IDE hangs on startup
I don't know what caused the failure to start, here is the log file I provided. Other computers of the same model can run normally, and the installation method is the same. Only this one encounters startup problems.
Arduino IDE 2.0.4
Starting backend process. PID: 1232
Configuration directory URI: 'file:///c%3A/Users/Administrator/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-04-20T10:31:52.586Z root INFO Backend Object.initialize: 3.9 ms [Finished 0.948 s after backend start]
2023-04-20T10:31:52.586Z root INFO Backend Object.configure: 3.0 ms [Finished 0.948 s after backend start]
2023-04-20T10:31:52.586Z root INFO Backend MessagingContribution.onStart: 1.4 ms [Finished 0.948 s after backend start]
2023-04-20T10:31:52.587Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 0.980 s after backend start]
2023-04-20T10:31:52.588Z root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 0.980 s after backend start]
2023-04-20T10:31:52.588Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 0.980 s after backend start]
2023-04-20T10:31:52.589Z root INFO Backend PluginLocalizationBackendContribution.initialize: 31.7 ms [Finished 0.980 s after backend start]
2023-04-20T10:31:52.589Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 0.980 s after backend start]
2023-04-20T10:31:52.590Z root INFO Backend ElectronTokenBackendContribution.configure: 0.7 ms [Finished 0.981 s after backend start]
2023-04-20T10:31:52.590Z config INFO >>> Initializing CLI configuration...
2023-04-20T10:31:52.591Z root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 0.981 s after backend start]
2023-04-20T10:31:52.591Z root INFO Backend ConfigServiceImpl.onStart: 0.8 ms [Finished 0.982 s after backend start]
2023-04-20T10:31:52.592Z config INFO Loading CLI configuration from c:\Users\Administrator\.arduinoIDE\arduino-cli.yaml...
2023-04-20T10:31:52.592Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 0.983 s after backend start]
2023-04-20T10:31:52.592Z root INFO Backend ArduinoDaemonImpl.onStart: 0.9 ms [Finished 0.984 s after backend start]
2023-04-20T10:31:52.592Z root INFO Backend NodeFileUploadService.configure: 1.7 ms [Finished 0.984 s after backend start]
2023-04-20T10:31:52.592Z daemon INFO Starting daemon from D:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-04-20T10:31:52.593Z discovery-log INFO start
2023-04-20T10:31:52.593Z discovery-log INFO start new deferred
2023-04-20T10:31:52.593Z root INFO Backend HostedPluginLocalizationService.initialize: 0.5 ms [Finished 0.984 s after backend start]
2023-04-20T10:31:52.593Z root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 0.985 s after backend start]
2023-04-20T10:31:52.593Z root INFO Backend FileDownloadEndpoint.configure: 0.7 ms [Finished 0.985 s after backend start]
2023-04-20T10:31:52.593Z root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 0.987 s after backend start]
2023-04-20T10:31:52.593Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 0.987 s after backend start]
2023-04-20T10:31:52.594Z root INFO Backend HostedPluginReader.configure: 0.2 ms [Finished 0.987 s after backend start]
2023-04-20T10:31:52.594Z root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 0.987 s after backend start]
2023-04-20T10:31:52.594Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 0.988 s after backend start]
2023-04-20T10:31:52.596Z root INFO Theia app listening on http://localhost:62735.
2023-04-20T10:31:52.596Z root INFO Finished starting backend application: 3.6 ms [Finished 0.991 s after backend start]
2023-04-20T10:31:52.624Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T10:31:52.624Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-04-20T10:31:52.624Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.7" with engines:
2023-04-20T10:31:52.624Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-04-20T10:31:52.624Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-04-20T10:31:52.625Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-04-20T10:31:52.625Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-04-20T10:31:52.626Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-04-20T10:31:52.626Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-04-20T10:31:52.626Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-04-20T10:31:52.626Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023
2023-04-20T10:31:52.647Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension.js": 6.9 ms [Finished 1.042 s after backend start]
2023-04-20T10:31:52.656Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.7" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 8.0 ms [Finished 1.050 s after backend start]
2023-04-20T10:31:52.667Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 11.2 ms [Finished 1.061 s after backend start]
2023-04-20T10:31:52.668Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 1.3 ms [Finished 1.062 s after backend start]
2023-04-20T10:31:52.669Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 0.6 ms [Finished 1.063 s after backend start]
2023-04-20T10:31:52.741Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-bg\extension": 72.3 ms [Finished 1.135 s after backend start]
2023-04-20T10:31:52.802Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 60.6 ms [Finished 1.196 s after backend start]
2023-04-20T10:31:52.948Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 146.6 ms [Finished 1.343 s after backend start]
2023-04-20T10:31:53.008Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 59.8 ms [Finished 1.403 s after backend start]
2023-04-20T10:31:53.047Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 38.9 ms [Finished 1.441 s after backend start]
2023-04-20T10:31:53.085Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-hu\extension": 37.4 ms [Finished 1.479 s after backend start]
2023-04-20T10:31:53.121Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 36.7 ms [Finished 1.516 s after backend start]
2023-04-20T10:31:53.163Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 41.2 ms [Finished 1.557 s after backend start]
2023-04-20T10:31:53.217Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ko\extension": 54.2 ms [Finished 1.611 s after backend start]
2023-04-20T10:31:53.241Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 24.3 ms [Finished 1.636 s after backend start]
2023-04-20T10:31:53.284Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pl\extension": 42.6 ms [Finished 1.678 s after backend start]
2023-04-20T10:31:53.321Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 36.7 ms [Finished 1.715 s after backend start]
2023-04-20T10:31:53.368Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 47.8 ms [Finished 1.763 s after backend start]
2023-04-20T10:31:53.409Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 40.7 ms [Finished 1.804 s after backend start]
2023-04-20T10:31:53.435Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-uk\extension": 25.4 ms [Finished 1.829 s after backend start]
2023-04-20T10:31:53.471Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "D:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 35.8 ms [Finished 1.865 s after backend start]
2023-04-20T10:31:53.471Z root INFO Deploy plugins list: 48.8 ms [Finished 1.865 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
Hi @snndbbdf. Please provide a detailed description of the symptoms of the IDE's failure to start on your system.
Is that the complete log (including the output provided in your subsequent post)? The reason I ask is because I didn't spot any "smoking gun" in the output. Usually we would expect to see an error in the logs related to the failure to start.
"I've looked through the entire startup log file and didn't see any errors, only warnings. I tried reinstalling, but the problem still persists."
