.532Z root ERROR D 2025-01-28T19:48:40.532Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | transport | (18) 127.0.0.1:9000 connection closed with error Protocol error
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | transport | (18) 127.0.0.1:9000 session closed
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | subchannel | (2) 127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 1
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | pick_first | READY -> IDLE
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | resolving_load_balancer | dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | connectivity_state | (1) dns:127.0.0.1:9000 READY -> IDLE
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | dns_resolver | Returning IP address for target dns:127.0.0.1:9000
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | resolving_load_balancer | dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.533Z root ERROR D 2025-01-28T19:48:40.533Z | connectivity_state | (1) dns:127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 1 -> 2
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | pick_first | Start connecting to subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | pick_first | IDLE -> CONNECTING
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> CONNECTING
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | subchannel | (2) 127.0.0.1:9000 IDLE -> CONNECTING
2025-01-28T19:48:40.538Z root ERROR D 2025-01-28T19:48:40.537Z | proxy | Using proxy 127.0.0.1:9000 to connect to localhost:60296
2025-01-28T19:48:40.541Z root ERROR D 2025-01-28T19:48:40.541Z | proxy | Successfully connected to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.541Z | proxy | Successfully established a plaintext connection to localhost:60296 through proxy 127.0.0.1:9000
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.541Z | transport | dns:127.0.0.1:9000 creating HTTP/2 session through proxy to dns:localhost:60296
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | subchannel | (2) 127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | pick_first | Pick subchannel with address 127.0.0.1:9000
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 2 -> 3
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | subchannel_refcount | (2) 127.0.0.1:9000 refcount 3 -> 2
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | pick_first | CONNECTING -> READY
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | resolving_load_balancer | dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | connectivity_state | (1) dns:127.0.0.1:9000 CONNECTING -> READY
2025-01-28T19:48:40.542Z root ERROR D 2025-01-28T19:48:40.542Z | transport | (19) 127.0.0.1:9000 local settings acknowledged by remote: {"headerTableSize":4096,"enablePush":true,"initialWindowSize":65535,"maxFrameSize":16384,"maxConcurrentStreams":4294967295,"maxHeaderListSize":4294967295,"maxHeaderSize":4294967295,"enableConnectProtocol":false}
2025-01-28T19:48:40.579Z root INFO Deploy plugins list: 33.4 ms [Finished 1.191 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2025-01-28T19:48:41.312Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 104.7 ms [Finished 1.417 s after frontend start]
2025-01-28T19:48:41.312Z root WARN A command editor.action.toggleStickyScroll is already registered.
See advice in post #15.
Next time please use code tags when posting logs, thanks.
It started working the other evening and still is. Thanks
Thank you and apologies for improper posting, it is edited.
I looked for proxy in their logs a few times before my ask, third time was the charm.
Appreciate the assist.
