Same problem. Arduino IDE does not open past the loading screen. Windows 10 using Arduino IDE 2.0.2. Tried reloading, also tried other solutions I found posted here but not finding the same issues.
INFO[0000] arduino-cli.exe version 0.29.0
INFO[0000] Executing `arduino-cli daemon`
daemon INFO {"IP":"127.0.0.1","Port":"64018"}
daemon INFO Unable to get Documents Folder: The filename, directory name, or volume label syntax is incorrect.
daemon ERROR Error: Unable to get Documents Folder: The filename, directory name, or volume label syntax is incorrect.
at Socket.<anonymous> (C:\Users\tjlan\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\arduino-daemon-impl.js:219:42)
at Socket.emit (node:events:394:28)
at addChunk (node:internal/streams/readable:312:12)
at readableAddChunk (node:internal/streams/readable:287:9)
at Socket.Readable.push (node:internal/streams/readable:226:10)
at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
daemon INFO Starting daemon from C:\Users\tjlan\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
daemon INFO time="2022-11-30T14:48:27-06:00" level=error msg="Unable to get Documents Folder: The filename, directory name, or volume label syntax is incorrect."
daemon INFO INFO[0000] Using config file: c:\Users\tjlan\.arduinoIDE\arduino-cli.yaml
daemon INFO {"IP":"127.0.0.1","Port":"64019"}
daemon INFO {"IP":"127.0.0.1","Port":"64020"}
daemon INFO {"IP":"127.0.0.1","Port":"64021"}
daemon INFO {"IP":"127.0.0.1","Port":"64022"}
daemon INFO {"IP":"127.0.0.1","Port":"64023"}
daemon INFO {"IP":"127.0.0.1","Port":"64024"}
daemon INFO {"IP":"127.0.0.1","Port":"64025"}
daemon INFO {"IP":"127.0.0.1","Port":"64026"}
daemon INFO {"IP":"127.0.0.1","Port":"64027"}
daemon INFO {"IP":"127.0.0.1","Port":"64028"}
daemon INFO {"IP":"127.0.0.1","Port":"64029"}
daemon INFO {"IP":"127.0.0.1","Port":"64030"}
daemon INFO {"IP":"127.0.0.1","Port":"64031"}
daemon INFO {"IP":"127.0.0.1","Port":"64032"}
daemon INFO {"IP":"127.0.0.1","Port":"64033"}
daemon INFO {"IP":"127.0.0.1","Port":"64034"}
daemon INFO {"IP":"127.0.0.1","Port":"64035"}
daemon INFO {"IP":"127.0.0.1","Port":"64036"}
daemon INFO {"IP":"127.0.0.1","Port":"64037"}
daemon INFO {"IP":"127.0.0.1","Port":"64038"}
daemon INFO {"IP":"127.0.0.1","Port":"64039"}
daemon INFO time="2022-11-30T14:48:28-06:00" level=error msg="Unable to get Documents Folder: The filename, directory name, or volume label syntax is incorrect."
daemon INFO {"IP":"127.0.0.1","Port":"64040"}
daemon INFO {"IP":"127.0.0.1","Port":"64041"}
daemon INFO {"IP":"127.0.0.1","Port":"64042"}
daemon INFO {"IP":"127.0.0.1","Port":"64043"}
daemon INFO {"IP":"127.0.0.1","Port":"64044"}
daemon INFO {"IP":"127.0.0.1","Port":"64045"}
daemon INFO {"IP":"127.0.0.1","Port":"64046"}
daemon INFO {"IP":"127.0.0.1","Port":"64047"}
daemon INFO {"IP":"127.0.0.1","Port":"64048"}
daemon INFO {"IP":"127.0.0.1","Port":"64049"}
